Webdesign & Ergonomie Discussion :
Intégration interface déjà créée dans le code php
    Mai 2009
    Par défaut Intégration interface déjà créée dans le code php
    Comme le titre l'indique, je dois intégrer une interface dans mon code php seulement je ne sais pas du tout comment faire. Voici mon code php:
    119
    120
    121
    122
    123
    124
    125
    126
    127
    128
    129
    130
    131
    132
    133
    134
    135
    136
    137
    138
    139
    140
    141
    142
    143
    <!--Page d'accueil de la console d'administration-->
    <html>
    <head><body background="img.jpg">
    <div align="center"><font color="white"><h2>Accueil Console d'administration</h2></font></div>
    <table><tr><td width="200"><a href="admincat.php">Gestion des catégories</a></td><td width="200"><a href="login.php">Déconnexion</a></td><td width="200"><a href="dumpDB.php">Sauvegarde</a></td></tr></table><br/>
    <script type="text/javascript" src="http://ajax.googleapis.com/ajax/libs/jquery/1.3.2/jquery.min.js"></script>
    <script type="text/javascript" src="ddaccordion.js"></script>
    ddaccordion.init({
    	headerclass: "submenuheader", //Shared CSS class name of headers group
    	contentclass: "submenu", //Shared CSS class name of contents group
    	revealtype: "click", //Reveal content when user clicks or onmouseover the header? Valid value: "click", "clickgo", or "mouseover"
    	mouseoverdelay: 200, //if revealtype="mouseover", set delay in milliseconds before header expands onMouseover
    	collapseprev: true, //Collapse previous content (so only one open at any time)? true/false
    	defaultexpanded: [], //index of content(s) open by default [index1, index2, etc] [] denotes no content
    	onemustopen: false, //Specify whether at least one header should be open always (so never all headers closed)
    	animatedefault: false, //Should contents open by default be animated into view?
    	persiststate: true, //persist state of opened contents within browser session?
    	toggleclass: ["", ""], //Two CSS classes to be applied to the header when it's collapsed and expanded, respectively ["class1", "class2"]
    	//togglehtml: ["suffix", "<img src='images/plus.gif' class='statusicon' />", "<img src='images/minus.gif' class='statusicon' />"], //Additional HTML added to the header when it's collapsed and expanded, respectively  ["position", "html1", "html2"] (see docs)
    	animatespeed: "fast", //speed of animation: integer in milliseconds (ie: 200), or keywords "fast", "normal", or "slow"
    	oninit:function(headers, expandedindices){ //custom code to run when headers have initalized
    		//do nothing
    	onopenclose:function(header, index, state, isuseractivated){ //custom code to run whenever a header is opened or closed
    		//do nothing
    </script>
    <style type="text/css">
    .glossymenu{
    margin: 5px 0;
    padding: 0;
    width: 170px; /*width of menu*/
    border: 1px solid #9A9A9A;
    border-bottom-width: 0;
    .glossymenu a.menuitem{
    background: black url(glossyback.gif) repeat-x bottom left;
    font: bold 14px "Lucida Grande", "Trebuchet MS", Verdana, Helvetica, sans-serif;
    color: white;
    display: block;
    position: relative; /*To help in the anchoring of the ".statusicon" icon image*/
    width: auto;
    padding: 4px 0;
    padding-left: 10px;
    text-decoration: none;
    .glossymenu a.menuitem:visited, .glossymenu .menuitem:active{
    color: white;
    .glossymenu a.menuitem .statusicon{ /*CSS for icon image that gets dynamically added to headers*/
    position: absolute;
    top: 5px;
    right: 5px;
    border: none;
    .glossymenu a.menuitem:hover{
    background-image: url(glossyback2.gif);
    .glossymenu div.submenu{ /*DIV that contains each sub menu*/
    background: white;
    .glossymenu div.submenu ul{ /*UL of each sub menu*/
