Bug manque maille
    Octobre 2005
    Par défaut Bug manque maille
    119
    120
    121
    122
    123
    124
    125
    126
    127
    128
    129
    130
    131
    132
    133
    134
    135
    136
    137
    138
    139
    private int[] ids = new int[3];
    int num_vertices_all=12;
    public void init(GLDrawable drawable) {
    	GL gl = drawable.getGL();
    	GLU glu = drawable.getGLU();
    	gl.glClearColor(0.0f, 0.0f, 0.0f, 0.0f); // Black Background
    	gl.glEnable(GL.GL_DOUBLEBUFFER);
    	gl.glEnable(GL.GL_DEPTH);
    	int status = 0;
    	//creation des points
    	float []colors = new float[33];
    	double []pts = new double[33];
    	int []indices = new int[20];
    	num_vertices_all=4;
    	pts[0] = 0; pts[1] = 0;  pts[2] = 0;
    	pts[3] = 0 ; pts[4] = 10;pts[5] = 0;
    	pts[6] = 0 ; pts[7] = 20;pts[8] = 0;
    	pts[9] = 10 ; pts[10] = 0;pts[11] = 0;
    	pts[12] = 10 ; pts[13] = 10;pts[14] = 0;
    	pts[15] = 10 ; pts[16] = 20;pts[17] = 0;
    	pts[18] = 20 ; pts[19] = 0;pts[20] = 0;
    	pts[21] = 20 ; pts[22] = 10;pts[23] = 0;
    	pts[24] = 30 ; pts[25] = 20;pts[26] = 0;
    	pts[27] = 30 ; pts[28] = 20;pts[29] = 0;
    	pts[30] = 30 ; pts[31] = 20;pts[32] = 0;
    	colors[0] = 0; colors[1] = 1; colors[2] = 0;
    	colors[3] = 0; colors[4] = 1; colors[5] = 0;
    	colors[6] = 0; colors[7] = 1; colors[8] = 0;
    	colors[9] = 0; colors[10] = 0; colors[11] = 1;
    	colors[12] = 0; colors[13] = 0; colors[14] = 1;
    	colors[15] = 0; colors[16] = 0; colors[17] = 1;
    	colors[18] = 0; colors[19] = 1; colors[10] = 1;
    	colors[21] = 0; colors[22] = 1; colors[23] = 1;
    	colors[24] = 0; colors[25] = 0; colors[26] = 1;
    	colors[27] = 1; colors[28] = 0; colors[29] = 1;
    	colors[30] = 1; colors[31] = 0; colors[32] = 1;
    	indices[0] = 0; indices[1] =3;
    	indices[2] = 1; indices[3] =4;
    	indices[4] = 2; indices[5] =5;
    	indices[6] = 5; indices[7] =8;
    	indices[8] = 4; indices[9] =7;
    	indices[10] = 3; indices[11] =6;
    	indices[12] = 6; indices[13] =9;
    	indices[14] = 6; indices[15] =9;
    	indices[16] = 7; indices[17] =10;
    	indices[18] = 8; indices[19] =11;
    	int nbPts = 12;
    	num_vertices_all=20;
    	IntBuffer indicesBuffer = BufferUtils.newIntBuffer(num_vertices_all);
    	FloatBuffer colorsBuffer = BufferUtils.newFloatBuffer(nbPts*3);
    	DoubleBuffer ptsBuffer = BufferUtils.newDoubleBuffer(nbPts*3);
    	indicesBuffer.put(indices);
    	colorsBuffer.put(colors);
    	ptsBuffer.put(pts);
    	gl.glGenBuffersARB( 3, ids );
    	gl.glBindBufferARB( GL.GL_ARRAY_BUFFER_ARB, ids[0] ); // Bind The Buffer
    	gl.glBufferDataARB( GL.GL_ARRAY_BUFFER_ARB,
    			    nbPts*3*BufferUtils.SIZEOF_DOUBLE,
