Optimisation de requête
    Septembre 2006
    Par défaut Optimisation de requête
    Voici l'explain plan d'une requête :
    SELECT COUNT(*)
    FROM DO_LOT_DOSSIER DOS
        ,SE_CAS CAS
        ,DO_LOT_ENTETE ENT
        ,DO_LOT_BON BON
        ,INT_IDENT_ROLE IDROLE
        ,AS_PRODUIT PROD
        ,AS_PRODUIT PROD2
      WHERE DOS.SE_CAS_ID = CAS.ID
    and BON.DO_LOT_ENT_ID = ENT.ID
    and BON.DO_LOT_ENT_ID = DOS.DO_LOT_ENT_ID
    and BON.SE_CAS_ID = DOS.SE_CAS_ID
    and BON.INT_TIDENT_CI = DOS.INT_TIDENT_CI
    and BON.INT_IDROLE_ID = DOS.INT_IDROLE_ID
    and IDROLE.ID = DOS.INT_IDROLE_ID
    and PROD.ID(+) = BON.AS_PROD_ID
    and PROD2.ID(+) = BON.AS_PROD_VEHI_ID
    call     count       cpu    elapsed       disk      query    current        rows
    Parse        2      0.03       0.02          0          0          0           0
    Execute      2      0.00       0.00          0          0          0           0
    Fetch        4      4.18       4.66       8826    2475294          0           2
    total        8      4.21       4.69       8826    2475294          0           2
    Misses in library cache during parse: 1
    Optimizer goal: CHOOSE
    Parsing user id: 23  (IDINFO)
    Rows     Row Source Operation
          1  SORT AGGREGATE
     221227   NESTED LOOPS
     221227    NESTED LOOPS
     221227     NESTED LOOPS
     221244      NESTED LOOPS OUTER
     221244        NESTED LOOPS
     221244         TABLE ACCESS FULL DO_LOT_BON
     221244         INDEX UNIQUE SCAN DO_LOT_ENT_PK (object id 7773)
     221205        INDEX UNIQUE SCAN AS_PROD_PK (object id 6579)
     125737       INDEX UNIQUE SCAN AS_PROD_PK (object id 6579)
     221227      INDEX UNIQUE SCAN DO_LOTDOSS_UK (object id 7771)
     221227     INDEX UNIQUE SCAN INT_IDROLE_PK (object id 8154)
     221227    INDEX UNIQUE SCAN SE_INTERV_PK (object id 9027)
    Rows     Execution Plan
          0  SELECT STATEMENT   GOAL: CHOOSE
          1   SORT (AGGREGATE)
     221227    NESTED LOOPS
     221227     NESTED LOOPS
     221227      NESTED LOOPS
     221244       NESTED LOOPS (OUTER)
     221244         NESTED LOOPS
     221244          TABLE ACCESS   GOAL: ANALYZED (FULL) OF
                         'DO_LOT_BON'
     221244          INDEX   GOAL: ANALYZED (UNIQUE SCAN) OF
                         'DO_LOT_ENT_PK' (UNIQUE)
     221205         INDEX   GOAL: ANALYZED (UNIQUE SCAN) OF 'AS_PROD_PK'
                        (UNIQUE)
     125737        INDEX   GOAL: ANALYZED (UNIQUE SCAN) OF 'AS_PROD_PK'
                       (UNIQUE)
     221227       INDEX   GOAL: ANALYZED (UNIQUE SCAN) OF 'DO_LOTDOSS_UK'
                      (UNIQUE)
     221227      INDEX   GOAL: ANALYZED (UNIQUE SCAN) OF 'INT_IDROLE_PK'
                     (UNIQUE)
     221227     INDEX   GOAL: ANALYZED (UNIQUE SCAN) OF 'SE_INTERV_PK'
                    (UNIQUE)
    Comme vous pouvez le voir, il utilise presque partout des index, il n'y a que sur la table "DO_LOT_BON" qu'il fait un "ANALYZED (FULL)", est-il possible de diminuer le temps d'exécution de cette requête? Dans cette requête, je n'ai pas mis les colonnes que doit retourner le select, en effet ce select permet la création d'une vue.
