Problème texture SDL
    Mars 2006
    Par défaut Problème texture SDL
    Malgré toutes mes tentatives et les différents formats de fichiers utilisés j'arrive toujours pas à voir ma texture appliqué sur mon petit cube, j'espère que vous allez pouvoir m'aider
    Initialisions:
    #include <SDL/SDL.h>
    #include <SDL/SDL_image.h>
    #include <GL/gl.h>
    #include <GL/glu.h>
    void Dessiner();
    double angleY = 0;
    double angleX = 0;
    GLuint texture;
    SDL_Surface *image;
    Main:
    int main(int argc, char *argv[])
    SDL_Event event;
    SDL_Init(SDL_INIT_VIDEO);
    atexit(SDL_Quit);
    SDL_WM_SetCaption("Mon premier programme OPENGL SDL", NULL);
    SDL_SetVideoMode(640, 480, 32, SDL_OPENGL);
    image=SDL_LoadBMP("cube.bmp");
    glGenTextures(1,&texture);
    glTexImage2D(GL_TEXTURE_2D,0,3, image->w,image->h,0,GL_RGB, GL_UNSIGNED_BYTE,image->pixels);
    glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_MIN_FILTER, GL_NEAREST);
    glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_MAG_FILTER, GL_NEAREST);
    glMatrixMode( GL_PROJECTION );
    glLoadIdentity();
    gluPerspective(70,(double)640/480,1,1000);
    glEnable(GL_DEPTH_TEST);
    glEnable(GL_TEXTURE_2D);
    Dessiner();
    Uint32 last_time = SDL_GetTicks();
    Uint32 current_time,ellapsed_time;
    Uint32 start_time;
    for (;
    start_time = SDL_GetTicks();
    while (SDL_PollEvent(&event))
    switch(event.type)
    case SDL_QUIT:
    exit(0);
    break;
    current_time = SDL_GetTicks();
    ellapsed_time = current_time - last_time;
    last_time = current_time;
    angleY += 0.05 * ellapsed_time;
    angleX += 0.05 * ellapsed_time;
    Dessiner();
    ellapsed_time = SDL_GetTicks() - start_time;
    if (ellapsed_time < 10)
    SDL_Delay(10 - ellapsed_time);
    return 0;
    Et enfin la fonction qui dessine:
    void Dessiner()
    glClear( GL_COLOR_BUFFER_BIT | GL_DEPTH_BUFFER_BIT );
    glBindTexture(GL_TEXTURE_2D,texture);
    glMatrixMode( GL_MODELVIEW );
    glLoadIdentity( );
    gluLookAt(0,0,5,0,0,0,0,1,0);
    glRotated(angleY,0,0,1);
    glRotated(angleX,1,0,0);
    glBegin(GL_QUADS);
    glColor3ub(255,0,0); //face rouge
    glTexCoord2f(0,0);glVertex3d(-1,-1,-1);
    glTexCoord2f(1,0);glVertex3d(1,-1,-1);
    glTexCoord2f(1,1);glVertex3d(1,1,-1);
    glTexCoord2f(0,1);glVertex3d(-1,1,-1);
    glColor3ub(0,255,0); //face verte
    glVertex3d(1,1,-1);
    glVertex3d(1,-1,1);
    glVertex3d(1,1,1);
    glColor3ub(0,0,255); //face bleue
    glVertex3d(-1,-1,1);
    glVertex3d(1,-1,1);
    glVertex3d(1,1,1);
    glVertex3d(-1,1,1);
    glColor3ub(255,255,0); //face jaune
    glVertex3d(-1,1,1);
    glColor3ub(0,255,255); //face cyan
    glVertex3d(1,1,-1);
    glVertex3d(1,1,1);
    glVertex3d(-1,1,1);
    glColor3ub(255,0,255); //face magenta
    glVertex3d(1,-1,1);
    glEnd();
    glFlush();
    SDL_GL_SwapBuffers();
    La programme tourne très bien, mais malheureusement pas de texture sur la face route.
    Avatar de bafman
    Novembre 2003
    il faut faire un glBindTexture entre le glGenTexture et le glTexImage2D.
    Mes articles
    Mars 2006
    Par défaut Merci
    C'est super, ca marche!! Merci, une erreur que j'aurai eu du mal a trouvé... enfin peut être que j'y serai arrivé, si j'avais raisonné logiquement.
    Je passe aux lumières et aux ombres
  1. [XNA] Problème textures objet DirectX
    Par Gurdil dans le forum XNA/Monogame
    Dernier message: 25/05/2007, 14h37
  2. Problème de SDL, clique souris
    Par K4trix dans le forum SDL
    Dernier message: 12/07/2006, 11h58
  3. Problème fonction SDL
    Par seeme dans le forum SDL
    Dernier message: 06/11/2005, 21h22
  4. Texture SDL + OpenGL
    Par batman60 dans le forum OpenGL
    Dernier message: 17/07/2005, 15h02
  5. Petit problème avec SDL
    Par Nyarlathotep dans le forum C
    Dernier message: 01/07/2005, 10h10
