Probleme d'utilisation du generator "for"
    Septembre 2004
    Par défaut Probleme d'utilisation du generator "for"
    Quelle différence(s) entre mes classes obj et Coord empêche(nt) d'utiliser le generator "for" comme il se doit?
    119
    120
    121
    122
    123
    124
    125
    126
    127
    128
    129
    130
    131
    132
    133
    134
    135
    136
    137
    138
    139
    140
    141
    142
    143
    144
    145
    146
    147
    148
    149
    150
    151
    152
    153
    154
    155
    156
    157
    158
    159
    160
    161
    162
    163
    164
    165
    166
    167
    168
    169
    170
    171
    172
    173
    174
    175
    176
    177
    178
    179
    #!/usr/bin/python
    # *-* coding:UTF-8 *-*
    class Coord(tuple):
    	def __new__(cls,*arg):
    		r=tuple.__new__(cls,arg[0]) if len(arg)==1 else tuple.__new__(cls,arg)
    		return r
    	def __init__(self,*arg):
    		self.__coord=arg[0] if len(arg)==1 else list(arg)
    		self.__dim=len(self.coord)
            @property
    	def coord(self):
    		return self.__coord
            @property
    	def dim(self):
    		return self.__dim
            @coord.setter
    	def coord(self,add):
    		print "Erreur!!"
            @coord.deleter
    	def coord(self):
    		print "Erreur!!"
    	#Surcharges
    	def __str__(self):
    		return 'Coord'+str(tuple(self.coord))
    	def __hash__(self):
    		v=0
    		pw=self.dim-1
    		for c in self.__coord:
    			v+=c*10**pw
    			pw-=1
    		return v
    	def __add__(self,other):
    		if not isinstance(other,Coord):
    			print "Erreur!!"
    		else:
    			gt=self if self.dim >= other.dim else other
    			lt=other if other.dim <= self.dim else self
    #			print ("gt=%s, lt=%s" % (gt,lt))
    			ad=gt.dim-lt.dim
    			val=()
    			resized=lt.coord
    			if ad!=0:
    				for c in xrange(ad):
    					resized+=0,
    			for v1,v2 in zip(gt.coord,resized):
    				val+=v1+v2,
    			return Coord(val)
    	def __sub__(self,other):
    			print "Erreur!!"
    		else:
    			fct=-1 if other.dim>self.dim else 1
    			ad=gt.dim-lt.dim
    			val=()
    			resized=lt.coord
    			if ad!=0:
    					resized+=0,
    				val+=(v1-v2)*fct,
    			return Coord(val)
    	def __mul__(self,other):
    			print "Erreur!!"
    		else:
    			ad=gt.dim-lt.dim
    			val=()
    			resized=lt.coord
    			if ad!=0:
    					resized+=0,
    				val+=v1*v2,
    			return Coord(val)
    	def __eq__(self,other):
    			print "Erreur!"
    		else:
    			return self.coord==other.coord
    	def __ne__(self,other):
    			print "Erreur!"
    		else:
    			return self.coord!=other.coord
    	def __gt__(self,other):
    			print "Erreur!!"
    		else:
    			return self.__hash__()>other.__hash__()
    	def __ge__(self,other):
    			print "Erreur!!"
    		else:
    			return self.__hash__()>=other.__hash__()
    	def __lt__(self,other):
    			print "Erreur!!"
    		else:
    			return self.__hash__()<other.__hash__()
    	def __le__(self,other):
    			print "Erreur!!"