    Au niveau du nombre de ligne par table :
    DO_LOT_BON : 247092
    DO_LOT_ENTETE : 2636
    DO_LOT_DOSSIER : 37568
    SE_CAS : 18349
    INT_IDENT_ROLE : 7246
    AS_PRODUIT : 3822
    Est-ce que l'ordre de déclaration de la clause FROM peut avoir une incidence sur les performances?
    Merci d'avance pour vos conseils avisés.
    Cédric
    McM
    McM est déconnecté
    Développeur Oracle
    Juillet 2003
    Activité : Développeur Oracle
    Quelle version de base ?
    McM
    McM est déconnecté
    Développeur Oracle
    Juillet 2003
    Est-ce que les stats sont à jour, parce qu'un acces full sur dos "serait" peut être mieux.
    Septembre 2006
    La base est en version 9.2.0.1, une migration est prévu en 10g mais pas dans l'immédiat.
    Les stats sont mis à jour une fois par semaine.
    Avatar de orafrance
    Janvier 2004
    Pour info, l'install du patchset 9.2.0.6 ou 9.2.0.7 serait déjà un bon début sachant que l'optimizer profite de quelques corrections intéressantes.
    Avatar de orafrance
    Janvier 2004
    Citation Envoyé par cedrich Voir le message
    Non, cela n'a d'importance qu'en mode RULE, ce qui n'est pas le cas (GOAL: CHOOSE).
    Septembre 2006
    Le schéma étant sur une base de test, j'ai migré en version 9.2.0.8.
    Voici le nouveau plan :
    119
    120
    121
    122
    123
    124
    125
    126
    127
    128
    129
    130
    131
    132
    133
    134
    135
    136
    137
    138
    139
    140
    SELECT CAS.TITRE CAS_TITRE
              ,CAS.DESIGNATION CAS_DESIGNATION
              ,CAS.CAS_NUMERO CAS_NUMERO
              ,BON.DB_ELEMENT_ID BON_DB_ELEMENT_ID
              ,BON.STATUS BON_STATUS
              ,BON.ID BON_ID
              ,BON.DO_LOT_ENT_ID BON_DO_LOT_ENT_ID
              ,BON.DATE_BON BON_DATE_BON
              ,BON.BON_NUMERO BON_BON_NUMERO
              ,BON.BON_SEQUENCE BON_BON_SEQUENCE
              ,BON.NOM_CLIENT BON_NOM_CLIENT
              ,BON.NUMERO_CLIENT BON_NUMERO_CLIENT
              ,BON.INT_TIDENT_CI BON_INT_TIDENT_CI
              ,BON.INT_IDROLE_ID BON_INT_IDROLE_ID
              ,BON.NUMERO_CARTE BON_NUMERO_CARTE
              ,BON.NUMERO_DOSSIER BON_NUMERO_DOSSIER
              ,BON.SE_CAS_ID BON_SE_CAS_ID
              ,BON.RECETTE_ARTICLE BON_RECETTE_ARTICLE
              ,BON.AS_PROD_ID BON_AS_PROD_ID
              ,BON.AS_PROD_VEHI_ID BON_AS_PROD_VEHI_ID
              ,BON.QUANTITE BON_QUANTITE
              ,BON.PRIX_UNITAIRE BON_PRIX_UNITAIRE
              ,BON.TAUX_RABAIS BON_TAUX_RABAIS
              ,BON.MONTANT_RABAIS BON_MONTANT_RABAIS
              ,BON.TAUX_MAJO BON_TAUX_MAJO
              ,BON.MONTANT_MAJO BON_MONTANT_MAJO
              ,BON.CO_TVATIER_ID BON_CO_TVATIER_ID
