comment tourner la vue avec la souris
    Septembre 2004
    Par défaut comment tourner la vue avec la souris
    il n'y aurait pas quelqu'un qui aurait un code pour tourner correctement la vue avec la souris en opengl.
    j'ai deja essayé ca mais ca ne marche pas bien :
    119
    120
    121
    122
    123
    124
    125
    126
    127
    128
    129
    130
    131
    132
    133
    134
    135
    136
    137
    138
    139
    140
    141
    142
    143
    144
    145
    146
    147
    148
    149
    150
    151
    152
    153
    154
    155
    156
    157
    158
    #include <windows.h>
    #include <gl/gl.h>
    #include <gl/glut.h>
    #include <stdlib.h>
    #include <stdio.h>
    #define WIDTH 640
    #define HEIGHT 480
    int id_rue = 0;
    float viseex = 0,viseey = 0.0,viseez = - 1.5* 0.4;
    float emplacementx = 0,emplacementy = 0.4,emplacementz = 0;
    int a = 0;
    int murexterieurx[14] = {1.5,1.5,1.5,1.5,9.5,9.5,9.5,9.5,11,11,11,11,1.5,1.5};
    int murexterieury[14] = {0,2.45,0,2.45,0,2.45,0,2.45,0,2.45,0,2.45,0,2.45};
    int murexterieurz[14] = {-4,-4,8,8,8,8,0.5,0.5,0.5,0.5,-4,-4,-4,-4};
    void rue(){
    id_rue=glGenLists(1);
    glNewList(id_rue,GL_COMPILE);
    glBegin(GL_QUADS);
    	glColor3f(0.0,0.0,0.0);
    	glVertex3f(-1,0,-3);
    	glVertex3f(1,0,-3);
    	glVertex3f(1,0,3);
    	glVertex3f(-1,0,3);
    	glColor3f(0.5,0.5,0.5);
        glVertex3f(1,0,3);
        glVertex3f(1.1,0.05,3);
        glVertex3f(1.1,0.05,-3);
        glVertex3f(1,0,-3);
        glVertex3f(1.2,0.05,3);
        glVertex3f(1.2,0.05,-3);
        glVertex3f(1.2,0.0,-3);
        glVertex3f(1.2,0.0,3);
        glVertex3f(1,0,3);
        glVertex3f(1,0,-3);
        glVertex3f(-1,0,3);
        glVertex3f(-1.1,0.05,3);
        glVertex3f(-1.1,0.05,-3);
        glVertex3f(-1.2,0.05,3);
        glVertex3f(-1.2,0.05,-3);
        glVertex3f(-1.2,0.0,-3);
        glVertex3f(-1.2,0.0,3);
        glVertex3f(-1,0,3);
        glEnd();
        glEndList();
    void Clavier(unsigned char key, int x, int y)
    if(key == 'z'){
    emplacementz = emplacementz - 0.1;
    viseez = viseez - 0.1;
    if(key == 'q'){
    emplacementx = emplacementx - 0.1;
    viseex = viseex - 0.1;
    if(key == 's'){
    emplacementz = emplacementz + 0.1;
    viseez = viseez + 0.1;
    if(key == 'd'){
    emplacementx = emplacementx + 0.1;
    viseex = viseex + 0.1;
    if(key == 'p'){
    int ancienx = viseex;
    viseex = 0 - viseez;
    viseez = ancienx;
    glLoadIdentity();
    gluLookAt(emplacementx,emplacementy,emplacementz,viseex,viseey,viseez,0,1,0);
    glutPostRedisplay();
    void reshape(int w,int h){
    glViewport(0,0,w,h);
       glMatrixMode(GL_PROJECTION);
       glLoadIdentity();
       gluPerspective(45.0,(float) w/h,1.,1000.0f);
       glMatrixMode(GL_MODELVIEW);
    void init(){
    glClearColor(0.0,0.0,1.0,0.0);
    rue();
    void motion(int x, int y)
    printf("x : %d\n",x);
    float degre = x/1.77777777777777777;
    printf("degre : %d\n",degre);
    if(degre > 350)
    glutWarpPointer(20,y);
    else if(degre > 270){
    viseex = 0;
    viseez = -1;
    else if(degre > 180){
    viseex = 1;
    viseez = 0;
    else if(degre > 90){
    viseex = 0;
    viseez = 1;
    else if(degre > 10){
    viseex = -1;
    viseez = 0;
    else {
    glutWarpPointer(WIDTH - 20,y);
    printf("viseex : %d viseez : %d x : %d \n",viseex,viseez,degre);
    void Display()
        glLoadIdentity();
        glCallList(id_rue);
        glBegin(GL_QUADS);
        glColor3f(1,0,0);
        glVertex3f(1,0,-3);
        glVertex3f(1,1,-3);
        glVertex3f(-1,1,-3);
        glEnd();
       	glFlush();
    	glutSwapBuffers();
    int main( int argc, char *argv[ ])
    	glutInit(&argc,argv);
        glutInitDisplayMode(GLUT_RGBA | GLUT_DOUBLE | GLUT_DEPTH);
        glutInitWindowSize(WIDTH,HEIGHT);
    	glutInitWindowPosition(50,50);
    	glutCreateWindow("Fenetre OpenGL");
        init();
    	glutDisplayFunc(Display);
    	glutPassiveMotionFunc(motion);
        glutKeyboardFunc(Clavier);
    	glutReshapeFunc(reshape);
    	glutMainLoop(); // lance le gestionnaire glut
        system("PAUSE");
    	return 0;
    Avatar de bafman
    Novembre 2003
    j'ai pas le code sous la main mais moi j'ai fait un truc ou je calcule l'angle de rotation en fonction du decalage de la souris et de l'angle du frustum (passé a gluPerspective donc dans ton cas 45) ca permet de gerer les rotation aussi en fonction de l'ouverture de la camera...
