Texture Qt / OpenGl
    Juillet 2009
    Par défaut Texture Qt / OpenGl
    je suis en train d'apprendre openGl avec Qt, J'ai fait un cube et j'ai voulu le texturer. seulement mon cube apparaît blanc (comme si la texture n'avait pas été chargée). ma texture est bien de dimension 2^n.
    Je met le code
    glWidget.h
    #define _GLWIDGET_H
    #include <QtGui>
    #include <QtOpenGL/QGLWidget>
    #include <iostream>
    class GLWidget : public QGLWidget {
        Q_OBJECT // must include this if you use Qt signals/slots
    public:
        GLWidget(QWidget *parent = NULL);
    protected:
        void initializeGL();
        void resizeGL(int w, int h);
        void paintGL();
        void chargerTextures();
        void mousePressEvent(QMouseEvent *event);
        void mouseMoveEvent(QMouseEvent *event);
        void keyPressEvent(QKeyEvent *event);
        GLuint texture[1];
    #endif  /* _GLWIDGET_H */
    glWidget.cpp
    119
    120
    #include <QtGui/QMouseEvent>
    #include <iostream>
    #include "glWidget.h"
    GLWidget::GLWidget(QWidget *parent) : QGLWidget(parent) {
        setMouseTracking(true);
    void GLWidget::initializeGL()
        glEnable(GL_CULL_FACE);
        glEnable(GL_TEXTURE_2D);
        glEnable(GL_DEPTH_TEST);
        glEnable(GL_BLEND);
        glEnable(GL_POLYGON_SMOOTH);
        glBlendFunc(GL_SRC_ALPHA, GL_ONE_MINUS_SRC_ALPHA);
        glClearColor(0, 0, 0, 0);
    void GLWidget::chargerTextures()
        QImage buf_vitrail;
        QImage vitrail;
        buf_vitrail.load("vitrail.bmp");
        vitrail = QGLWidget::convertToGLFormat(buf_vitrail);
        glGenTextures(1, &texture[0]);
        glTexImage2D(GL_TEXTURE_2D, 0, 3, vitrail.width(), vitrail.height(), 0, GL_RGB, GL_BITMAP, &texture[0]);
        glTexParameteri(GL_TEXTURE_2D,GL_TEXTURE_MIN_FILTER,GL_LINEAR);
        glTexParameteri(GL_TEXTURE_2D,GL_TEXTURE_MAG_FILTER,GL_LINEAR);
    void GLWidget::resizeGL(int w, int h) {
        int side = qMin(w, h);
             glViewport((w - side) / 2, (h - side) / 2, side, side);
             glMatrixMode(GL_PROJECTION);
             glLoadIdentity();
             glOrtho(-0.5, +0.5, -0.5, +0.5, 4.0, 15.0);
             glMatrixMode(GL_MODELVIEW);
    void GLWidget::paintGL() {
        glMatrixMode( GL_PROJECTION );
        glLoadIdentity();
        gluPerspective(90.f, 1.f, 1.f, 500.f);
        glClear( GL_COLOR_BUFFER_BIT | GL_DEPTH_BUFFER_BIT );
        glMatrixMode( GL_MODELVIEW );
        glLoadIdentity( );
        glBindTexture(GL_TEXTURE_2D, texture[0]);
        gluLookAt(3,4,2,0,0,0,0,0,1);
        glBegin(GL_QUADS);
                        glTexCoord2f(0.0f, 0.0f); glVertex3f(-1.0f, -1.0f,  1.0f);	// Bottom Left Of The Texture and Quad
                        glTexCoord2f(1.0f, 0.0f); glVertex3f( 1.0f, -1.0f,  1.0f);	// Bottom Right Of The Texture and Quad
                        glTexCoord2f(1.0f, 1.0f); glVertex3f( 1.0f,  1.0f,  1.0f);	// Top Right Of The Texture and Quad
                        glTexCoord2f(0.0f, 1.0f); glVertex3f(-1.0f,  1.0f,  1.0f);	// Top Left Of The Texture and Quad
                        // Back Face
                        glTexCoord2f(1.0f, 0.0f); glVertex3f(-1.0f, -1.0f, -1.0f);	// Bottom Right Of The Texture and Quad
                        glTexCoord2f(1.0f, 1.0f); glVertex3f(-1.0f,  1.0f, -1.0f);	// Top Right Of The Texture and Quad
                        glTexCoord2f(0.0f, 1.0f); glVertex3f( 1.0f,  1.0f, -1.0f);	// Top Left Of The Texture and Quad
                        glTexCoord2f(0.0f, 0.0f); glVertex3f( 1.0f, -1.0f, -1.0f);	// Bottom Left Of The Texture and Quad
                        // Top Face
                        glTexCoord2f(0.0f, 1.0f); glVertex3f(-1.0f,  1.0f, -1.0f);	// Top Left Of The Texture and Quad
                        glTexCoord2f(0.0f, 0.0f); glVertex3f(-1.0f,  1.0f,  1.0f);	// Bottom Left Of The Texture and Quad
                        glTexCoord2f(1.0f, 0.0f); glVertex3f( 1.0f,  1.0f,  1.0f);	// Bottom Right Of The Texture and Quad