              ,BON.CO_TVACODE_ID BON_CO_TVACODE_ID
              ,BON.TAUX_TVA BON_TAUX_TVA
              ,BON.MONTANT_TVA BON_MONTANT_TVA
              ,BON.MONTANT_LIGNE BON_MONTANT_LIGNE
              ,BON.CO_COMPTE_FACTURATION_ID BON_CO_COMPTE_FACTURATION_ID
              ,BON.DO_DOCVTED_ID BON_DO_DOCVTED_ID
              ,BON.DB_UNIT_ID BON_DB_UNIT_ID
              ,BON.ETALON BON_ETALON
              ,BON.DO_REGLIG_CI BON_DO_REGLIG_CI
              ,BON.DESIGNATION_ARTICLE BON_DESIGNATION_ARTICLE
              ,BON.DESIGNATION_DOSSIER BON_DESIGNATION_DOSSIER
              ,BON.DB_BADGE_ID BON_DB_BADGE_ID
              ,BON.DB_BADGE_TABLE_CI BON_DB_BADGE_TABLE_CI
              ,BON.DB_CHAPITR_ID BON_DB_CHAPITR_ID
              ,BON.ETAT_BON BON_ETAT_BON
              ,BON.DO_LOTBON_ID BON_DO_LOTBON_ID
              ,BON.ETAT_DOSSIER BON_ETAT_DOSSIER
              ,DOS.ID DOS_ID
              ,DOS.DO_LOT_ENT_ID DOS_DO_LOT_ENT_ID
              ,DOS.SE_CAS_ID DOS_SE_CAS_ID
              ,DOS.INT_TIDENT_CI DOS_INT_TIDENT_CI
              ,DOS.INT_IDROLE_ID DOS_INT_IDROLE_ID
              ,DOS.AD_ADR_ID DOS_AD_ADR_ID
              ,DOS.TYPE_VALEUR_DOSS DOS_TYPE_VALEUR_DOSS
              ,DOS.CODE_RECAP DOS_CODE_RECAP
              ,DOS.TAUX_REMISE DOS_TAUX_REMISE
              ,DOS.AS_PROD_REMI_ID DOS_AS_PROD_REMI_ID
              ,DOS.TAUX_MAJO DOS_TAUX_MAJO
              ,DOS.AS_PROD_MAJO_ID DOS_AS_PROD_MAJO_ID
              ,DOS.AS_LIBPRIX_ID DOS_AS_LIBPRIX_ID
              ,DOS.CO_COND_PMT_ID DOS_CO_COND_PMT_ID
              ,DOS.ETAT_DOSSIER DOS_ETAT_DOSSIER
              ,ENT.ID ENT_ID
              ,ENT.STATUS ENT_STATUS
              ,ENT.DO_DOCPROP_ID ENT_DO_DOCPROP_ID
              ,ENT.DO_DCMPPER_VARIANTE ENT_DO_DCMPPER_VARIANTE
              ,ENT.ABREGE ENT_ABREGE
              ,ENT.NOM ENT_NOM
              ,ENT.DATE_LOT ENT_DATE_LOT
              ,ENT.CODE_SOLDE ENT_CODE_SOLDE
              ,IDROLE.NOM_AFFICHE IDROLE_NOM_AFFICHE
              ,IDROLE.INT_IDENT_ID IDROLE_INT_IDENT_ID
              ,IDROLE.AD_ADR_ID IDROLE_AD_ADR_ID
              ,PROD.AS_FAMILLE_ID PROD_AS_FAM_ID
              ,PROD2.REFERENCE_INT_2 PROD2_REFERENCE_INT_2
        ,SE_CAS CAS
        ,DO_LOT_ENTETE ENT
        ,DO_LOT_BON BON
        ,AS_PRODUIT PROD
        ,AS_PRODUIT PROD2
    Parse        1      0.00       0.11          0          0          0           0
    Fetch        2      2.87       4.84      22568       7296          0          16
    total        5      2.87       4.96      22568       7296          0          16
         16  HASH JOIN
       2636   TABLE ACCESS FULL DO_LOT_ENTETE
         16   HASH JOIN OUTER
     221227    HASH JOIN OUTER
     221227     HASH JOIN
      37568      HASH JOIN