    Mes articles
    Septembre 2004
    Par défaut genial
    genial, c'est le genre de programme qu'il me faut,peut-tu essayer de le retrouver?
    Juin 2004
    Il y a quelqu'un qui a fait un petit morceau de debut du jeu Homeworld justement une fonction qui fait ce que tu recherches :
    http://pierre.lando.free.fr/maisonmonde/
    Septembre 2004
    merci mais j'arrive pas a lire les fichiers .rar
    Juin 2004
    ben décompresse le avec WinRar
    Septembre 2004
    j'ai reussi a l'ouvrir mais quel source j'ouvre?
    il y en a tellement
    Juin 2004
    je ne peux vraiment pas te dire je n'ai regardé le source que tres brievement (je ne connais pas le C++ )
    d'apres moi ce serait dans le fichier cam.cpp...
    Avatar de khayyam90
    Architecte de système d’information
    Janvier 2004
    Activité : Architecte de système d’information
    un moyen pour tourner la caméra avec la souris est le suivant :
    au début de la fonction callback d'affichage :
    GetCursorPos(&mouse_position);
    SetCursorPos(centre.x,centre.y);
    anglex+=(float)(mouse_position.x-centre.x)/2;
    angley+=(float)(mouse_position.y-centre.y)/2;
    normaliser(&anglex, &angley);
    // mouvements de la caméra
    glRotated(angley, 1, 0, 0);
    glRotated(anglex, 0, 1, 0);
    la fonction normaliser() sert à 'normaliser' les valeurs des angles, autrement dit, on leur applique des modulos pour les ramener entre 0 et 360 (une fonction qui prend 2 lignes à écrire).
    Le fait de procéder comme ça permet de tourner indéfiniment dans un sens sans risquer les dépassements de capacité.
    mouse_position et centre doivent être déclarées de type POINT, et il est nécessaire de connaitre les coordonnées du centre de la fenêtre pour y remettre le curseur à chaque frame.
    de plus, anglex et angley doivent être initialisées à 0 et doivent être statiques.
    il est également possible de régler la vitesse de rotation de la caméra en jouant sur le (anglex+= ... /2)
    c'est une méthode parmis tant d'autres.
    Septembre 2004
    merci, j'ai un peu modifier le code mais ca ne va pas correctement avec se que j'avais fait(avec glulookat car a chaque fois que je bouge ma vue avec le clavier(avancer ou reculer), ca remet la vue comme avant que je la bouge avec la souris, n'aurais-tu pas la meme fonction mais avec glulookat
    Membre éclairé Avatar de venomelektro
    Avril 2004
    http://www.gametutorials.com/Tutorials/OpenGL/OpenGL_Pg1.htm
    Camera Part5 - Strafing
    A+
    Avatar de khayyam90
    Janvier 2004
    Citation Envoyé par delfare
    ce que je ferais, c'est de faire pointer la caméra vers la position de la caméra+<0,0,1>
    donc je rajouterais avant mon bout de code le
    emplacementx,emplacementy,emplacementz+1,0,1,0);
    (mais de cette manière on spécifie implicitement que la caméra est originellement tournée suivant l'axe des z et que cela correspond à anglex=0)
    Avatar de khayyam90
    Janvier 2004
    mais je rappelle aussi qu'il est posssible de faire avancer la caméra dans un monde sans utiliser glulookat.
    les gltranslated sont là pour faire avancer le monde autour de la caméra.
    Septembre 2004
    merci, grace a tes idées, j'ai inventer mon propre programme qui utilise lui glulookat a la place de rotate et translate
  1. Comment créer une vue avec des paramètres (objets) ?
    Par Ryu2000 dans le forum Eclipse Platform
    Réponses: 25
    Dernier message: 12/12/2012, 14h11
  2. Comment utiliser une vue avec 2 tables
    Par Masmeta dans le forum Développement
    Dernier message: 07/01/2011, 13h38
  3. [RCP]Comment changer de vue avec mon plugin ?
    Par Cpt Anderson dans le forum Eclipse Platform
    Réponses: 14
    Dernier message: 15/12/2010, 13h43
  4. Comment Créer une vue avec nombre de colonnes inconnu d'avance ?
    Par masterx_goldman dans le forum Développement
    Dernier message: 21/10/2009, 18h28
