Hello,
Voilà c'est très simple
Disons que j'ai 3 tables:
la requête paginée suivante:
4 ACTOR (+- 1800000 rows) FILES (+- 1700000 rows) FILE_CONTRACT (+-500000 rows)
qui contient donc un order by (pour la pagination).
17 select * from ( select rownum rnum, a.* from (SELECT contract.INTEGRATED_FILE_ID FROM FILE_CONTRACT file_contract, FILES contract, ACTOR declarant WHERE file_contract.CONTRACTOR_ID=declarant.ID AND file_contract.FILE_ID=contract.ID AND declarant.ACTOR_TYPE_CODE ='contractor' AND declarant.BCE_NUM=999999724 ORDER BY contract.INTEGRATED_FILE_ID desc ) a where rownum < 25 ) where rnum >= 10;
les indexes sur les champs utilisés dans cette requête sont:
l'explain plan:
4 ACTOR(BCE_NUM) FILES(ID,INTEGRATED_FILE_ID) FILE_CONTRACT(CONTRACTOR_ID,FILE_ID)
Le problème c'est que c'est quand même assez couteux... Ca tombe même en time out (30sec!) quand la db est chargée ;(
37 PLAN_TABLE_OUTPUT ------------------------------------------------------------------------------------------------------------------------------------------------------ ----------------------------------------------------------------------------------------------------- | Id | Operation | Name | Rows | Bytes | Cost | ----------------------------------------------------------------------------------------------------- | 0 | SELECT STATEMENT | | 1 | 26 | 10 | |* 1 | VIEW | | 1 | 26 | 10 | |* 2 | COUNT STOPKEY | | | | | | 3 | VIEW | | 1 | 13 | 10 | |* 4 | SORT ORDER BY STOPKEY | | 1 | 40 | 10 | | 5 | NESTED LOOPS | | 1 | 40 | 8 | | 6 | NESTED LOOPS | | 4 | 116 | 4 | PLAN_TABLE_OUTPUT ------------------------------------------------------------------------------------------------------------------------------------------------------ |* 7 | TABLE ACCESS BY INDEX ROWID| ACTOR | 1 | 18 | 2 | |* 8 | INDEX RANGE SCAN | ACTOR_M2_BCE_NUM | 2 | | 1 | |* 9 | INDEX RANGE SCAN | FILE_CONTRACT_M1_CONTRACTOR_ID | 1 | 11 | 2 | |* 10 | INDEX RANGE SCAN | FILES_M3_INT_FILE_ID | 1635K| 17M| 1 | ----------------------------------------------------------------------------------------------------- Predicate Information (identified by operation id): --------------------------------------------------- 1 - filter("from$_subquery$_001"."RNUM">=10) 2 - filter(ROWNUM<25) PLAN_TABLE_OUTPUT ------------------------------------------------------------------------------------------------------------------------------------------------------ 4 - filter(ROWNUM<25) 7 - filter("DECLARANT"."ACTOR_TYPE_CODE"='contractor') 8 - access("DECLARANT"."BCE_NUM"=416451583) 9 - access("FILE_CONTRACT"."CONTRACTOR_ID"="DECLARANT"."ID") 10 - access(SYS_OP_DESCEND("FILE_CONTRACT"."FILE_ID")=SYS_OP_DESCEND("CONTRACT"."ID")) filter("FILE_CONTRACT"."FILE_ID"="CONTRACT"."ID")
Et ça à l'air de venir de la clause order by. (Normal j'imagine que ça prenne du temps mais si quelqu'un sait comment optimiser ça, en jouant sur les indexes ou autre chose...)
Voici, pour info les traces, on voit clairement la différence avec la clause order by ou sans:
Avec:
et sans:
39 Execution Plan ---------------------------------------------------------- 0 SELECT STATEMENT Optimizer=CHOOSE (Cost=10 Card=1 Bytes=26) 1 0 VIEW (Cost=10 Card=1 Bytes=26) 2 1 COUNT (STOPKEY) 3 2 VIEW (Cost=10 Card=1 Bytes=13) 4 3 SORT (ORDER BY STOPKEY) (Cost=10 Card=1 Bytes=40) 5 4 NESTED LOOPS (Cost=8 Card=1 Bytes=40) 6 5 NESTED LOOPS (Cost=4 Card=4 Bytes=116) 7 6 TABLE ACCESS (BY INDEX ROWID) OF 'ACTOR' (Cost =2 Card=1 Bytes=18) 8 7 INDEX (RANGE SCAN) OF 'ACTOR_M2_BCE_NUM' (NO N-UNIQUE) (Cost=1 Card=2) 9 6 INDEX (RANGE SCAN) OF 'FILE_CONTRACT_M1_CONTRA CTOR_ID' (NON-UNIQUE) (Cost=2 Card=1 Bytes=11) 10 5 INDEX (RANGE SCAN) OF 'FILES_M3_INT_FILE_ID' (NO N-UNIQUE) (Cost=1 Card=1635731 Bytes=17993041) Statistics ---------------------------------------------------------- 0 recursive calls 0 db block gets 5970 consistent gets 1630 physical reads 0 redo size 669 bytes sent via SQL*Net to client 368 bytes received via SQL*Net from client 2 SQL*Net roundtrips to/from client 1 sorts (memory) 0 sorts (disk) 15 rows processed
37 Execution Plan ---------------------------------------------------------- 0 SELECT STATEMENT Optimizer=CHOOSE (Cost=8 Card=1 Bytes=26) 1 0 VIEW (Cost=8 Card=1 Bytes=26) 2 1 COUNT (STOPKEY) 3 2 NESTED LOOPS (Cost=8 Card=1 Bytes=40) 4 3 NESTED LOOPS (Cost=4 Card=4 Bytes=116) 5 4 TABLE ACCESS (BY INDEX ROWID) OF 'ACTOR' (Cost=2 C ard=1 Bytes=18) 6 5 INDEX (RANGE SCAN) OF 'ACTOR_M2_BCE_NUM' (NON-UN IQUE) (Cost=1 Card=2) 7 4 INDEX (RANGE SCAN) OF 'FILE_CONTRACT_M1_CONTRACTOR _ID' (NON-UNIQUE) (Cost=2 Card=1 Bytes=11) 8 3 INDEX (RANGE SCAN) OF 'FILES_M3_INT_FILE_ID' (NON-UN IQUE) (Cost=1 Card=1635731 Bytes=17993041) Statistics ---------------------------------------------------------- 0 recursive calls 0 db block gets 59 consistent gets 0 physical reads 0 redo size 640 bytes sent via SQL*Net to client 368 bytes received via SQL*Net from client 2 SQL*Net roundtrips to/from client 0 sorts (memory) 0 sorts (disk) 15 rows processed
Voilàj'ai l'impression que ce sont les physical reads qui plombent tout mais je ne sais pas trop d'ou ça vient... et même s'il y a moyen d'optimiser ça...
Merci pour ceux qui ont lu jusqu'au bout![]()
