Bonjour a tous,
je suis entrain de développer ma 1ère application en servlets/jsp donc j'ai rencontré un problème dans l'authentification des utilisateurs toute aide sera la bienvenue. Merci d'avance
Ma page d'authentification:
ma servlet
68 <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd"> <html xmlns="http://www.w3.org/1999/xhtml"> <head> <meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1" /> <title>Security Policy</title> <link href="main.css" rel="stylesheet" type="text/css" /> <script> function ins() { if(document.form1.password.value.length==0|| document.form1.login.value.length==0) alert("must complete all mandatory fields"); else { document.form1.action='Servlet_Authen.java'; //document.form1.submit(); } } </script> <style type="text/css"> <!-- .momo { font-family: Times New Roman, Times, serif; } .momo { color: #000; font-weight: bold; } .momo { font-size: large; } --> </style> </head> <body onload="MM_preloadImages('images/genilogo.bmp')"> <p align="center" class="titre">Welcome</p> <div align="justify"> <p class="momo" style="size:20px">You should sign in to configure your Security Policy </p><form method="get" name="form1" id="form1"> <center> <table width="594" border="0"> <tr> <div class="ins"> <td class="ins">*Login</td> <td class="ins"><input class="champtext" name="login" type="text" maxlength="30" /></td> </div> </tr> <tr class="ins"> <p> </p> <div class="ins"> <td>*Password</td> <td> <input class="champtext" name="password" type="password" maxlength="30"/> </td> </div> </tr> </table> </center> <center> <p> <input name="Reset" id="search_btn" type="reset" value="Reset" /> <input name="Enter" id="search_btn" type="submit" onclick="ins();" value="Enter" /> </p> </center> </form> <p> </p> <p class="momo"> </p> </div> </body>
77//package Servlets; import java.io.PrintWriter; import javax.servlet.*; import javax.servlet.http.*; import java.io.IOException; import java.sql.*; public class Servlet_Authen extends HttpServlet { public class Authentification { private Connection c; private Statement stmt; public Authentification()throws ClassNotFoundException, SQLException { Class.forName("sun.jdbc.odbc.JdbcOdbcDriver"); c = DriverManager.getConnection("jdbc:odbc:DBAdmin"); stmt = c.createStatement(); } public boolean verification(String login,String password)throws SQLException { ResultSet rs1 = stmt.executeQuery("select * from DBAdmin.administrateur"); boolean verif=false; while(rs1.next()) { if((login.equals(rs1.getString(2)))& (password.equals(rs1.getString(3)))) { verif= true; } //System.out.println(rs1.getString(2)); } return verif; } public void liste() throws SQLException { ResultSet rs = stmt.executeQuery("select * from DBAdmin.administrateur"); while(rs.next()){ System.out.println(rs.getString(3));} } } public void doGet( HttpServletRequest req, HttpServletResponse response) throws ServletException, IOException { // get stream to output HTML on! response. setContentType("text/html"); PrintWriter out = response. getWriter(); String login = req. getParameter("login"); String password = req. getParameter("password"); // System.out.println(login+password); HttpSession session = req.getSession(true); session.setAttribute("login", login); try{ Authentification authentification = new Authentification(); if (authentification.verification(login,password)) { RequestDispatcher dispat = getServletContext().getRequestDispatcher("/Accueil_auth.html"); dispat.forward(req,response); } else { } } catch(Exception e){ e.printStackTrace(); } } }
