[openGL] Ombrage de Gouraud
    grmi91
    Par défaut [openGL] Ombrage de Gouraud
    Je viens de faire l'ombrage plat sur un cube et je souhaiterais faire un ombrage de Gouraud en openGL.
    code de l'ombrage plat :
    Code :
    #define ESCAPE 27
    GLfloat light_position[] = { 1.0F,0.0F,1.0F,0.0F };
    GLfloat lightambiant[] = { 1.0f,1.0f,1.0f,0.0};
    int window;
    void InitGL(int Width, int Height)
    	glClearColor(0.0f, 0.0f, 0.0f, 0.0f);
    	glClearDepth(1.0);
    	glDepthFunc(GL_LESS);
    	glEnable(GL_DEPTH_TEST);
    	glEnable(GL_LIGHTING);
    	glEnable(GL_LIGHT0);
    	glLightfv(GL_LIGHT0,GL_POSITION,light_position);
    	glLightfv(GL_LIGHT0,GL_AMBIENT,lightambiant);
    	/* model d'ombrage */
    	glShadeModel(GL_SMOOTH);		//GL_FLAT = ombrage plat; GL_SMOOTH = ombrage de Gouraud (degradé)
    	glMatrixMode(GL_PROJECTION);
    	glLoadIdentity();
    	gluPerspective(45.0f,(GLfloat)Width/(GLfloat)Height,0.1f,100.0f);
    	glMatrixMode(GL_MODELVIEW);
    void ReSizeGLScene(int Width, int Height)
    void DrawGLScene()
      	glLoadIdentity();
    	glLoadIdentity();
    	gluLookAt(8.0,6.0,4.0,0.0,0.0,0.0,0.0,1.0,0.0);
                 * Cube avec ombrage plat *
                 //dessin cube en donner les 4 sommets et la normale des 6 faces
      	     glBegin (GL_QUADS);
    		// face 1
    		glNormal3f (0.0f,0.0f,1.0f);
    		glVertex3i(1,1,1);
    		glVertex3i(1,-1,1);
    		glVertex3i(-1,-1,1);
    		glVertex3i(-1,1,1);
                    //face2
    		glNormal3f (0.0f,0.0f,-1.0f);
    		glVertex3i(1,1,-1);
    		glVertex3i(1,-1,-1);
    		glVertex3i(-1,-1,-1);
    		glVertex3i(-1,1,-1);
    	             // face3
    	             glNormal3f (1.0f,0.0f,0.0f);
    		glVertex3i(1,1,1);
    		glVertex3i(1,-1,1);
    		glVertex3i(1,1,-1);
    	             // face4
    		glNormal3f (-1.0f,0.0f,0.0f);
    		glVertex3i(-1,1,1);
    	   // face5
    		glNormal3f (0.0f,1.0f,0.0f);
    		glVertex3i(-1,1,1);
    		glVertex3i(1,1,1);
    		glVertex3i(1,1,-1);
    	   // face6
    		glNormal3f (0.0f,-1.0f,0.0f);
    		glVertex3i(1,-1,1);
    	glEnd ();
    	glutSwapBuffers();
    void keyPressed(unsigned char key, int x, int y)
    int main(int argc, char **argv)
    Donc si quelqu'un pouvait m'aider pour l'ombrage de Gouraud ce serait sympa.
    Février 2008
    deux problèmes dans ton code:
    1. Tu ne définis pas tous les paramètres de la lumière. La composante diffuse est importante par exemple
    2. Tu ne définis pas de "matériau" pour les vertex de ton cube. Un matériau est comme une couleur, mais est séparé en plusieurs composantes, ambiante, diffuse, speculaire, etc.... Comme les lumières donc, et ca tombe bien car c'est avec les lumières que ca s'utilise.
    Si vraiment tu ne veux pas définir de matériau, tu peux laisser opengl les calculer tout seul à partir d'une couleur (glColor3f(0,1,0) opar exemple) si tu active auparavant GL_COLOR_MATERIAL (glEnable(GL_COLOR_MATERIAL))
  1. [openGL] Ombrage de Gouraud
    Par grmi91 dans le forum Windows
    Dernier message: 11/03/2008, 19h15
  2. Directx ou opengl
    Par scorpiwolf dans le forum DirectX
    Réponses: 13
    Dernier message: 07/02/2003, 09h29
  3. OpenGL et *.3ds
    Par tintin22 dans le forum OpenGL
    Dernier message: 06/05/2002, 14h51
  4. OpenGL ou DirectX
    Par Nadir dans le forum DirectX
    Dernier message: 02/05/2002, 13h48
  5. Opengl -- Les surfaces
    Par Anonymous dans le forum OpenGL
    Dernier message: 02/05/2002, 11h14
