paramétres de glreadpixel()
    Juillet 2009
    Par défaut paramétres de glreadpixel()
    bonjour. dans un petit code c++/opengl pour afficher deux rectangle rouge et vert,j'ai utilisé glreadpixel() pour récupérer la couleur des pixels colorés, le code est le suivant:
    119
    120
    121
    122
    123
    124
    125
    126
    127
    128
    129
    130
    131
    132
    133
    134
    135
    136
    137
    138
    139
    140
    141
    142
    143
    144
    145
    // Source file for the OFF file viewer   ***Modifiée***
    // INCLUDE FILES
    #include <iostream>
    #include <stdio.h>
    #include <stdlib.h>
    #include <string.h>
    #include <ctype.h>
    #include <math.h>
    #include <assert.h>
    #include <GL/glut.h>
    #include <GL/glu.h>
    #include <GL/gl.h>
    #ifdef _WIN32
    #include <windows.h>
    #endif
    #define DATA_WIDTH 20
    #define DATA_HEIGHT 2000
    using namespace std;
    // TYPE DEFINITIONS
    typedef struct data{
    	unsigned char  r;
    	unsigned char v;
    	unsigned char b;
    data datargb[DATA_WIDTH][DATA_HEIGHT];
    // GLUT variables
    static int GLUTwindow = 0;
    static int GLUTwindow_height = 800;
    static int GLUTwindow_width = 800;
    static int GLUTmouse[2] = { 0, 0 };
    static int GLUTbutton[3] = { 0, 0, 0 };
    static int GLUTarrows[4] = { 0, 0, 0, 0 };
    static int GLUTmodifiers = 0;
    // GLOBAL VARIABLES
    float  midLar = ((float)GLUTwindow_width) / 2.0f;
    float  midHau = ((float)GLUTwindow_height) / 2.0f;
    FILE *f=NULL; char *fichier="C:/fichierRGB.txt";
    // Display variables
    static int scaling = 0;
    static int translating = 0;
    static int rotating = 0;
    static float scale = 1.0;
    static float center[3] = { 0.0, 0.0, 0.0 };
    static float rotation[3] = { 0.0, 0.0, 0.0 };
    static float translation[3] = { 0.0, 0.0, -4.0 };
    void drawRectangle(void)
      // Set projection transformation
      glMatrixMode(GL_PROJECTION);
      glLoadIdentity();
      gluPerspective(45.0, (GLfloat) GLUTwindow_width /(GLfloat) GLUTwindow_height, 0.1, 100.0);
      // Set camera transformation
      glMatrixMode(GL_MODELVIEW);
      glLoadIdentity();
      glTranslatef(translation[0], translation[1], translation[2]);
      glScalef(scale, scale, scale);
      glRotatef(rotation[0], 1.0, 0.0, 0.0);
      glRotatef(rotation[1], 0.0, 1.0, 0.0);
      glRotatef(rotation[2], 0.0, 0.0, 1.0);
      glTranslatef(-center[0], -center[1], -center[2]);
      // Clear window
      glClearColor(.0, .0, .0, 1.0);
      glColor3f(.0,.0,.0);
    //rectangle rouge
    glColor3f(1.0,.0,.0);
    glBegin(GL_POLYGON);
    glVertex2f(.0,.0);
    glVertex2f(0.2,.0);
    glVertex2f(0.2,1.0);
    glVertex2f(.0,1.0);
    glEnd();
    rectangle vert
    glColor3f(.0,1.0,.0);
    glVertex2f(0.201,0.0);
    glVertex2f(0.4,0.0);
    glVertex2f(0.4,1.0);
    glVertex2f(0.201,1.0);
    glEnd();
    glutSwapBuffers();
    glReadBuffer(GL_FRONT);
    glReadPixels((int)(midLar),(int)(midHau),DATA_WIDTH,DATA_HEIGHT,GL_RGB,GL_UNSIGNED_BYTE,datargb);
    f=fopen(fichier,"w");
    for(int k=0;k<3;k++)
    for(int m=0;m<2000;m++)
     fprintf(f,"[%d][%d]:  r:%d   g:%d   b:%d\n",k,m,(int)datargb[k][m].r,(int)datargb[k][m].v,(int)datargb[k][m].b);
    fclose(f);
    void GLUTInit(int *argc, char **argv)
      // Open window
      glutInit(argc, argv);
      glutInitWindowPosition(300, 100);
      glutInitWindowSize(GLUTwindow_width, GLUTwindow_height);
      glutInitDisplayMode(GLUT_DOUBLE | GLUT_RGB | GLUT_DEPTH);
      GLUTwindow = glutCreateWindow("OpenGL Viewer");
      // Initialize GLUT callback functions
      glutDisplayFunc(drawRectangle);
      // Initialize graphics modes
      glEnable(GL_DEPTH_TEST);
    int main(int argc, char **argv)
      // Initialize GLUT
      GLUTInit(&argc, argv);
      // Run GLUT interface
      glutMainLoop();
      // Return success
      return 0;
    ma question est : quelle est la largeur et la hauteur adéquate de glreadpixel() pour récupérer seulement les couleurs rouge et vert (des deux rectangles sachant que les point des rectangle sont de type float ?
    cordialement
    Responsable 2D/3D/Jeux
    Avatar de LittleWhite
    Mai 2008
    Cela dépend de la taille de votre viewport (qui est généralement, la taille de la fenêtre). Cela dépend aussi de toutes les transformations que vous effectués sur votre pixel (matrice monde / vue / projection). Car pour retrouver la positio exacte du point d'un rectange, comme il le sera sur l'écran, il faut le transformer (comme le fait OpenGL). Une astuce, mais je crois, maintenant dépréciée, c'est d'utiliser glProject().
    Ma page sur DVP
    Mon Portfolio
  1. [xmlrad] Pb de paramètre ?
    Par Pm dans le forum XMLRAD
    Dernier message: 07/01/2003, 15h37
  2. [SWT] Problème de paramètre GridData
    Par yolepro dans le forum SWT/JFace
    Dernier message: 06/12/2002, 11h37
  3. passage en paramètre d'un array dynamique 2D
    Par Guigui_ dans le forum Langage
    Dernier message: 27/11/2002, 20h47
  4. Paramètre requete SQL (ADOQuery)
    Par GaL dans le forum C++Builder
    Dernier message: 30/07/2002, 12h24
  5. glReadPixels
    Par exxos dans le forum OpenGL
    Dernier message: 15/05/2002, 22h37
