Probléme avec les texture array
    Membre régulier
    Février 2015
    Par défaut Probléme avec les texture array
    J'ai un petit probléme avec Les Texture Array.
    Dans le code qui suit je veut utilisé les Texture Array c-à-d remplacer la GL_TEXTURE_2D par GL_TEXTURE_2D_ARRAY.
    voila le code :
    #include <windows.h>
    #include <GL/glew.h>
    #include <GL/gl.h>
    #include <GL/glu.h>
    #include <stdio.h>
    #include <string>
    #include <set>
    #include <iostream>
    class RenderTarget
    private:
        GLuint _frameBuffer;
        GLuint _renderBuffer;
        GLuint _texture;
        int _size;
    public:
        virtual ~RenderTarget() {
            glDeleteTextures(1, &_texture);
            glDeleteRenderbuffers(1, &_renderBuffer);
            glDeleteFramebuffers(1, &_frameBuffer);
        const int Size() {
            return _size;
        void Bind() {
            glViewport(0, 0, _size, _size);
            glBindFramebuffer(GL_FRAMEBUFFER, _frameBuffer);
        void Unbind() {
            glBindFramebuffer(GL_FRAMEBUFFER, 0);
        GLuint Texture() {
            return _texture;
        GLuint FBO() {
            return _frameBuffer;
        RenderTarget(const int size, GLuint wrap = GL_CLAMP_TO_EDGE, GLuint filterParam = GL_LINEAR, GLuint internalFormat = GL_RGBA32F, GLuint type = GL_FLOAT) :
            _size(size)
            glGenTextures(1, &_texture);
            glBindTexture(GL_TEXTURE_2D, _texture);
            glTexImage2D(GL_TEXTURE_2D, 0, internalFormat, _size, _size, 0, GL_RGBA, type, NULL);
            static const GLfloat border[] = {2, 2, 2, 2};
            glTexParameterfv(GL_TEXTURE_2D, GL_TEXTURE_BORDER_COLOR, border);
            glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_WRAP_S, wrap);
            glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_WRAP_T, wrap);
            glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_MAG_FILTER, filterParam);
            glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_MIN_FILTER, filterParam);
            glGenFramebuffers(1, &_frameBuffer);
            glFramebufferTexture2D(GL_FRAMEBUFFER, GL_COLOR_ATTACHMENT0, GL_TEXTURE_2D, _texture, 0);
            glGenRenderbuffers(1, &_renderBuffer);
            glBindRenderbuffer(GL_RENDERBUFFER, _renderBuffer);
            glRenderbufferStorage(GL_RENDERBUFFER, GL_DEPTH_COMPONENT, _size, _size);
            glFramebufferRenderbuffer(GL_FRAMEBUFFER, GL_DEPTH_ATTACHMENT, GL_RENDERBUFFER, _renderBuffer);
            printf(" FBO dans1 -- %d \n",_frameBuffer);
            glBindTexture(GL_TEXTURE_2D, 0);
            glBindRenderbuffer(GL_RENDERBUFFER, 0);
    J'ai fait ces modification suivante:
    #include <GL/gl.h>
    #include <GL/glu.h>
    #include <stdio.h>
    #include <string>
    #include <set>
    #include <iostream>
    class RenderTarget
    private:
    	GLuint _texture;
    	int _size;
    public:
    	const int Size() {
    		return _size;
    	void Bind() {
    	void Unbind() {
    	GLuint Texture() {
    		return _texture;
    	GLuint FBO() {
    		_size(size)
    		glBindTexture(GL_TEXTURE_2D_ARRAY, _texture);
    		glTexImage3D(GL_TEXTURE_2D_ARRAY, 0, internalFormat, _size, _size, 1, 0, GL_RGBA, type, NULL);
    		static const GLfloat border[] = {2, 2, 2,2};
    		glTexParameterfv(GL_TEXTURE_2D_ARRAY, GL_TEXTURE_BORDER_COLOR, borde);
    		glTexParameteri(GL_TEXTURE_2D_ARRAY, GL_TEXTURE_WRAP_S, wrap);
    		glTexParameteri(GL_TEXTURE_2D_ARRAY, GL_TEXTURE_WRAP_T, wrap);
    		glTexParameteri(GL_TEXTURE_2D_ARRAY, GL_TEXTURE_MAG_FILTER, filterParam);
    		glTexParameteri(GL_TEXTURE_2D_ARRAY, GL_TEXTURE_MIN_FILTER, filterParam);
    		glFramebufferTextureLayer(GL_FRAMEBUFFER, GL_COLOR_ATTACHMENT0, _texture, 0, 0);
    		glBindTexture(GL_TEXTURE_2D_ARRAY, 0);
    mes une image blanche s'affiche
    Qui peut me donner une solution ?