                        glTexCoord2f(1.0f, 1.0f); glVertex3f( 1.0f,  1.0f, -1.0f);	// Top Right Of The Texture and Quad
                        // Bottom Face
                        glTexCoord2f(1.0f, 1.0f); glVertex3f(-1.0f, -1.0f, -1.0f);	// Top Right Of The Texture and Quad
                        glTexCoord2f(0.0f, 1.0f); glVertex3f( 1.0f, -1.0f, -1.0f);	// Top Left Of The Texture and Quad
                        glTexCoord2f(0.0f, 0.0f); glVertex3f( 1.0f, -1.0f,  1.0f);	// Bottom Left Of The Texture and Quad
                        glTexCoord2f(1.0f, 0.0f); glVertex3f(-1.0f, -1.0f,  1.0f);	// Bottom Right Of The Texture and Quad
                        // Right face
                        glTexCoord2f(1.0f, 0.0f); glVertex3f( 1.0f, -1.0f, -1.0f);	// Bottom Right Of The Texture and Quad
                        glTexCoord2f(0.0f, 1.0f); glVertex3f( 1.0f,  1.0f,  1.0f);	// Top Left Of The Texture and Quad
                        // Left Face
                        glTexCoord2f(0.0f, 0.0f); glVertex3f(-1.0f, -1.0f, -1.0f);	// Bottom Left Of The Texture and Quad
                        glTexCoord2f(1.0f, 1.0f); glVertex3f(-1.0f,  1.0f,  1.0f);	// Top Right Of The Texture and Quad
            glEnd();
    void GLWidget::mousePressEvent(QMouseEvent *event) {
    void GLWidget::mouseMoveEvent(QMouseEvent *event) {
    void GLWidget::keyPressEvent(QKeyEvent* event) {
        switch(event->key()) {
        case Qt::Key_Escape:
            close();
            break;
        default:
            event->ignore();
            break;
    Voilà, si quelu'un pouvait me dire ce qui cloche dans mon code ce serait bien sympa. Moi je ne vois pas d'où ça peut venir, en plus je n'ai aucune erreur au compilo.
    (avant de poster je me suis renseigné)
    Merci d'avance.
    Novembre 2008
    Secteur : Santé
    Bonjour Wiz02
    Premier problème : dans ta fonction initializeGL, quand tu écris :
    tu déclares en fait une nouvelle fonction chargerTextures mais tu n'appelles pas ta fonction GLWidget::chargerTextures. Il faut donc écrire :
        chargerTextures();
    (PS : si tu utilises Qt Creator, l'IDE de Qt, cette erreur serait soulignée dans l'éditeur)
    Ensuite, dans ta fonction chargerTextures, tu charges ta texture dans la variable vitrail mais à aucun moment, tu utilises cette variable (tu utilises uniquement ses dimensions).
    Il faut la passer en paramètre à glTexImage2D :
        0, GL_RGB, GL_UNSIGNED_BYTE, vitrail.bits());
    Il manque également un bind de ta texture après ta génération :
    Au final, ta fonction chargerTextures devient :
        QImage buf_vitrail;
        QImage vitrail;
        glBindTexture( GL_TEXTURE_2D, texture[0] );
    Tu peux améliorer en faisant :
    - mettre tes textures dans un fichier ressources .qrc
    - utiliser la fonction QGLWidget::bindTexture :
        QImage buf_vitrail;
        QImage vitrail;
        texture[0] = bindTexture(vitrail);
    - Utiliser les shaders programs. Regarde le code de l'exemple texture : http://qt.developpez.com/doc/4.6/ope...-glwidget-cpp/
    - Plus généralement, tu peux regarder le code des exemples Qt sur l'OpenGL : http://qt.developpez.com/doc/4.6/examples-opengl/
    Juillet 2009
    Bonjour gbdivers
    Maintenant,ça marche.
    Merci beaucoup pour cette réponse hyper complète et pour les liens.
    Wiz02.
  1. plusieurs textures en OpenGL
    Par KaD dans le forum OpenGL
    Dernier message: 04/03/2006, 12h08
  2. Texture SDL + OpenGL
    Par batman60 dans le forum OpenGL
    Dernier message: 17/07/2005, 15h02
  3. Incohérence des textures sous OpenGL
    Par Nicuvëo / Calëtunda dans le forum OpenGL
    Dernier message: 22/12/2004, 11h27
  4. texture sous opengl : objets complexes
    Par pouleriguen dans le forum OpenGL
    Dernier message: 20/11/2004, 20h47
  5. BP avec Textures en OpenGL
    Par skyghis dans le forum OpenGL
    Dernier message: 27/11/2003, 18h15