    		else:
    			return self.__hash__()<=other.__hash__()
    def step(c_min,c_max):
    	#TODO test de validite des arguments
    	t_min,t_max=list(c_min.coord),list(c_max.coord)
    	l_min,l_max,ret_list,mods=[],[],[],[]
    	for v1,v2 in zip(t_min,t_max):
    		l_min.append(min([v1,v2]))
    		ret_list.append(min([v1,v2]))
    		l_max.append(max([v1,v2]))
    #	print "l_min-->",l_min,"\nl_max-->",l_max,"\nret_list-->",ret_list
    	max_click,count=1,1
    	for mn,mx in zip(l_min,l_max):
    		mods.append(abs(max_click))
    		max_click*=abs(mx-mn)+1
    #	print "max_click-->",max_click,"\nmods-->",mods
    	while count<=max_click:
    		for i in xrange(len(l_min)):
    			if not count%mods[i]:
    				#print ("not %d%%%d = %s" % (count,mods[i],not count%mods[i]))
    				ret_list[i]=ret_list[i]+1 if ret_list[i]<l_max[i] else l_min[i]
    				#print ("ret_list[%d]<l_max[%d] = %s  l_min[%d] = %s" % (i,i,ret_list[i]<l_max[i],i,l_min[i]))
    				#print ("ret_list[%d] = %s" % (i,ret_list[i]))
    		yield Coord(ret_list)
    		count+=1
    class obj(object):
    	oid=1
    	def __init__(self):
    		self.oid=obj.oid
    		obj.oid+=1
    	def __str__(self):
    		return ("obj.%d" % self.oid)
    	def __repr__(self):
    	def __hash__(self):
    		return self.oid
    def robj(mx):
    	count=1
    	while count<=mx:
    		yield obj()
    		count+=1
    class mini_field():
    	def __init__(self):
    		self.__d={}
    		for c in step(Coord(1,1),Coord(1,4)):
    			self.__d[c]=c
    		for o in robj(4):
    			self.__d[o]=o
            @property
    	def d(self):
    		return self.__d
    if __name__=='__main__':
    	f=mini_field()
    	for k in f.d:
    		print k,f.d[k]
    	print f.d.keys()
    Voici ce que j'obtiens en sortie:
    obj.1 obj.1
    obj.2 obj.2
    obj.3 obj.3
    obj.4 obj.4
    Coord(1, 1) Coord(1, 1)
    [obj.1, obj.2, obj.3, obj.4, (1, 1), (1, 2), (1, 3), (1, 4)]
    Je ne retrouve plus les clés de type Coord en passant par un generator...
    Architecte technique retraité
    Juin 2008
    Lorsque vous faites print f.d.keys() çà affiche la liste f.d.keys()...
    Normal: on applique str sur la liste.
    Vous souhaiteriez que le str s'applique aux éléments de la liste...
    Ca ne fonctionne pas comme çà, snif?
    Pour vous en convaincre:
    >>class A:
    >>    def __str__(self): return 'A'
    >> li = [ 1, 2, 3, A() ]
    >> print li
    [1, 2, 3, <__main__.A instance at 0x28c8c8>]
    >>> print ', '.join(str(e) for e in li)
    1, 2, 3, A
    -W
    Architectures post-modernes.
    Septembre 2004
    Les problèmes de mise en forme ne me dérange guère. Ce que je trouve beaucoup plus gênant c'est:
    qui a pour réponse:
    File "./Coord_beta.py", line 180, in <module>
    print f.d[Coord(1,2)]
    KeyError: (1, 2)
    Alors même que la clé est présente dans la liste f.d.keys()!!
    Juin 2008
    Re...
    Citation Envoyé par Krishna Voir le message
    N'étaient-ils pas la raison du premier post?
    qui a pour réponse:
    Heu... comme vous ne dites pas pourquoi çà vous gêne, vous laissez penser que vous considérez "Coord(1,2)" comme une chaine de caractère et non comme une nouvelle, à priori, instance de Coord(1,2)...
    Qu'avez vous fait pour que çà puisse fonctionner?
    Bon d'accord en prenant le temps de fouiller le code on trouve une fonction __hash__ qui pourrait, si complétée par __cmp__, le faire...
    Mais c'est beurk: retournez l'instance précédemment créé via __new__ plutôt que de multiplier des objets identiques mais pas vraiement pareil...
    Vous vous entrainez à coder toxique ou quoi?
    - W
    PS: A quoi sert d'avoir sous classé tuple si c'est pour stocker les valeurs 'ailleurs' et avoir une fonction de hash en plus???
    class Coord(tuple):
        _instances_ = {}
        def __new__(cls, *args):
            if args not in cls._instances_:
                cls._instances_[args] = tuple.__new__(cls, args)
            return cls._instances_[args]
    t = Coord(1, 1)
    v = Coord(1, 1)
    print 't == v: %s' % (t == v) # t et v sont égaux
    print 'id(t) = %s' % id(t) # mais aussi identiques
    print 'id(v) = %s' % id(v)
    dd = {}                         # si nous mettons cela dans un dict..
    for x in range(4):
        c = Coord(1, x)
        dd[c] = c
    if t in dd: print 'known'  # pas besoin de __cmp__ ou de __hash__
    print dd[Coord(1,1)]
    Septembre 2004
    Bonsoir, re...bonsoir...
    L'utilisation du generator "for" me permettrait avant tout d'accéder au contenu du dictionnaire.
    Certes, le manque de clarté dans ma question permet toutes les interprétations...
    Je n'ai rien lu jusqu'ici sur __cmp__ dans mon livre de référence python. Je vais m'y employer de ce pas et corriger le code en conséquence.
    Alors là j'aurais vraiment besoin de précision. Est-ce une question d'espace mémoire? Comment fait-on pour retourner l'instance précédemment créée via __new__?
    Qu'est-ce que du code toxique?
