Problème affichage de texture.
    Mars 2008
    Par défaut Problème affichage de texture.
    Voila j'essaye de faire un cube avec des texture dessus. J'arrive à charger l'image avec la librairie SDL. Mais apres la texture est pas joli elle ne représente pas l'image.
    Mes codes :
    main.cpp
    using namespace std;
    #include <stdlib.h>
    #include <math.h>
    #include <unistd.h>
    #include <GL/glew.h>
    #include <GL/gl.h>
    #include <GL/glu.h>
    #include <GL/glut.h>
    #include "scene.hpp"
    #define ESCAPE 27
    // La scene
    Scene s;
    // La fenetre
    int _win;
    int _win_width;
    int _win_height;
    // Prototype glut
    void Rechape (int Width, int Height);
    void Display ();
    void Keyboard (unsigned char key, int x, int y);
      // Initialisation fenetre
      glutInit(&argc, argv);
      glutInitDisplayMode(GLUT_RGBA | GLUT_DOUBLE | GLUT_ALPHA | GLUT_DEPTH);
      glutInitWindowSize(640, 480);
      glutInitWindowPosition(50, 50);
      _win = glutCreateWindow("SIA Project - FERY MORI");
      glutFullScreen();
      // Initialisation evenement
      glutDisplayFunc(&Display);
      glutIdleFunc(&Display);
      glutReshapeFunc(&Rechape);
      glutKeyboardFunc(&Keyboard);
      // OpenGL - Boucle
      glClearColor(0.0f, 0.0f, 0.0f, 0.0f);
      glClearDepth(1.0);
      glDepthFunc(GL_LESS);
      glEnable(GL_DEPTH_TEST);
      glShadeModel(GL_SMOOTH);
      glMatrixMode(GL_PROJECTION);
      glLoadIdentity();
      gluPerspective(45.0f,(GLfloat)_win_width/(GLfloat)_win_height,0.1f,100.0f);
      glMatrixMode(GL_MODELVIEW);
      s.init();
      glutMainLoop();
      return 1;
      Evenement :
    void Rechape (int Width, int Height) {
      if (Height==0)
        Height=1;
      glViewport(0, 0, Width, Height);
      glLoadIdentity();
      gluPerspective(45.0f,(GLfloat)Width/(GLfloat)Height,0.1f,100.0f);
    void Display () {
      glClearColor(175,151,124,0);
      glLoadIdentity();
      glTranslatef(-1.5f,0.0f,-6.0f);
      s.draw();
        Dessin de la scene
      glutSwapBuffers();
    void Keyboard (unsigned char key, int x, int y) {
        if (key == ESCAPE) {
    	glutDestroyWindow(_win);
    	exit(0);
    scene.hpp
    #ifndef SCENE_HPP
    #define SCENE_HPP
    #include "caisse.hpp"
    class Scene {
    public:
      void init ();
      void draw ();
    private:
      Caisse caisse;
    #endif /* SCENE_HPP */
    caisse.hpp
    #ifndef CAISSE_HPP
    #define CAISSE_HPP
    #include <GL/gl.h>
    #include <GL/glu.h>
    class Caisse {
    public:
      void set ();
      void draw ();
    private:
      GLuint _id;
    #endif /* CAISSE_HPP */
    scene.cpp
    #include <GL/gl.h>
    #include <GL/glu.h>
    #include <SDL/SDL.h>
    #include <SDL/SDL_image.h>
    #include <unistd.h>
    #include <stdio.h>
    #include <stdlib.h>
    #include <iostream>
    void Scene::init () {
      caisse.set();
    void Scene::draw () {
      caisse.draw();
    caisse.cpp
    #include <GL/gl.h>
    #include <GL/glu.h>
    void Caisse::set() {
      SDL_Surface *texture;
      glGenTextures(1,&_id);
      texture = IMG_Load ("../texture/caisse_bois.tga");
      glBindTexture (GL_TEXTURE_2D, _id);
      glTexParameteri (GL_TEXTURE_2D, GL_TEXTURE_WRAP_S,GL_CLAMP_TO_EDGE);
      glTexParameteri (GL_TEXTURE_2D, GL_TEXTURE_WRAP_T,GL_CLAMP_TO_EDGE);
      glTexParameteri (GL_TEXTURE_2D, GL_TEXTURE_MAG_FILTER, GL_LINEAR);
      glTexParameteri (GL_TEXTURE_2D, GL_TEXTURE_MIN_FILTER, GL_LINEAR);
      glTexEnvf (GL_TEXTURE_ENV, GL_TEXTURE_ENV_MODE, GL_MODULATE);
      glTexImage2D (GL_TEXTURE_2D, 0, GL_RGBA8, texture->w, texture->h, 0, GL_RGBA, GL_UNSIGNED_BYTE, texture->pixels);
    void Caisse::draw() {
      glActiveTexture(GL_TEXTURE0);
      glEnable(GL_TEXTURE_2D);
      glTexEnvf(GL_TEXTURE_ENV,GL_TEXTURE_ENV_MODE,GL_REPLACE);
      glBindTexture(GL_TEXTURE_2D, _id);
      glBegin(GL_QUADS);
      // Front Face
      glTexCoord2f(0.0f, 0.0f); glVertex3f(-1.0f, -1.0f,  1.0f);    // Bottom Left Of The Texture and Quad
