Depuis quelques jours j'ai l'erreur suivante sur mes sauvegardes de bases.
Les sauvegardes sont gérées par un catalog rman et un script.
Le script envoie les backups sur une bande.
J'ai eu le probleme sur 1 base et ca s'est communiqué à toutes... avec les mêmes erreurs...
Auriez vous une idée ?
26 RMAN> 2> 3> 4> 5> 6> 7> 8> 9> 10> 11> 12> 13> 14> 15> allocated channel: c1 channel c1: sid=531 devtype=SBT_TAPE channel c1: Time Navigator Media Management Starting backup at 19-APR-10 channel c1: starting full datafile backupset channel c1: specifying datafile(s) in backupset including current control file in backupset including current SPFILE in backupset channel c1: starting piece 1 at 19-APR-10 channel c1: finished piece 1 at 19-APR-10 piece handle=l3lbfn1t_1_1 tag=TAG20100419T011541 comment=API Version 2.0,MMS Version 4.0.1.0 channel c1: backup set complete, elapsed time: 00:05:06 Finished backup at 19-APR-10 Starting backup at 19-APR-10 channel c1: starting compressed full datafile backupset channel c1: specifying datafile(s) in backupset input datafile fno=00004 name=/oradata/sejour/data/data1.dbf input datafile fno=00005 name=/oradata/sejour/data/index1.dbf input datafile fno=00002 name=/oradata/sejour/data/undo.dbf input datafile fno=00001 name=/oradata/sejour/data/system.dbf input datafile fno=00003 name=/oradata/sejour/data/sysaux input datafile fno=00006 name=/oradata/sejour/data/tempdb.dbf channel c1: starting piece 1 at 19-APR-10 RMAN-03009: failure of backup command on c1 channel at 04/19/2010 01:35:04 ORA-19513: failed to identify sequential file ORA-27206: requested file not found in media management catalog continuing other job steps, job failed will not be re-run channel c1: starting compressed full datafile backupset channel c1: specifying datafile(s) in backupset including current control file in backupset including current SPFILE in backupset channel c1: starting piece 1 at 19-APR-10 channel c1: finished piece 1 at 19-APR-10 piece handle=l5lbfo69_1_1 tag=TAG20100419T012049 comment=API Version 2.0,MMS Version 4.0.1.0 channel c1: backup set complete, elapsed time: 00:06:06 released channel: c1 RMAN-00571: =========================================================== RMAN-00569: =============== ERROR MESSAGE STACK FOLLOWS =============== RMAN-00571: =========================================================== RMAN-03009: failure of backup command on c1 channel at 04/19/2010 01:35:04 ORA-19513: failed to identify sequential file ORA-27206: requested file not found in media management catalog