      18349       TABLE ACCESS FULL SE_CAS
      37568       HASH JOIN
       7246        TABLE ACCESS FULL INT_IDENT_ROLE
      37568        TABLE ACCESS FULL DO_LOT_DOSSIER
       3822     TABLE ACCESS FULL AS_PRODUIT
    Rows     Execution Plan
         16   HASH JOIN
       2636    TABLE ACCESS   GOAL: ANALYZED (FULL) OF 'DO_LOT_ENTETE'
         16    HASH JOIN (OUTER)
     221227     HASH JOIN (OUTER)
     221227      HASH JOIN
      37568       HASH JOIN
      18349        TABLE ACCESS   GOAL: ANALYZED (FULL) OF 'SE_CAS'
      37568        HASH JOIN
       7246         TABLE ACCESS   GOAL: ANALYZED (FULL) OF
                        'INT_IDENT_ROLE'
      37568         TABLE ACCESS   GOAL: ANALYZED (FULL) OF
                        'DO_LOT_DOSSIER'
     221244       TABLE ACCESS   GOAL: ANALYZED (FULL) OF 'DO_LOT_BON'
       3822      TABLE ACCESS   GOAL: ANALYZED (FULL) OF 'AS_PRODUIT'
    Le temps est encore de presque 5s et j'ai recalulé les statistiques avec "compute" sur le schéma.
    Comment puis-je descendre ce temps?
    Quelqu'un a-t-il une idée?
    Avatar de orafrance
    Janvier 2004
    c'est pas suffisant 5s ? Essaye avec le hint FIRST_ROWS pour voir ce que ça donne sans les HASH JOIN.
    Septembre 2006
    Je dois descendre le plus bas possible!
    Avec la clause FIRST_ROW :
    119
    120
    121
    122
    123
    124
    125
    126
    127
    128
    129
    130
    131
    132
    133
    134
    135
    136
    137
    138
    139
    140
    141
    142
    143
    144
    145
    146
    147
    148
    149
    150
    151
    152
    153
    154
    155
    156
    157
    158
    159
    160
    161
    162
    SELECT /*+ FIRST_ROWS*/ CAS.TITRE CAS_TITRE
              ,BON.ID BON_ID
              ,DOS.ID DOS_ID
              ,ENT.ID ENT_ID
              ,ENT.NOM ENT_NOM
        ,SE_CAS CAS
        ,DO_LOT_ENTETE ENT
        ,DO_LOT_BON BON
        ,AS_PRODUIT PROD
        ,AS_PRODUIT PROD2
    Parse        1      0.00       0.09          0          0          0           0
    Execute      1      0.00       0.00          0          0          0           0
    Fetch        2      0.00       0.10         43        218          0          16
    total        4      0.00       0.19         43        218          0          16
    Optimizer goal: FIRST_ROWS
         16  NESTED LOOPS OUTER
         16    NESTED LOOPS
         16     NESTED LOOPS
          6      NESTED LOOPS
          6       NESTED LOOPS
          6        TABLE ACCESS FULL DO_LOT_DOSSIER
          6        TABLE ACCESS BY INDEX ROWID INT_IDENT_ROLE
          6         INDEX UNIQUE SCAN INT_IDROLE_PK (object id 8154)
          6       TABLE ACCESS BY INDEX ROWID SE_CAS
