[SDL+OpenGL] Initialisation de OpenGL orienté objet ?
    Membre averti Avatar de legend666
    Mars 2004
    Par défaut [SDL+OpenGL] Initialisation de OpenGL orienté objet ?
    Salut !
    J' essaye de faire une petite classe OpenGL me permettant de faciliter l' affichage de ce dernier:
    class SCREEN
    public:
      SCREEN(char * T = "VMAP SCENE", bool FULL = false, int S_w = 800, int S_h = 600, int S_bpp = 16);
      void InitVMAP(void);
      void Draw(void);
    private:
      /* WINDOW PROPERTIES */
      int SCREEN_w;
      int SCREEN_h;
      int SCREEN_bpp;
      char * TITLE;
      bool MainLoop;
      Uint8 * Keys;
      Uint32 Vflags;
      int FpsT;
      SDL_Surface * Screen;
      SDL_Event E;
      void ReshapeGL(void);
    void SCREEN::InitVMAP(void)
      if(SDL_Init(SDL_INIT_VIDEO) < 0)
        cerr << "Unable to open SDL: " << SDL_GetError() << endl;
        exit(1);
      atexit(SDL_Quit);
      FpsT = SDL_GetTicks();
      SDL_GL_SetAttribute(SDL_GL_RED_SIZE, 5);
      SDL_GL_SetAttribute(SDL_GL_GREEN_SIZE, 5);
      SDL_GL_SetAttribute(SDL_GL_BLUE_SIZE, 5);
      SDL_GL_SetAttribute(SDL_GL_DEPTH_SIZE, 16);
      SDL_GL_SetAttribute(SDL_GL_DOUBLEBUFFER, 1);
      if(!(Screen = SDL_SetVideoMode(SCREEN_w, SCREEN_h, SCREEN_bpp, Vflags)))
        cerr << "Unable to set Videomode: " << SDL_GetError() << endl;
        exit(1);
      atexit(SDL_Quit);
      SDL_FillRect(Screen, NULL, SDL_MapRGBA(Screen->format, 0, 0, 0, 0));
      ReshapeGL();
      SDL_WM_SetCaption(TITLE, NULL);
      glClearColor(0.0f, 0.0f, 0.0f, 0.5f);
      glClearDepth(1.0f);
      glDepthFunc(GL_LEQUAL);
      glEnable(GL_DEPTH_TEST);
      glEnable(GL_CULL_FACE);
      glShadeModel(GL_SMOOTH);
      glHint(GL_PERSPECTIVE_CORRECTION_HINT, GL_NICEST);
      return;
    void SCREEN::Draw(void)
      while(!SDL_PollEvent(& E) || E.type != 2)
        glLoadIdentity();
        glBegin(GL_TRIANGLES);
        glVertex3f(0.0f, 1.0f, 0.0f);
        glVertex3f(-1.0f, -1.0f, 0.0f);
        glVertex3f(1.0f, -1.0f, 0.0f);
        glEnd();
        SDL_GL_SwapBuffers();
      return;
    Ce code compile parfaitement, mais malheureusement la fonctio Draw n' affiche rien ! Aurai-je oublié une étape d' initialisation ou autre ?
    Merci d' avance
    Avatar de shenron666
    avancé
    Avril 2005
    Activité : avancé
    oui tu as oublié quelques inits :
    - tu n'initialises pas le viewport ni la perspective
    - tu ne sélectionne pas la matrice GL_MODELVIEW avant de traiter ton affichage
    - de plus ton triangle est en z = 0 après un glLoadIdentity donc il ne peut etre visible, il faudrait faire un glTranslate vers le fond de la scène afin de le positionner devant la vue
    - tu ne donne pas de couleur à ton triangle
    vois déjà si cela fait quelque chose et reviens nous voir
    Tutoriels OpenGL
  1. problème SDL 2.0 et opengl
    Par Lintel-oo dans le forum SDL
    Dernier message: 03/04/2015, 01h57
  2. opengl : probleme vecteur local a un objet
    Par lanael dans le forum OpenGL
    Dernier message: 02/01/2007, 19h36
  3. Initialisation d'un type d'objet
    Par fdraven dans le forum Oracle
    Dernier message: 28/10/2005, 12h05
  4. Initialisation d'openGL (Visualisation et repère)
    Par franco01 dans le forum OpenGL
    Dernier message: 23/07/2005, 02h10
  5. OpenGL sans fenetre OpenGl
    Par ihuop dans le forum OpenGL
    Dernier message: 20/04/2005, 15h33