    Avatar de dragonjoker59
    Software Developer
    Juin 2005
    Activité : Software Developer
    As-tu mis des appels à glGetError, pour vérifier que tes actions se passent bien?
    As-tu vérifié via glCheckFramebufferStatus que ton frame buffer est bien complet, avant de tenter de l'utiliser?
    Membre régulier
    Février 2015
    Citation Envoyé par dragonjoker59 Voir le message
    Bonjour, et merci pour votre réponse .
    oui oui j'ai bien utiliser glCheckFramebufferStatus pour vérification .
    voila le code :
    GLenum FBOstatus;
    	// check FBO status
    	FBOstatus = glCheckFramebufferStatusEXT(GL_FRAMEBUFFER);
    	printf("--------------- FBO== %d \n",GL_FRAMEBUFFER_COMPLETE_EXT);
    	if(FBOstatus != GL_FRAMEBUFFER_COMPLETE_EXT)
    		printf("GL_FRAMEBUFFER_COMPLETE_EXT failed, CANNOT use FBO\n");
    		switch(FBOstatus) {
            case GL_FRAMEBUFFER_COMPLETE_EXT:
                break;
            case GL_FRAMEBUFFER_UNSUPPORTED_EXT:
                printf("Unsupported framebuffer format\n");
                break;
            case GL_FRAMEBUFFER_INCOMPLETE_MISSING_ATTACHMENT_EXT:
                printf("Framebuffer incomplete, missing attachment\n");
                break;
    		case GL_FRAMEBUFFER_INCOMPLETE_ATTACHMENT_EXT:
                printf("Framebuffer incomplete, incomplete attachment\n");
                break;
            case GL_FRAMEBUFFER_INCOMPLETE_DIMENSIONS_EXT:
                printf("Framebuffer incomplete, attached images must have same dimensions\n");
                break;
            case GL_FRAMEBUFFER_INCOMPLETE_FORMATS_EXT:
                printf("Framebuffer incomplete, attached images must have same format\n");
                break;
            case GL_FRAMEBUFFER_INCOMPLETE_DRAW_BUFFER_EXT:
                printf("Framebuffer incomplete, missing draw buffer\n");
                break;
            case GL_FRAMEBUFFER_INCOMPLETE_READ_BUFFER_EXT:
                printf("Framebuffer incomplete, missing read buffer\n");
                break;
    oui oui le frame buffer est bien complet , il n-y-a aucune erreur .
    Software Developer
    Juin 2005
    Et pour glGetError, aucun soucis de ce côté là?
    Membre régulier
    Février 2015
    glGetError return 0 c-à-d aucune erreur .
    Software Developer
    Juin 2005
    Euh ... Vos appels à glGetError, vous les avez faits après chaque appel de fonction OpenGL?
  1. [OpenGL 3.x] Problème d'initialisation avec les textures array
    Par Nikogram dans le forum OpenGL
    Dernier message: 11/05/2014, 14h50
  2. Problème avec les textures
    Par Harmonic dans le forum SFML
    Dernier message: 02/04/2013, 10h27
  3. Problème avec les textures projectives
    Par sylvain_bos dans le forum Ogre
    Dernier message: 03/01/2011, 18h49
  4. Problème avec les textures
    Par Letinono dans le forum CUDA
    Dernier message: 07/07/2009, 17h06
  5. problème avec les cell array
    Par fattouna dans le forum MATLAB
    Dernier message: 02/07/2009, 22h56