    			    ptsBuffer, GL.GL_STATIC_DRAW_ARB );
    	gl.glBindBufferARB( GL.GL_ARRAY_BUFFER_ARB, ids[1] ); // Bind The Buffer
    			    nbPts*3*BufferUtils.SIZEOF_FLOAT,
    			    colorsBuffer, GL.GL_STATIC_DRAW_ARB );
    	gl.glBindBufferARB(GL.GL_ARRAY_BUFFER_ARB, ids[2]); // Bind The Buffer
    	gl.glBufferDataARB(GL.GL_ARRAY_BUFFER_ARB,
    			   num_vertices_all * BufferUtils.SIZEOF_INT,
    			   indicesBuffer, GL.GL_STATIC_DRAW_ARB);
    	//lecture des infos sur la carte
    	System.err.println("GL_VENDOR: " + gl.glGetString(GL.GL_VENDOR));
    	System.err.println("GL_RENDERER: " + gl.glGetString(GL.GL_RENDERER));
    	System.err.println("GL_VERSION: " + gl.glGetString(GL.GL_VERSION));
    	canvas.setAutoSwapBufferMode(false);
    public boolean display(GLDrawable drawable) {
    	gl.glMatrixMode(GL.GL_MODELVIEW);
    	gl.glLoadIdentity();
    	float trans = 0;
    	gl.glMatrixMode(GL.GL_PROJECTION);
    	glu.gluPerspective(30, this.width / this.height, 1, 9000000);
    	gl.glViewport(0, 0, width, height);
    	gl.glClearColor(1f, 0, 0, 0);
    	gl.glDisable(GL.GL_LIGHTING);
    	gl.glDisable(GL.GL_BLEND);
    	gl.glClear(GL.GL_COLOR_BUFFER_BIT | GL.GL_DEPTH_BUFFER_BIT);
    	gl.glEnable(gl.GL_CULL_FACE);
    	gl.glEnable(GL.GL_DEPTH_TEST);
    	gl.glColor3f(0,1,0);
    	gl.glEnableClientState (GL.GL_VERTEX_ARRAY);
    	gl.glEnableClientState (GL.GL_COLOR_ARRAY);
    	gl.glEnableClientState (GL.GL_INDEX_ARRAY);
    	gl.glVertexPointer( 3, GL.GL_DOUBLE, 0, (Buffer) null  );
    	gl.glColorPointer( 3, GL.GL_FLOAT, 0, (Buffer) null  );
    	gl.glBindBufferARB( GL.GL_ARRAY_BUFFER_ARB, ids[2] );
    	gl.glIndexPointer(2, GL.GL_INT, (Buffer) null  );
    	gl.glDrawArrays (GL.GL_TRIANGLE_STRIP, 0, num_vertices_all);
    	gl.glDisableClientState(GL.GL_VERTEX_ARRAY);
    	gl.glDisableClientState(GL.GL_COLOR_ARRAY);
    	gl.glDisableClientState(GL.GL_INDEX_ARRAY);
    	gl.glFlush ();
    	return true;
    Je ne vois pas tous mes points maillés. Est ce que quelqu'un peut me dire pourquoi ?
    Avatar de shenron666
    avancé
    Avril 2005
    Activité : avancé
    Tu veux dire que tu as des polygones qui ne s'affichent pas ?
    c'est peut-etre un problème dans l'ordre de tes indices ?
    Tutoriels OpenGL
    Avatar de bafman
    Novembre 2003
    mmm la ca me parrais bizzar..
    normalement le double buffering s'initialise ala creation de la fenetre, pareil pour le depth buffer, et sinon pour activer le depth test c'est
    Mes articles
  1. Synthèse des manques/bugs de BIRT
    Par erwan.bodere dans le forum BIRT
    Dernier message: 28/04/2009, 09h01
  2. Urgent - bug - NTLDR manque
    Par Perludix dans le forum Windows XP
    Dernier message: 14/04/2007, 13h46
