[Info] Algorithme de Mandelbrot en sql
    Développeur et DBA Oracle
    Octobre 2006
    Activité : Développeur et DBA Oracle
    Par défaut [Info] Algorithme de Mandelbrot en sql
    J'ai trouvé un post qui traite l'algorithme Mandelbrot sur OTN.
    Algorithme de Mandelbrot.
    For each pixel on the screen do:
      x = x0 = x co-ordinate of pixel
      y = y0 = y co-ordinate of pixel
      iteration = 0
      max_iteration = 1000
      while ( x*x + y*y <= (2*2)  AND  iteration < max_iteration )
        xtemp = x*x - y*y + x0
        y = 2*x*y + y0
        x = xtemp
        iteration = iteration + 1
      if ( iteration == max_iteration )
      then
        color = black
      else
        color = iteration
      plot(x0,y0,color)
    SQL> set linesize 150
    SQL> set pagesize 110
    SQL> with ord as (SELECT M xyz  FROM DUAL MODEL  DIMENSION BY (0 P) MEASURES( 0 M) (M[FOR P FROM 0 T
    O 99 INCREMENT 1 ]=CV(P)))
      2  , xgen as (
      3    select -2.2 + xyz*0.031 cx, xyz ix
      4      from ord)
      5  , ygen as (
      6    select -1.5 + xyz*0.031 cy, xyz iy
      7      from ord)
      8  , z as (
      9    select ix, iy, i
     10      from xgen, ygen
     11     model partition by (ix, iy)
     12           dimension by (0 i)
     13           measures (cx, cy
     14                   , cx x
     15                   , cy y
     16           )
     17           ignore nav
     18           rules iterate (100)
     19                   until (X[iteration_number] * X[iteration_number] +
     20                          Y[iteration_number] * Y[iteration_number] > 16) (
     21             cx[iteration_number] = cx[cv()]+cx[cv()-1]
     22           , cy[iteration_number] = cy[cv()]+cy[cv()-1]
     23           , x[iteration_number] = cx[cv()]+x[cv()-1]*x[cv()-1]-y[cv()-1]*y[cv()-1]
     24           , y[iteration_number] = cy[cv()]+y[cv()-1]*x[cv()-1]*2
     25           )
     26  )
     27  select replace(ltrim(max(sys_connect_by_path(i,'|')) keep (dense_rank last partition by ix),'|'
     28     from (select ix, iy, substr(' .,,,-----++++%%%%@@@@### ',least(max(i),26),1) i from z group
    by ix, iy)
     29            connect by iy = prior iy and ix = prior ix + 1
     30            start with ix = 1
     31            group by iy;
    <div style="margin-left:40px">
    REPLACE(LTRIM(MAX(SYS_CONNECT_BY_PATH(I,'|'))KEEP(DENSE_RANKLASTPARTITIONBYIX),'|'),'|')
    100 rows selected.
    SQL>
    SQL></div>
    Avatar de Waldar
    Pour obtenir le résultat avec TOAD 9.6 (je ne sais pas si ça joue) sur Oracle (11.1.0.6) j'ai du utiliser deux "ord" différents, sinon j'étais bloqué à ix = 0.
    WITH
        ord1 AS
        MODEL
            DIMENSION BY (0 P)
            MEASURES( 0 M)
            (M[FOR P FROM 0 TO 99 INCREMENT 1 ]=CV(P))),
        xgen AS (SELECT -2.2 + xyz*0.031 cx, xyz ix FROM ord1),
        ord2 AS
        MODEL
            DIMENSION BY (0 P)
            MEASURES( 0 M)
        ygen AS (SELECT -1.5 + xyz*0.031 cy, xyz iy FROM ord2),
        z AS
        SELECT ix, iy, i
        FROM xgen, ygen
        model
          partition BY (ix, iy)
          dimension BY (0 i)
          measures (cx, cy, cx x, cy y)
          IGNORE nav
          rules iterate (100)
          until (X[iteration_number] * X[iteration_number] + Y[iteration_number] * Y[iteration_number] > 16)
              cx[iteration_number] = cx[cv()]+cx[cv()-1],
              cy[iteration_number] = cy[cv()]+cy[cv()-1],
              x[iteration_number] = cx[cv()]+x[cv()-1]*x[cv()-1]-y[cv()-1]*y[cv()-1],
    SELECT
        REPLACE(ltrim(max(sys_connect_by_path(i,'|')) keep (dense_rank last partition BY ix),'|'),'|') aff
    FROM
        (SELECT ix, iy,
        FROM z GROUP BY ix, iy)
    CONNECT BY iy = PRIOR iy AND ix = PRIOR ix + 1
    START WITH ix = 1
    GROUP BY iy
    Octobre 2006
    À la maison marche bien mais au travail non (toad 9.0.1).
    Essaie ça
        ord AS
        (select rownum-1 xyz from dual connect by rownum<=100 ),
        xgen AS (SELECT -2.2 + xyz*0.031 cx, xyz ix FROM ord),
        ygen AS (SELECT -1.5 + xyz*0.031 cy, xyz iy FROM ord),
        z AS
        SELECT ix, iy, i
        FROM xgen, ygen
        model
          dimension BY (0 i)
          IGNORE nav
          rules iterate (100)
    SELECT
    FROM
        (SELECT ix, iy,
    START WITH ix = 1
    GROUP BY iy
    Avatar de Waldar
    Vous devez avoir le même problème que moi, essayez avec ord1 et ord2 (qui sont similaires), le premier pour alimenter xgen, le second pour alimenter ygen.
    Avatar de orafrance
    Janvier 2004
    Excusez-moi de casser l'ambiance mais... à quoi ça sert ?
    Ignare inside
    Octobre 2006
    Oui je l'ai essayé avec ta solution est ça marché.
    as tu essayé la solution avec le connect by ?
    Octobre 2006
    Citation Envoyé par orafrance Voir le message
    Ignare inside
    http://fr.wikipedia.org/wiki/Ensemble_de_Mandelbrot
    Pour moi, c'est juste de maitriser mieux la clause Model.
    Avatar de Waldar
    Citation Envoyé par salim11 Voir le message
    As tu essayé la solution avec le connect by ?
    J'avais lu un peu vite ! Ca fonctionne très bien avec le connect by.
  1. Algorithme de dijkstra sur SQL Server pour placement optimal
    Par SQL_EVAN dans le forum Contribuez
    Dernier message: 17/06/2013, 17h20
  2. [Débutant] Récupérer des infos à partir d'une requete sql
    Par Jeje9 dans le forum C#
    Dernier message: 29/02/2012, 22h12
  3. info sur la vue v$sql
    Par mongolic dans le forum Administration
    Dernier message: 11/10/2009, 15h57
  4. Réponses: 2
    Dernier message: 25/05/2009, 16h53
  5. [MySQL] Comparer des info date dans une requete SQL
    Par kaygee dans le forum PHP & Base de données
    Dernier message: 06/01/2006, 22h56
