1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271
| #include "SDL.h"
#define SCREEN_WIDTH 640
#define SCREEN_HEIGHT 480
#define SPRITE_SIZE 32
#define ASTEROIDE1_SIZE 32
#define ASTEROIDE2_SIZE 16
#define ASTEROIDE3_SIZE 64
#define BULLET_SIZE 8
int gameover;
/* source and destination rectangles */
SDL_Rect rcArc1,rcArc2, rcArc3, rcBrc, rcSrc, rcSprite, rcBullet, rcAsteroide1, rcAsteroide2, rcAsteroide3;
void HandleEvent(SDL_Event event);
switch (event.type) {
/* close button clicked */
case SDL_QUIT:
gameover = 1;
break;
/* handle the keyboard */
case SDL_KEYDOWN:
switch (event.key.keysym.sym) {
case SDLK_ESCAPE:
case SDLK_q:
gameover = 1;
break;
case SDLK_LEFT:
rcSrc.x +=32;
if (rcSrc.x == 1152)
rcSrc.x = 32;
break;
case SDLK_RIGHT:
rcSrc.x -=32;
if (rcSrc.x == 32)
rcSrc.x = 1152;
break;
case SDLK_UP:
rcSrc.x = 288;
rcSprite.y -= 10;
while (rcSprite.y <= 0)
rcSprite.y = 480;
break;
case SDLK_DOWN:
rcSrc.x = 864;
rcSprite.y += 10;
while ( rcSprite.y >= 480)
rcSprite.y = 0;
break;
break;
int main ( int argc, char *argv[] )
SDL_Surface *screen, *temp, *sprite, *Bullet, *grass,*asteroide1,*asteroide2,*asteroide3;
int colorkey;
/* initialize SDL */
SDL_Init(SDL_INIT_VIDEO);
/* set the title bar */
SDL_WM_SetCaption("SDL Animation", "SDL Animation");
/* create window */
screen = SDL_SetVideoMode(SCREEN_WIDTH, SCREEN_HEIGHT, 0, 0);
/* set keyboard repeat */
SDL_EnableKeyRepeat(70, 70);
/* load sprite */
temp = SDL_LoadBMP("greenship-v1.bmp");
sprite = SDL_DisplayFormat(temp);
SDL_FreeSurface(temp);
/* load bullet */
temp = SDL_LoadBMP("bullet02.bmp");
Bullet = SDL_DisplayFormat(temp);
/* load asteroidmodel1 */
temp = SDL_LoadBMP("asteroid-model1-32_32x32.bmp");
asteroide1 = SDL_DisplayFormat(temp);
/*load asteroidmodel2*/
temp = SDL_LoadBMP("asteroid-model1-32_16x16.bmp");
asteroide2 = SDL_DisplayFormat(temp);
/*load asteroidmodel3*/
temp = SDL_LoadBMP("asteroid-model1-32_64x64.bmp");
asteroide3 = SDL_DisplayFormat(temp);
/*_______________________________________________________________
/* setup sprite colorkey and turn on RLE */
colorkey = SDL_MapRGB(screen->format, 255, 0, 255);
SDL_SetColorKey(sprite, SDL_SRCCOLORKEY | SDL_RLEACCEL, colorkey);
/* setup bullet colorkey and turn on RLE */
colorkey = SDL_MapRGB(screen->format, 255, 125, 32);
SDL_SetColorKey(Bullet, SDL_SRCCOLORKEY | SDL_RLEACCEL, colorkey);
/* setup asteroide1 colorkey and turn on RLE */
colorkey = SDL_MapRGB(screen->format, 0, 255, 255);
SDL_SetColorKey(asteroide1, SDL_SRCCOLORKEY | SDL_RLEACCEL, colorkey);
/* setup asteroide2 colorkey and turn on RLE */
SDL_SetColorKey(asteroide2, SDL_SRCCOLORKEY | SDL_RLEACCEL, colorkey);
