Voilà, j'essaie de générer un arbre 3D avec L-System, mais j'obtiens des formes bizarres et je n'arrive pas à mettre le doigt sur le problème. De plus, pour je ne sais quelle raison l'arbre (enfin le pseudo arbre) n'est pas droit sur l'axe des Y ...
using System;
using System.Numerics;
using System.Linq;
using OpenTK;
using OpenTK.Graphics;
using OpenTK.Graphics.OpenGL4;
namespace Lsys
	public class draw_sys
		private Quaterniond rotationQuat;
		private Vector3d position;
		private Vector3d forwardVector;
		private Vector3d upvector;
		private Vector3d rightVector;
		public List<Vector3d> vertices = new List<Vector3d>();
		public List<Vector3d> vertices2 = new List<Vector3d>();
//		float x = 0.1f;
//		float y = 0.01f;
		public draw_sys ()
			rotationQuat = Quaterniond.Identity;
			forwardVector = new Vector3d(0.1, 0, 0);
			upvector = new Vector3d (0, 0.1, 0);
			rightVector = new Vector3d (0.01, 0, 0);//Vector3d.Cross (upvector, forwardVector);
		public void forward(double distance, bool draw){
			Vector3d moveVector = Vector3d.Transform (forwardVector * distance, rotationQuat);
			Vector3d oldPosition = position;
			position += moveVector;
			if (draw) {
				vertices.Add (oldPosition);
				vertices.Add (-position);
//				vertices.Add (new Vector3d (-oldPosition.Y, -oldPosition.X, 0));
//				vertices.Add (new Vector3d (-position.Y, position.X, 0));
//				vertices.Add (new Vector3d (oldPosition.Y, -oldPosition.X, 0));
//				vertices.Add (new Vector3d (position.Y, position.X, 0));
			} else {
				vertices2.Add (oldPosition);
				vertices2.Add (-position);
//				vertices2.Add (new Vector3d (-oldPosition.X, -oldPosition.Y, oldPosition.Z));
//				vertices2.Add (new Vector3d (-position.X, position.Y, position.Z));
//				vertices2.Add (new Vector3d (oldPosition.X, -oldPosition.Y, oldPosition.Z));
//				vertices2.Add (new Vector3d (position.X, position.Y, position.Z));
			//					vertices.Add (new Vector3 (-x, -y, 0.0f));//-oldPosition.X, -oldPosition.Y, oldPosition.Z));
			//					vertices.Add (new Vector3 (-x, y, 0.0f));
			//					vertices.Add (new Vector3 (x, -y, 0.0f));
			//					vertices.Add (new Vector3 (x, y, 0.0f));
			//					x += 0.1f; y += 0.2f;
		public void Yaw(double angle){
			rotationQuat *= new Quaterniond (upvector, angle);
		public void Pitch(double angle){
			rotationQuat *= new Quaterniond (rightVector, angle);
		public void Roll(double angle){
			rotationQuat *= new Quaterniond (forwardVector, angle);
		public List<Vector3d>draw_please(string lsys){
			string start = "F";
			string[] tmp = new string[10];
			tmp [0] = lsys;
			for(int n = 0; n < 3; n++)
				start = start.Replace ("F", tmp[0]);
			for (int i = 0; i < start.Length; i++) {
				if (start [i] == 'F') {
					forward (0.2, true);
				if (start [i] == '+')
					Yaw (90);
				if (start [i] == '-')
					Yaw (-90);
				if (start [i] == '[') {
					Roll (-5);
					forward (0.2f, false);
				if (start [i] == ']') {
					Pitch (5);
					for (int j = 0; j < vertices2.Count; j++) {
						vertices.Add (vertices2.ElementAt (j));
					vertices2.Clear ();
			return vertices;
Je vous remercie d'avance pour votre aide.
EDIT : voici le résultat donné (désolé l'image est un peu grande):
Nom : Lsystem-3d.png
Affichages : 170
Taille : 216,7 Ko
