Erreur sur un MERGE [11gR2]
    Avatar de CinePhil
    Août 2006
    Par défaut Erreur sur un MERGE
    Voilà mon MERGE :
    MERGE INTO GRHUM.TYPE_POPULATION act
    USING
      SELECT C_TYPE_POPULATION, LC_TYPE_POPULATION, LL_TYPE_POPULATION, REF_REGLEMENTAIRE, TEM_FONCTIONNAIRE, TEM_ATOS, TEM_ITARF, TEM_ENS_SUP, TEM_ENSEIGNANT, TEM_2DEGRE, TEM_HOSPITALIER,
        TEM_BIBLIO, TEM_CARRIERE, D_CREATION, D_MODIFICATION, TEM_1DEGRE, TEM_VISIBLE, D_OUVERTURE, D_FERMETURE
      FROM PLEMENAGER.TYPE_POPULATION
    ) rf
    ON (act.C_TYPE_POPULATION = rf.C_TYPE_POPULATION)
    WHEN MATCHED THEN
      UPDATE
      SET act.LC_TYPE_POPULATION = rf.LC_TYPE_POPULATION,
        act.LL_TYPE_POPULATION = rf.LL_TYPE_POPULATION,
        act.REF_REGLEMENTAIRE = rf.REF_REGLEMENTAIRE,
        act.TEM_FONCTIONNAIRE = rf.TEM_FONCTIONNAIRE,
        act.TEM_ATOS = rf.TEM_ATOS,
        act.TEM_ITARF = rf.TEM_ITARF,
        act.TEM_ENS_SUP = rf.TEM_ENS_SUP,
        act.TEM_ENSEIGNANT = rf.TEM_ENSEIGNANT,
        act.TEM_2DEGRE = rf.TEM_2DEGRE,
        act.TEM_HOSPITALIER = rf.TEM_HOSPITALIER,
        act.TEM_BIBLIO = rf.TEM_BIBLIO,
        act.TEM_CARRIERE = rf.TEM_CARRIERE,
        act.D_CREATION = rf.D_CREATION,
        act.D_MODIFICATION = rf.D_MODIFICATION,
        act.TEM_1DEGRE = rf.TEM_1DEGRE,
        act.TEM_VISIBLE = rf.TEM_VISIBLE,
        act.D_OUVERTURE = rf.D_OUVERTURE,
        act.D_FERMETURE = rf.D_FERMETURE
    WHEN NOT MATCHED THEN
      INSERT (C_TYPE_POPULATION, LC_TYPE_POPULATION, LL_TYPE_POPULATION, REF_REGLEMENTAIRE, TEM_FONCTIONNAIRE, TEM_ATOS, TEM_ITARF, TEM_ENS_SUP, TEM_ENSEIGNANT, TEM_2DEGRE, TEM_HOSPITALIER,
        TEM_BIBLIO, TEM_CARRIERE, D_CREATION, D_MODIFICATION, TEM_1DEGRE, TEM_VISIBLE, D_OUVERTURE, D_FERMETURE)
      VALUES (rf.C_TYPE_POPULATION, rf.LC_TYPE_POPULATION, rf.LL_TYPE_POPULATION, rf.REF_REGLEMENTAIRE, rf.TEM_FONCTIONNAIRE, rf.TEM_ATOS, rf.TEM_ITARF, rf.TEM_ENS_SUP, rf.TEM_ENSEIGNANT, rf.TEM_2DEGRE, rf.TEM_HOSPITALIER,
        rf.TEM_BIBLIO, rf.TEM_CARRIERE, rf.D_CREATION, rf.D_MODIFICATION, rf.TEM_1DEGRE, rf.TEM_VISIBLE, rf.D_OUVERTURE, rf.D_FERMETURE);
    SQL Developer m'affiche, à chaque fois, quelques secondes après avoir lancé la requête, une boîte d'erreur titrée "Reconnexion" :
    La base de données a été réinitialisée. L'ensemble des états de session ou transactions en attente est perdu.
    La sortie de script me dit ceci :
    Erreur à la ligne de commande: 1 Colonne: 1
    Rapport d'erreur -
    Erreur SQL : ORA-00600: code d'erreur interne, arguments : [13013], [5001], [55222], [25173079], [59], [25173079], [17], [], [], [], [], []
    00600. 00000 - "internal error code, arguments: [%s], [%s], [%s], [%s], [%s], [%s], [%s], [%s], [%s], [%s], [%s], [%s]"
    *Cause: This is the generic internal error number for Oracle program
    exceptions. It indicates that a process has encountered a low-level,
    unexpected condition. The first argument is the internal message
    number. This argument and the database version number are critical in
    identifying the root cause and the potential impact to your system.
    Qu'est-ce qui se passe ?
    Je précise que les deux tables font seulement 31 lignes. En principe, un UPDATE suffirait mais je fais ça aussi à titre d'exercice et j'aurai ensuite des tables plus complexes à fusionner.
    Décembre 2002
    Sur Metalink, diverses bogues sont référencées avec ces codes d'erreur, et impliquant un MERGE.
    Vous pourrez les trouver à partir de l'assistant de recherche ORA-600 figurant dans la note 153788.1.
    Octobre 2007
    Juste pour ma curiosité: les entités source et destination du Merge sont bien des tables ou des vues ? Avec des policies ou rien de spécial. La colonne de jointure est-elle bien du même dans les mêmes entités ? Y-a-t-il des triggers positionnés sur la table/vue destination ou des vues matérialisées sont ils impliquées ?
    Merci pour vos précision.
    Avatar de CinePhil
    Août 2006
    Comme j'avais eu aussi une boîte d'erreur similaire sur autre chose plus simple ce matin, j'ai relancé SQL Developer et je viens d'essayer mon MERGE de nouveau... avec le même résultat, hélas !
    Citation Envoyé par mnitu
    Ce sont deux tables identiques. L'idée est de mettre à jour la table du schéma GRHUM avec la table de référence que j'ai mise dans mon schéma PLEMENAGER. Dans ce cas précis, je pourrais simplement remplacer la table par sa référence mais je préfèrerais utiliser le MERGE à titre formateur pour moi et en vue d'opérations plus délicates sur d'autres tables où le remplacement ne sera pas une solution envisageable.
    Des "policies" ?
    Kesako ?
    A priori, rien de spécial.
    Oui, puisque ce sont les mêmes tables à la base.
    Je ne pense pas. Comment le savoir ?
    Citation Envoyé par Pomaleix
    Il faut un abonnement spécial pour y accéder ?
    Décembre 2002
    Citation Envoyé par CinePhil Voir le message
    Oui, il faut avoir un contrat de support en cours de validité.
    Avatar de CinePhil
    Août 2006
    Citation Envoyé par Pomalaix Voir le message
    Donc pas d'accès pour moi a priori.
  1. [11gR2] Comment savoir quelle ligne provoque une erreur sur un merge oracle
    Par Holly Smoke dans le forum Oracle
    Dernier message: 26/08/2015, 18h09
  2. Erreur sur MERGE INTO
    Par FirePrawn dans le forum MS SQL Server
    Dernier message: 13/09/2012, 14h58
  3. [VBS] Erreur sur "AddWindowsPrinterConnection"
    Par Admin dans le forum VBScript
    Dernier message: 27/03/2004, 16h15
  4. []Erreur sur second emploi collection binding
    Par jacma dans le forum VB 6 et antérieur
    Dernier message: 08/03/2004, 18h02
  5. Erreur sur le TNSListener après installation de 9iAS
    Par Patmane dans le forum Installation
    Dernier message: 04/02/2004, 11h16