          6        INDEX UNIQUE SCAN SE_INTERV_PK (object id 9027)
         16      TABLE ACCESS BY INDEX ROWID DO_LOT_BON
       1225       INDEX RANGE SCAN DO_LOT_BON_LOT_ENT_IDX (object id 7764)
         16     TABLE ACCESS BY INDEX ROWID DO_LOT_ENTETE
         16      INDEX UNIQUE SCAN DO_LOT_ENT_PK (object id 7773)
         16    TABLE ACCESS BY INDEX ROWID AS_PRODUIT
         16     INDEX UNIQUE SCAN AS_PROD_PK (object id 6579)
    Rows     Execution Plan
          0  SELECT STATEMENT   GOAL: HINT: FIRST_ROWS
         16   NESTED LOOPS (OUTER)
         16     NESTED LOOPS
         16      NESTED LOOPS
          6       NESTED LOOPS
          6        NESTED LOOPS
                        'DO_LOT_DOSSIER'
          6         TABLE ACCESS   GOAL: ANALYZED (BY INDEX ROWID) OF
                        'INT_IDENT_ROLE'
          6          INDEX   GOAL: ANALYZED (UNIQUE SCAN) OF
                         'INT_IDROLE_PK' (UNIQUE)
                       'SE_CAS'
                        'SE_INTERV_PK' (UNIQUE)
         16       TABLE ACCESS   GOAL: ANALYZED (BY INDEX ROWID) OF
                      'DO_LOT_BON'
       1225        INDEX   GOAL: ANALYZED (RANGE SCAN) OF
                       'DO_LOT_BON_LOT_ENT_IDX' (NON-UNIQUE)
                     'DO_LOT_ENTETE'
         16       INDEX   GOAL: ANALYZED (UNIQUE SCAN) OF 'DO_LOT_ENT_PK'
                      (UNIQUE)
                    'AS_PRODUIT'
         16      INDEX   GOAL: ANALYZED (UNIQUE SCAN) OF 'AS_PROD_PK'
                     (UNIQUE)
                   'AS_PRODUIT'
         16     INDEX   GOAL: ANALYZED (UNIQUE SCAN) OF 'AS_PROD_PK' (UNIQUE)
    Le problème exacte est le suivant :
    Il y a une vue principale constitué de deux vues (je suis actuellement en train de vérifier si on ne peut pas mettre les deux vues ensemble). La vue que l'on essaye d'optimiser est un des "composant" de la vue principal.
    Décembre 2007
    Ceci veut dire que les stats ont été calculées en utilisant ANALYZE ?
    Si la réponse est oui alors il est temps de basculer vers dbms_stats.
    Décembre 2007
    Citation Envoyé par McM Voir le message
    "bon" doit être accédé en entier de toute façon à cause de la jointure externe ...
    Avatar de orafrance
    Janvier 2004
    Et comment tu arrives à savoir quand une requête ne peut pas être mieux optimisé ? Le plus rapide possible ça n'existe pas... sinon dans 2 mois t'es encore sur ta requête. Il faut absolument déterminer un temps acceptable.
    Apparemment avec FIRST_ROWS c'est plus rapide non ?
    Citation Envoyé par Michel SALAIS Voir le message
    Pas forcément, DBMS_STATS permet aussi de faire du compute
    McM
    McM est déconnecté
    Développeur Oracle
    Juillet 2003
    Ah bon ?! Je ne vois aucune raison à ça.
