glsl multi texturing
    Octobre 2007
    Par défaut glsl multi texturing
    Salut tout le monde,
    J'essaye en ce moment d'envoyer plusieurs coordonnées de textures à mon shader glsl mais j'y arrive pas.
    Mon but étant de rendre un terrain avec plusieurs niveaux de textures. (en passant par les VAs et VBOs)
    Voici le code coté application:
    glEnableClientState(GL_VERTEX_ARRAY);
    glEnableClientState(GL_NORMAL_ARRAY);
    glEnableClientState(GL_TEXTURE_COORD_ARRAY);
    glEnable(GL_TEXTURE_2D);
    glActiveTexture(GL_TEXTURE0_ARB);
    if(mesh->GetMaterial()->GetTexture(0))
        glBindTexture(GL_TEXTURE_2D, mesh->GetMaterial()->GetTexture(0)->m_glName);
    glTexCoordPointer(2, GL_FLOAT, sizeof(mythic::gpm::TERRAIN_VERTEX), &v->u0);
    glActiveTexture(GL_TEXTURE1_ARB);
    if(mesh->GetMaterial()->GetTexture(1))
        glBindTexture(GL_TEXTURE_2D, mesh->GetMaterial()->GetTexture(1)->m_glName);
    glTexCoordPointer(2, GL_FLOAT, sizeof(mythic::gpm::TERRAIN_VERTEX), &v->u1);
    glActiveTexture(GL_TEXTURE2_ARB);
    if(mesh->GetMaterial()->GetTexture(2))
        glBindTexture(GL_TEXTURE_2D, mesh->GetMaterial()->GetTexture(2)->m_glName);
    glTexCoordPointer(2, GL_FLOAT, sizeof(mythic::gpm::TERRAIN_VERTEX), &v->u2);
    glVertexPointer(3, GL_FLOAT, sizeof(mythic::gpm::TERRAIN_VERTEX), &v->x);
    glNormalPointer(GL_FLOAT, sizeof(mythic::gpm::TERRAIN_VERTEX), &v->nx);
    et voici le vertex shader:
    void main()
    	gl_TexCoord[0] = gl_MultiTexCoord0;
    	gl_TexCoord[1] = gl_MultiTexCoord1;
    	gl_TexCoord[2] = gl_MultiTexCoord2;
    	gl_Position = ftransform();
    Et voici le fragment shader
    // Uniform samplers, will be used to render the detail layers of the terrain. except
    // for the main_diffuse_map, each diffuse map is associated with one alpha map.
    uniform sampler2D main_diffuse_map;
    uniform sampler2D diffuse_map_1;
    uniform sampler2D alpha_map_1;
    uniform sampler2D diffuse_map_2;
    uniform sampler2D alpha_map_2;
    uniform sampler2D diffuse_map_3;
    uniform sampler2D alpha_map_3;
    uniform sampler2D diffuse_map_4;
    uniform sampler2D alpha_map_4;
    uniform sampler2D diffuse_map_5;
    uniform sampler2D alpha_map_5;
    uniform sampler2D diffuse_map_6;
    uniform sampler2D alpha_map_6;
    // Texture units support.
    uniform int texUnitSup;
    void main()
    	if(texUnitSup > 16)//The splatting will be done with all the splatting layers in one pass.
    		vec4 mainDiffMap = texture2D(main_diffuse_map, gl_TexCoord[0].st);
    		vec4 diffMap1 = texture2D(diffuse_map_1, gl_TexCoord[1].st);
    		vec4 alphaMap1 = texture2D(alpha_map_1, gl_TexCoord[2].st);
    		vec4 diffMap2 = texture2D(diffuse_map_1, gl_TexCoord[1]);
    		vec4 alphaMap2 = texture2D(alpha_map_1, gl_TexCoord[2]);
    		vec4 diffMap3 = texture2D(diffuse_map_1, gl_TexCoord[1]);
    		vec4 alphaMap3 = texture2D(alpha_map_1, gl_TexCoord[2]);
    		vec4 diffMap4 = texture2D(diffuse_map_1, gl_TexCoord[1]);
    		vec4 alphaMap4 = texture2D(alpha_map_1, gl_TexCoord[2]);
    		vec4 diffMap5 = texture2D(diffuse_map_1, gl_TexCoord[1]);
    		vec4 alphaMap5 = texture2D(alpha_map_1, gl_TexCoord[2]);
    		vec4 diffMap6 = texture2D(diffuse_map_1, gl_TexCoord[1]);
    		vec4 alphaMa6 = texture2D(alpha_map_1, gl_TexCoord[2]);
    		gl_FragColor = mainDiffMap + (diffMap1 * alphaMap1) /*+ (diffMap2 * alphaMap2)
    			                       + (diffMap3 * alphaMap3) + (diffMap4 * alphaMap4)
    								   + (diffMap5 * alphaMap5) + (diffMap6 * alphaMap6)*/;
    	else if(texUnitSup > 8)//The splatting will be done with 5/6 splatting layers in one pass.
    	else
    		//The engine is not designed fot this kind of hardware !!!
    Ce que j'ai comme résultat avec ce code c'est que, seules les dernières coordonnées passées a glTexCoordPointer sont prisent en compte, aussi, coté shader, les coordonnées 1 et 2 (gl_MultiTexCoord1/2) ne sont pas initialisées (opengl n'a pas envoyé ces coordonnées là)
    Voila, merci.
    Responsable technique
    Février 2006
    Activité : Responsable technique
    Tu pourrais mettre le fragment shader?
    Octobre 2007
    Je relance le sujet.
    Merci de bien vouloir jeter un oeil sur mon soucis =)
    Avatar de wax78
    R&D - Palefrenier programmeur
    Août 2006
    Par le plus grand hasard (ne l'ayant jamais testé avec des VBO et autres), ne faut-il pas utilisé ?
    void glClientActiveTexture(	GLenum  	texture);
    (Mais c'est vraiment au pif en esperant que ca soit .
    Octobre 2007
    Merci pour la réponse, mais ça n'a pas marché :/
    Je me suis débrouillé un peu à ma façon, et j'ai envoyé les autres coordonnées de textures par le biais des vertex attributes =)
    Voila donc, problème résolu.
    Merci.
  1. Multi texture dans avec les VBO
    Par yvesall dans le forum OpenGL
    Dernier message: 28/04/2009, 02h05
  2. [libjpeg && opengl] problème "multi-texturing"
    Par pspflashsystem dans le forum OpenGL
    Dernier message: 23/02/2009, 14h01
  3. [ GLSL ] et textures (débutant)
    Par scannerz57 dans le forum OpenGL
    Dernier message: 24/12/2008, 15h01
  4. Réponses: 2
    Dernier message: 29/02/2008, 16h59
  5. GLSL : Affichage Texture
    Par Lhudel dans le forum OpenGL
    Dernier message: 09/03/2007, 17h12