/* setup asteroide3 colorkey and turn on RLE */
SDL_SetColorKey(asteroide3, SDL_SRCCOLORKEY | SDL_RLEACCEL, colorkey);
/* load grass */
temp = SDL_LoadBMP("backgroundlvl1.bmp");
grass = SDL_DisplayFormat(temp);
/* set sprite position */
rcSprite.x = (SCREEN_WIDTH/2-SPRITE_SIZE /2);
rcSprite.y = (SCREEN_HEIGHT/2-SPRITE_SIZE/2);
/* set bullet position */
rcBullet.x = 0;
rcBullet.y = 0;
/* set asteroide1 position */
rcAsteroide1.x = 300;
rcAsteroide1.y = 300;
/* set asteroide2 position */
rcAsteroide2.x = 200;
rcAsteroide2.y = 200;
/* set asteroide3 position */
rcAsteroide3.x = 400;
rcAsteroide3.y = 400;
/* set animation frame sprite */
rcSrc.x = 288;
rcSrc.y = 0;
rcSrc.w = SPRITE_SIZE;
rcSrc.h = SPRITE_SIZE;
/* set animation frame bullet */
rcBrc.x = 0;
rcBrc.y = 0;
rcBrc.w = BULLET_SIZE ;
rcBrc.h = BULLET_SIZE ;
/* set animation frame asteroide1 */
rcArc1.x = 32;
rcArc1.y = 0;
rcArc1.w = ASTEROIDE1_SIZE;
rcArc1.h = ASTEROIDE1_SIZE;
/* set animation frame asteroide2 */
rcArc2.x = 48;
rcArc2.y = 0;
rcArc2.w = ASTEROIDE2_SIZE;
rcArc2.h = ASTEROIDE2_SIZE;
/* set animation frame asteroide3 */
rcArc3.x = 192;
rcArc3.y = 0;
rcArc3.w = ASTEROIDE3_SIZE;
rcArc3.h = ASTEROIDE3_SIZE;
/*_____________________________________________________________*/
gameover = 0;
/* message pump */
while (!gameover)
int count = 0;
SDL_Event event;
/* look for an event */
if (SDL_PollEvent(&event)) {
HandleEvent(event);
/* rotation asteroides*/
if (count == 0){
/*rotation asteroid1*/
rcArc1.x += 32;
while( rcArc1.x == 1024 ){
rcArc1.x = 32;
rcAsteroide1.y +=1;
if(rcAsteroide1.y == 480){
rcAsteroide1.y = 0;
/*rotation asteroid2*/
rcArc2.x += 16;
while( rcArc2.x == 512){
rcArc2.x = 16;
rcAsteroide2.y -=1;
if(rcAsteroide2.y == 0){
rcAsteroide2.y = 480;
/*rotation asteroid3*/
rcArc3.x += 64;
while( rcArc3.x == 2048){
rcArc3.x = 64;
rcAsteroide3.y +=1;
if(rcAsteroide3.y == 480){
rcAsteroide3.y = 0;
/* draw the grass */
SDL_BlitSurface(grass, NULL, screen, NULL);
/* draw the sprite */
SDL_BlitSurface(sprite, &rcSrc, screen, &rcSprite);
/* draw the bullet */
SDL_BlitSurface(Bullet, &rcBrc, screen, &rcBullet);
/* draw the asteroidemodel1 */
SDL_BlitSurface(asteroide1, &rcArc1, screen, &rcAsteroide1);
/* draw the asteroidemodel2 */
SDL_BlitSurface(asteroide2, &rcArc2, screen, &rcAsteroide2);
/* draw the asteroidemodel3 */
SDL_BlitSurface(asteroide3, &rcArc3, screen, &rcAsteroide3);
/* update the screen */
SDL_UpdateRect(screen, 0, 0, 0, 0);
count ++;
if ( count == 5)
count = 0;
/* clean up */
SDL_FreeSurface(asteroide1);
SDL_FreeSurface(asteroide2);
SDL_FreeSurface(asteroide3);
SDL_FreeSurface(sprite);
SDL_FreeSurface(Bullet);
SDL_FreeSurface(grass);
SDL_Quit();
return 0;