    Voici un exemple : Table FCLIENT et jointure externe sur parametre (PK)
    SELECT *
    FROM fclient a, param_sl p
    WHERE a.ste = 18 AND a.client = 18157
    AND p.ste (+) = a.ste
    AND p.TYPE (+) = a.t44
    AND p.num (+) = a.pays
    Operation	Object Name	Rows	Bytes	Cost	Object Node	In/Out	PStart	PStop
    SELECT STATEMENT Optimizer Mode=CHOOSE		1  	 	3
      NESTED LOOPS OUTER		1  	484  	3
        TABLE ACCESS BY INDEX ROWID	SERCA.FCLIENT	1  	450  	2
          INDEX RANGE SCAN	SERCA.FCLIENT_I1	1  	 	1
        TABLE ACCESS BY INDEX ROWID	SERCA.PARAM_SL	1  	34  	1
          INDEX UNIQUE SCAN	SERCA.PARAM_SL_PK	1
    Octobre 2007
    Je ne vois pas bien à quoi ça sert de optimiser la requête qui va créer la vue. Cette optimisation n’est pas de toute une garantie d’un bon plan d’exécution au moment de l’utilisation de la vue par des autres requêtes. Peut être si c’était une vue matérialisée, mais il ne semble pas être le cas. Mettre des hints dans la vue c’est plutôt un moyen de chercher des ennuis (pour orafrance, cella ne dit pas que ta demande d’utiliser le hint n’est pas justifié à cette étape).
    Avatar de orafrance
    Janvier 2004
    pour orafrance, cella ne dit pas que ta demande d’utiliser le hint n’est pas justifié à cette étape.
    en effet, j'avais juste pour objectif de proscrire les hash joins pour voir ce que ça donne
    Ceci étant, je suis d'accord, une mauvaise requête dans une vue peut être très performantes selon comment on joins la vue lors de son utilisation
    Mai 2007
    salut,
    d'apres ce que je vois sur ta requette, il est normal que le plan d'execution te retourne un FULL car tu n'a pas de close where filtrante. en effet ta vue contient TOUT les elements de ta table DO_LOT_BON. Donc, il Oracle n'a aucune raison d'utiliser un index (vu que toute les lignes sont retenues).
    par contre quand tu feras une requette sur ta vue avec une clause Where, le plan d'execution devrais changer pour utiliser l'index qui va bien (en relation avec ta clause where).
    fait ta vue telle que tu l'a définie dans le premier post.
    puis requette where DO_LOT_BON.X = z
    avec un index sur X.
    ton plan d'execution devrais utiliser l'index et le FULL devrais disparaitre...
    P.
    Décembre 2007
    Citation Envoyé par orafrance Voir le message
    Je le sais bien mais le mot n'est pas dans la syntaxe d'où ma question ...
    Décembre 2007
    SELECT *
    Dans l'exemple ici tu ajoute un critère sur la table concernée ce qui n'existe pas dans la requête traitée dans ce rubrique ...
    Septembre 2006
    Déjà merci à tous,
    Le temps doit être le plus bas possible car cette vue entre dans processus de calcul. Ce processus actuellement prend 1h pour générer une 100 de facture d'une centaine de ligne ce qui tout simplement innacpetable pour le client.
    J'ai également lancé une trace Oracle pour voir qu'elles seraient les requêtes qui pourraient poser problème. De là, j'en ai tiré un index qui manquait, malgré cela, c'est toujours trop lent.
    Donc comme cette vue est lente, j'aimerais l'optimiser pour voir si elle a une influence significative.
    @Orafrance tu proposes d'utiliser les hints clause tel que "FIRST_ROW" et n'est-il plus supporté par Oracle 10g?
    Avatar de orafrance
    Janvier 2004
    Au contraire, en 10g il me semble que c'est même la valeur de l'OPTIMIZER_MODE par défaut
  1. [Access] Optimisation performance requête - Index
    Par fdraven dans le forum Access
    Dernier message: 12/08/2005, 15h30
  2. Optimisation de requête avec Tkprof
    Par stingrayjo dans le forum Oracle
    Dernier message: 04/07/2005, 10h50
  3. Optimiser une requête SQL d'un moteur de recherche
    Par kibodio dans le forum Langage SQL
    Dernier message: 06/03/2005, 21h55
  4. optimisation des requêtes
    Par yech dans le forum PostgreSQL
    Dernier message: 21/09/2004, 20h03
  5. Optimisation de requête
    Par olivierN dans le forum SQL
    Dernier message: 16/12/2003, 11h09