    Décembre 2007
    bonsoir,
    c'est le code qu'a mis wiztricks dans son dernier message
    Mars 2007
    Ce qui m'a toujours dérangé avec cette technique est que la méthode __init__ est quand-même appelée, même si on retourne un objet déjà construit...
    Septembre 2004
    La classe...
    devidee,
    Peux-tu m'exposer brièvement (même si je considère mon post comme résolu) dans quelles circonstances cette technique peut poser problème?
    Décembre 2007
    ce que veut dire dividee, c'est que lorsque __new__ renvoie une instance qui existe déjà celle-ci repasse par la case "__init__". Tout le travail qui avait été fait lors de la création de cette instance est alors fait à nouveau (mais à l'identique). Quelque part, c'est une perte de temps (surtout si le travail fait par __init__ est long).
    Juin 2008
    Par défaut ajout delete
    Intellectuellement, je suis d'accord: c'est pas top.
    Mais la chose permet de "tuner" ce qu'on fait dans __init__ ou dans __new__ jusqu'à supprimer complètement __init__.
    Les vrais problèmes se posent lorsqu'on sous classe ce type d'objet mais c'est déjà le cas pour toutes les classes qui comportent une partie statique.
    Voir les DP Singleton et FlyWeight - ce dernier étant cela.
    Un autre problème est la gestion du delete ou le contrôle du nombre d'individu de la collection.
    Python utilise ce genre de technique pour mémoriser les objets de type int et les float. L'idée étant qu'il n'est pas utile de les détruire... Suivant l'algo. leur quantité devient insupportable côté occupation mémoire: elle n'est libérée qu'à la sortie du programme.
    - W
    Juin 2008
    Citation Envoyé par kango Voir le message
    La chose permet de définir une collection d'objets ayant un identifiant qui sert de clé: chaque instance ne doit être initialisée qu'une seule fois 'à la création' et nécessairement dans/via __new__.
    Pourquoi déclarer __init__ dans ce cas?
    - W
    Décembre 2007
    c'est pas faux, rien ne nous empêche de ne PAS implémenter __init__
    Juin 2008
    Par défaut toxique!
    Il n'est pas toujours facile de mettre du verbe sur une réaction épidermique
    Mais Coord sous classe tuple en stockant le vecteur passé en paramètre dans une liste (et dans self via le tuple.__new__).
    Une des différences entre tuple et list est la mutabilité du second que vous traitez bizarrement car __add__ et __sub__ retourne de nouveaux Coord i.e. l'objet est 'immutable' même si on utilise les valeurs du vecteur de la liste __coord.
    In fine, tout cela manque de cohérence et la vraie question est de savoir ce que vous voulez vraiment faire i.e. pour représenter vos vecteurs optez vous de sous classer list ou de sous classer tuple?
    La mutabilité en découle... et la nécessité d'écrire __hash__ et __cmp__ sans doute aussi.
    Pour l'instant, le seul attribut ajouté à la classe de base est 'dim', la longueur qui peut être calculée dynamiquement et vu comme attribut grace à property. Ce qui laisse penser que les vecteurs (Coord) sont des list ou des tuple auxquels sont ajoutés les methods/opérations __add__, __sub__, ...
    qui retourne ou pas une nouvelle instance (list donne le choix, tuple: non).
    Et si nous accrochons que des méthodes à un type de base immutables, pourquoi mémoriser les objets crées?
    - W
    Janvier 2007
    Citation Envoyé par dividee Voir le message
    Et si on fait ? :
    class Coord(tuple):
        _instances_ = {}
            else:
                return Coord._instances_[args]
    PS
    Dans le code de wiztricks (message #4), il n’apparait pas __init__()
    Si ça avait été le cas, j’aurais bien placé un
    print ’quelque chose de visible’
    dans cet __init__() pour me convaincre de visu que le programme passe dans __init__() dans tous les cas.
    Quel code écrire pour obtenir une telle confirmation ?
    Juin 2008
    Bonjour Eyquem
    Citation Envoyé par eyquem Voir le message
    class Coord(tuple):
        _instances_ = {}
            else:
    cls._instances_ est la même chose que Coord._instances_ donc:
    class Coord(tuple):
        _instances_ = {}
    me paraît suffisant.
    Pour le reste, il est tellement 'simple' d'ajouter:
        def __init__(self, *args):
            print 'coucou'
    que je n'ai sans doute pas compris la question.
    - W
    Mars 2007
    Une perte de temps c'est le cas "gentil". Cela peut aussi faire échouer __init__, augmenter l'utilisation mémoire qu'on essayait de limiter, ou même donner un comportement incorrect si on n'y prend pas garde.
    - W
    En cas d'héritage, c'est le __init__ de la classe parente qui sera appelé (dans le cas présent, tuple.__init__).