    list-style-type: none;
    margin: 0;
    padding: 0;
    .glossymenu div.submenu ul li{
    border-bottom: 1px solid blue;
    .glossymenu div.submenu ul li a{
    display: block;
    font: normal 13px "Lucida Grande", "Trebuchet MS", Verdana, Helvetica, sans-serif;
    color: black;
    padding: 2px 0;
    padding-left: 10px;
    .glossymenu div.submenu ul li a:hover{
    background: #DFDCCB;
    colorz: white;
    </style>
    </head>
    <body>
    <?php
    include("connection.php");
    $r_cat = mysql_db_query($db,"SELECT * FROM cat ORDER BY ordre ASC");
    while($cat = mysql_fetch_assoc($r_cat))
       $r_pages= mysql_db_query($db,"SELECT * FROM pages WHERE id_cat= '$cat[id]' ORDER BY ordre ASC");
       $n=mysql_num_rows($r_pages);
       if($n>=1)
       $class='menuitem submenuheader';
       $debut='<div class="submenu"><ul>';
       $fin='</ul></div>';
    	else
    	$class='menuitem';
    	$debut='';
    	$fin='';
        echo '<div class="glossymenu"><form method="post" action="ajoutpages.php" ><input type="image" src="plus.gif" title="Ajouter une page dans la catégorie" />
    	<input type="hidden" name="categories" value="'.$cat['id'].'" /><a class="'.$class.'">'.$cat['nom_fr'].'('.$n.')</a></form>'; // formulaire permettant l'accès à la page d'ajout de pages par l'intermédiaire de l'icone plus.
        echo $debut;
        while($pages = mysql_fetch_assoc($r_pages))
        echo '<li><em><font color="#0066FF">'.$pages['titre_fr'].'/'.$pages['titre_en'].'</font></em></a><form method="post" action="modifpages.php" ><input type="image" src="images.jpg" title="Modifier"/><input type="hidden" name="pages" value="'.$pages['id'].'" /></form></li>'; // formulaire permettant l'accès à la page de modification des pages par l'intermédiaire de l'icone modifier
        echo $fin.'</div>';
    </div>
    </body>
    </html>
    <?php mysql_close();?>
    Voici l'index.php
    <?php
    include('head.php');?>
    <img src="images/interface_08.jpg" width="760" height="800" alt="">
    <?php include('foot.php');?>
    Mon maitre de stage me demande de faire ça seulement je n'ai jamais fait quelque chose de ce genre. Merci de votre aide !
    Avatar de Vil'Coyote
    Développeur adélia & Web
    Février 2008
    Activité : Développeur adélia & Web
    pourrais tu expliciter un peu plus ta demande stp car c'est pas très clair.
    tu souhaites mettre quoi dans quoi?
    la vie n'est pas cirrhose des foies ...
    Avant de poster un message Rechercher n'est pas qu'une option.
    FAQ Web - Tuto Web
    Mai 2009
    Je souhaite que la page en php ait le design créé par le fichier index. Je m'exprime mal peut être. J'ai 3 fichiers, head, index et foot.php qui sont les scripts pour l'interface graphique du site. Et je dois intégrer cette interface( donc les fichiers je crois) dans mon code php !
    Février 2008
    salut,
    il faut savoir ce que fait ton code. s'il ne sert qu'a l'affichage de données il va falloir que tu intègre ton code à ses page et non l'inverse.
    si je comprend bien les page à inclure ne le sont que pour le design?
    et une question con,
    c'est le design à intégrer? si oui est t il possible de nous le montrer car j'ai peur qu'il ne te faille l'adapter (découpage, insertion dans le css, etc ...)
    FAQ Web - Tuto Web
  1. Réponses: 6
    Dernier message: 19/07/2006, 13h48
  2. [SQL] erreur dans la requette SQL ou dans le code PHP
    Par jack_1981 dans le forum PHP & Base de données
    Réponses: 19
    Dernier message: 11/07/2006, 21h21
  3. Erreur dans mon code PHP
    Par jack_1981 dans le forum Langage
    Dernier message: 12/05/2006, 10h01
  4. [PHP-JS] Probleme de javascript dans un code php
    Par stomerfull dans le forum Langage
    Dernier message: 23/01/2006, 09h33
  5. [PHP-JS] Probleme de javascript dans un code php
    Réponses: 20
    Dernier message: 12/01/2006, 13h41
