Bonjour tout le monde,
voilà je me suis dernièrement mit à OpenGL, et j'en suis à la lumière. Voici mon code:
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
#include <iostream>
#include <string>
#include "sdlglutils.h"
#include <GL/glu.h>
GLfloat lightAmbient[] = {0.5, 0.5, 0.5, 1.f };
GLfloat lightDiffuse[] = {1, 1, 1, 1.f };
GLfloat lightPosition[] = {0.f, 0.f,10 };
GLuint textureCaisseCote;
GLuint textureCaisseFace;
GLuint textureSol;
double angle1 = 0;
double angle2 = 0;
double fovy = 0;
void dessiner_scene()
    // Vider l'écran.
    glMatrixMode(GL_MODELVIEW);
    glLoadIdentity();
    // Placer la camera.
    gluLookAt(2+fovy, 1+fovy, 3+fovy, 0, 0, 0, 0, 0, 1);
    glRotated(angle1, 1, 0, 0);
    glRotated(angle2, 0, 0, 1);
    glLightfv(GL_LIGHT0, GL_DIFFUSE, lightDiffuse);
    glLightfv(GL_LIGHT0, GL_AMBIENT, lightAmbient);
    glLightfv(GL_LIGHT0, GL_POSITION, lightPosition);
    // Sol.
    glBindTexture(GL_TEXTURE_2D, textureSol);
    glBegin(GL_QUADS);
        glNormal3f(0, 0, -1);
        glTexCoord2d(0, 0);   glVertex3d(5, -5, -0.5);
        glTexCoord2d(5, 0);   glVertex3d(5, 5, -0.5);
        glTexCoord2d(5, 5);   glVertex3d(-5, 5, -0.5);
        glTexCoord2d(0, 5);   glVertex3d(-5, -5, -0.5);
    glEnd();
    glBindTexture(GL_TEXTURE_2D, textureCaisseFace);
    glBegin(GL_QUADS);
        // Face avant.
        glNormal3f(1, 0, 0);
        glTexCoord2d(0, 0);   glVertex3d(1, -0.5, -0.5);
        glTexCoord2d(1, 0);   glVertex3d(1, 0.5, -0.5);
        glTexCoord2d(1, 1);   glVertex3d(1, 0.5, 0.5);
        glTexCoord2d(0, 1);   glVertex3d(1, -0.5, 0.5);
        // Face arriere.
        glNormal3f(-1, 0, 0);
        glTexCoord2d(0, 0);   glVertex3d(-1, 0.5, -0.5);
        glTexCoord2d(1, 0);   glVertex3d(-1, -0.5, -0.5);
        glTexCoord2d(1, 1);   glVertex3d(-1, -0.5, 0.5);
        glTexCoord2d(0, 1);   glVertex3d(-1, 0.5, 0.5);
    glEnd();
    glBindTexture(GL_TEXTURE_2D, textureCaisseCote);
    glBegin(GL_QUADS);
        // Cote Droit.
        glNormal3f(0, 1, 0);
        // Cote Gauche.
        glNormal3f(0, -1, 0);
        glTexCoord2d(0, 0);   glVertex3d(-1, -0.5, -0.5);
        glTexCoord2d(1, 0);   glVertex3d(1, -0.5, -0.5);
        glTexCoord2d(1, 1);   glVertex3d(1, -0.5, 0.5);
        glTexCoord2d(0, 1);   glVertex3d(-1, -0.5, 0.5);
        // Cote Haut.
        glNormal3f(0, 0, 1);
        glTexCoord2d(0, 0);   glVertex3d(1, 0.5, 0.5);
        glTexCoord2d(1, 0);   glVertex3d(-1, 0.5, 0.5);
    glEnd();
    // Proceder à l'affichage.
    glFlush();
    SDL_GL_SwapBuffers();
int main(int argc, char** argv)
    // Initialisation de la SDL.
    if (SDL_Init(SDL_INIT_VIDEO) < 0)
        std::cerr << "Error - Impossible d'initialiser la SDL." << std::endl;
        return EXIT_FAILURE;
    // Parametrage de la fenêtre.
    SDL_WM_SetCaption("OpenGL -- Caisse", NULL);
    // Ouverture de la fenêtre avec un contexte OpenGL.
    SDL_Surface* screen = SDL_SetVideoMode(640, 480, 32, SDL_OPENGL);
    if (screen == NULL)
        std::cerr << "Error - " << SDL_GetError() << std::endl;
    // Parametrage de la matrice de projection.
    glMatrixMode(GL_PROJECTION);
    glLoadIdentity();
    gluPerspective(70, (double)(640/480), 1, 1000);
    // Activation du texturage et de la profondeur.
    glEnable(GL_DEPTH_TEST);
    glEnable(GL_TEXTURE_2D);
    glEnable(GL_LIGHT0);
    glEnable(GL_LIGHTING);
    // Chargement de la texture.
    textureCaisseCote = loadTexture("crate06_side_top.jpg");
    textureCaisseFace = loadTexture("crate06_front.jpg");
    textureSol = loadTexture("sol.jpg");
    SDL_Event event;
    bool running = true;
    SDL_EnableKeyRepeat(10, 10);
    while (running)
        while (SDL_PollEvent(&event))
            switch (event.type)
                case SDL_QUIT:
                    running = false;
                    break;
                case SDL_KEYDOWN:
                    if (event.key.keysym.sym == SDLK_LEFT)
                        angle1--;
                    if (event.key.keysym.sym == SDLK_RIGHT)
                        angle1++;
                    if (event.key.keysym.sym == SDLK_UP)
                        angle2++;
                    if (event.key.keysym.sym == SDLK_DOWN)
                        angle2--;
                    if (event.key.keysym.sym == SDLK_SPACE)
                        fovy += 0.1;
                    if (event.key.keysym.sym == SDLK_ESCAPE)
                        fovy -= 0.1;
                    break;
            dessiner_scene();
    // Fermer SDL.
    SDL_Quit();
    return EXIT_SUCCESS;
pour sdlglutils.h c'est juste pour utiliser le loadTexture(..) donc je pense pas que le problème bient de là.
En fait, mon problème est que je n'ai pas de lumière, voici un screen:
http://img124.imageshack.us/img124/7910/argpr0.png
Quelqu'un pourrait me dire d'où vient le problème ? Merci d'avance =x