      glTexCoord2f(1.0f, 0.0f); glVertex3f( 1.0f, -1.0f,  1.0f);	// Bottom Right Of The Texture and Quad
      glTexCoord2f(1.0f, 1.0f); glVertex3f( 1.0f,  1.0f,  1.0f);	// Top Right Of The Texture and Quad
      glTexCoord2f(0.0f, 1.0f); glVertex3f(-1.0f,  1.0f,  1.0f);	// Top Left Of The Texture and Quad
      // Back Face
      glTexCoord2f(1.0f, 0.0f); glVertex3f(-1.0f, -1.0f, -1.0f);	// Bottom Right Of The Texture and Quad
      glTexCoord2f(1.0f, 1.0f); glVertex3f(-1.0f,  1.0f, -1.0f);	// Top Right Of The Texture and Quad
      glTexCoord2f(0.0f, 1.0f); glVertex3f( 1.0f,  1.0f, -1.0f);	// Top Left Of The Texture and Quad
      glTexCoord2f(0.0f, 0.0f); glVertex3f( 1.0f, -1.0f, -1.0f);	// Bottom Left Of The Texture and Quad
      // Top Face
      glTexCoord2f(0.0f, 1.0f); glVertex3f(-1.0f,  1.0f, -1.0f);	// Top Left Of The Texture and Quad
      glTexCoord2f(0.0f, 0.0f); glVertex3f(-1.0f,  1.0f,  1.0f);	// Bottom Left Of The Texture and Quad
      glTexCoord2f(1.0f, 0.0f); glVertex3f( 1.0f,  1.0f,  1.0f);	// Bottom Right Of The Texture and Quad
      glTexCoord2f(1.0f, 1.0f); glVertex3f( 1.0f,  1.0f, -1.0f);	// Top Right Of The Texture and Quad
      // Bottom Face
      glTexCoord2f(1.0f, 1.0f); glVertex3f(-1.0f, -1.0f, -1.0f);	// Top Right Of The Texture and Quad
      glTexCoord2f(0.0f, 1.0f); glVertex3f( 1.0f, -1.0f, -1.0f);	// Top Left Of The Texture and Quad
      glTexCoord2f(0.0f, 0.0f); glVertex3f( 1.0f, -1.0f,  1.0f);	// Bottom Left Of The Texture and Quad
      glTexCoord2f(1.0f, 0.0f); glVertex3f(-1.0f, -1.0f,  1.0f);	// Bottom Right Of The Texture and Quad
      // Right face
      glTexCoord2f(1.0f, 0.0f); glVertex3f( 1.0f, -1.0f, -1.0f);	// Bottom Right Of The Texture and Quad
      glTexCoord2f(0.0f, 1.0f); glVertex3f( 1.0f,  1.0f,  1.0f);	// Top Left Of The Texture and Quad
      // Left Face
      glTexCoord2f(0.0f, 0.0f); glVertex3f(-1.0f, -1.0f, -1.0f);	// Bottom Left Of The Texture and Quad
      glTexCoord2f(1.0f, 1.0f); glVertex3f(-1.0f,  1.0f,  1.0f);	// Top Right Of The Texture and Quad
      glEnd();
    Donc voila je sais pas pourquoi la texture ne couvre pas la totalité de mon cube et pourquoi l'image est moche et déformée comme ca.
    Si quelqu'un à la solution je le remercie d'avance je vais quand meme continué de chercher.
    Merci d'avance.
    Janvier 2007
    Essayes d'activer le depth test avant de plaquer tes textures.
    Mars 2008
    J'ai essayé
      glBegin(GL_QUADS);
      // Front Face
    Mais meme problème je commence à desepérer.
    Décembre 2004
    salut
    le glTexEnvf(GL_TEXTURE_ENV,GL_TEXTURE_ENV_MODE,GL_MODULATE);
    il est censé te servir à quoi ?
    il se passe quoi si tu l'enlèves ?
    Avatar de shenron666
    avancé
    Avril 2005
    Activité : avancé
    vu la capture, ce n'est visiblement pas un problème dans ton code mais plus lié au chargement de ta texture
    ta texture au format TGA, tu es certain qu'elle comporte bien 4 échantillons ?
    Tutoriels OpenGL
    Décembre 2004
    grace à toi je sais à quoi sert glTexEnv maintenant
    effectivement l'erreur c'est
    à remplacer par
    glTexImage2D (GL_TEXTURE_2D, 0, GL_RGBA8, texture->w, texture->h, 0, GL_RGB, GL_UNSIGNED_BYTE, texture->pixels);
    ou
    glTexImage2D (GL_TEXTURE_2D, 0, GL_RGBA8, texture->w, texture->h, 0, GL_BGR, GL_UNSIGNED_BYTE, texture->pixels);
    avancé
    Avril 2005
    Activité : avancé
    ha mais il ne faut pas donner toutes les réponses comme ça d'un coup
    il faut le laisser chercher un peu
    Tutoriels OpenGL
  1. Problème d'affichage de texture.
    Par kokarez dans le forum DirectX
    Dernier message: 08/12/2009, 10h57
  2. [Débutant][OpenGL ES] Problème affichage textures
    Par Niicoo dans le forum OpenGL
    Dernier message: 12/06/2009, 16h15
  3. Réponses: 10
    Dernier message: 08/06/2009, 12h30
  4. [VBO] Problème d'affichage de texture
    Par Lung dans le forum OpenGL
    Dernier message: 22/04/2009, 09h16
  5. [OpenSceneGraph] Problème affichage de texture
    Par PP(Team) dans le forum OpenSceneGraph
    Dernier message: 23/01/2007, 17h35