    Il faudrait donc ajouter:
            pass
    pour l'éviter.
    Juin 2008
    Bonjour Dividee,
    Je ne sais pas s'il faut s'attacher à ce genre de détails car ce qui doit être fait dans __new__ et dans __init__ est à traiter au cas par cas.
    Ici, dans cet exemple, nous sous-classons un type de base: je ne suis pas certain qu'une méthode __init__ soit définie pour les "tuple".
    ??? Si la surclasse définit une méthode '__init__' il faudra l'appeler au moins dans __new__ après la création de l'instance... ou via __init__ en lui passant les paramètres attendus.
    Dans ce cas, on peut être embêté pour définir le passage de paramètre de __new__ à __init__:
    - on pose que c'est __init__ qui insère l'instance dans le __dict__,
    - on ajoute **kwds au paramètres et __new__ positionne kwds['do_init'] à True
    - autres,
    Les règles de 'compositions' ne sont pas (voire jamais) simples.
    - W
    heu...
    Octobre 2007
    Activité : heu...
    Hmmm... je lis ce sujet avec interêt, mais une situation me turlupine... :
    imaginons que nous devions faire un traitement sur un dictionnaire avec des centaines de millions (ou millirads ou plus, bref énormément) de clés qui chacune est une instance de Coord, mais qu'ensuite, nous passions à un tout autre traitement qui n'a plus besoin du dictionnaire ou des instances de Coord, Coord._instances_ garderait une référence des différentes instances, qu'il faudrait manuellement supprimer pour que cela n'encombre plus la mémoire...
    Dans ce cas, l'implémentation de __cmp__() (ou __eq__()) et __hash__() ne serait-elle pas plus judicieuse ? Et si oui, auriez vous un exemple (oui, j'ai pas capté grand chose à __hash__()... ) ? Et si non, pourquoi (ou pourquoi ce serait 'beurk' )?
    Mars 2007
    dir(tuple) m'indique que tuple possède bien une méthode __init__.
    Je ne comprends pas les trois points d'interrogation. Oui, il faudra certainement appeler la méthode __init__ du parent dans __new__, mais il faudra aussi éviter qu'elle soit appelée automatiquement (une deuxième fois donc!) par le mécanisme de création d'instances.
    Un exemple:
    class A(object):
            print "A.__init__"
    class B(A):
        _instances_ = {}
                self = A.__new__(cls, *args)
                A.__init__(self, *args)
                cls._instances_[args] = self
    >>> b = B(42)
    A.__init__
    A.__init__ # de trop
    >>> c = B(42)
    A.__init__ # de trop, retourne la même instance que b
    D'où la nécessité de définir une méthode __init__ vide dans la classe B pour éviter cela.
    - autres,
    - W
    D'accord, on ne peut pas donner de solution générale, mais ce n'était pas mon propos, je voulais juste attirer l'attention sur le point ci-dessus qu'il est facile d'oublier...
    Juin 2008
    Salut N.tox
    J'ai déjà mentionné les soucis que tu énonces.
    Comme dans le cas précédent, il faut rester "pragmatique".
    Citation Envoyé par N.tox Voir le message
    Ah ben le problème de la destruction est un des soucis de la chose et les types int et float présentent ce problème.
    Une solution pourrait être de déclarer le dico _instance_ weakref.
    Après tout, s'il n'y a plus de références à un objet dont la clé est X...
    Autres applications: la chose pourrait être le cache d'une partie des millions d'enregistrements d'une base de donnée. Dans ce cas, nous aurions à définir la 'clé' qui permet de savoir si une copie mémoire de l'enregistrement existe déjà ou pas.
    C'est "beurk" dans le contexte clé => attributs.
    Prenons des "tuple":
    a = 1, 2
    b = 1, 2
    c = 3
    assert a == b
    assert c != a
    assert id(a) != id(b)
    Note: contrairement aux "int", deux "tuple" égaux n'ont pas la même adresse.
    Sous classons:
    class T(tuple): pass
    a = T((1, 2))
    b = T((1, 2))
    assert a == b
    Pas de changement, ouf... mais ajoutons de la viande à T:
    class T(tuple):
        count = 0
            self._count = T.count
            T.count += 1
    Les relations précédentes sont toujours valables : T dérive de tuple.
    Et la on est embêté... car si nos objets égaux ne sont plus si égaux que çà...
    __hash__, __cmp__ les 'trouvent' égaux:
    >>> dd = {}
    >>> dd[a] = a
    >>> print dd[b]._count
    0
    alors que nous devrions avoir 1...
    La relation d'identité ainsi déconstruite difficile de définir des formes.
    - W
  1. Réponses: 2
    Dernier message: 30/08/2004, 14h48
