encore un probleme de picking :)
    Membre confirmé Avatar de shams
    Juillet 2005
    Par défaut encore un probleme de picking :)
    bonjour à tous,
    j'ai (encore) un petit soucis avec mon picking. Je découvre SDL, et j'utilise la freeFlyCamera. J'avais déjà réussi a faire fonctionner le picking auparavant, mais la... aucune idée de ce qui cloche.
    Tout part de la!
    int main( int narg, char **argv)
    	width = LARGEUR_FENETRE;
    	height = HAUTEUR_FENETRE;
    	// Init SDL video subsystem
    	if ( SDL_Init (SDL_INIT_VIDEO) < 0 )
            fprintf(stderr, "Couldn't initialize SDL: %s\n", SDL_GetError());
    		exit(1);
        // Set GL context attributes
        initAttributes ();
        // Create GL context
        createSurface (0);
        // Init GL state
        initGL ();
        // Draw, get events...
        mainLoop ();
        // Cleanup
    	SDL_Quit();
    	return 0;
    les principales fonctions
    119
    120
    121
    122
    123
    124
    125
    126
    127
    128
    static void initGL ()
        initTerrain();
        redim (gScreen->w, gScreen->h);
    	glMatrixMode( GL_PROJECTION );
        glLoadIdentity( );
        gluPerspective(60,(double)width/height,0.001,200000);
    	camera = new FreeFlyCamera(Vector3D(0,0,2));
    static void mainLoop ()
        SDL_Event event;
        int done = 0;
        const Uint32 time_per_frame = 1000/FPS;
        Uint32 last_time,current_time,elapsed_time; //for time animation
        Uint32 start_time,stop_time; //for frame limit
    	last_time = SDL_GetTicks();
        while ( !done )
    		start_time = SDL_GetTicks();
    		/* Check for events */
    		while ( SDL_PollEvent (&event) )
    			switch (event.type)
    				case SDL_QUIT:	done = 1;	break;
    				case SDL_MOUSEMOTION:	if (!modeSelect) camera->OnMouseMotion(event.motion);
                                                              else   camera->OnMouseMotion2(event.motion);	break;
    				case SDL_MOUSEBUTTONUP:
    				case SDL_MOUSEBUTTONDOWN: if (!modeSelect)	camera->OnMouseButton(event.button);
                                                              else  camera->OnMouseButton2(event.button);	break;
    				case SDL_KEYUP:	 camera->OnKeyboard(event.key); break;
    				case SDL_KEYDOWN:
    						switch (event.key.keysym.sym)
    							case SDLK_p:		takeScreenshot("test.bmp");		break;
    							case SDLK_m:		modeSelect = !modeSelect;
    									if (!modeSelect)	SDL_ShowCursor(SDL_DISABLE);
    									else				SDL_ShowCursor(SDL_ENABLE);
    												break;
    							case SDLK_ESCAPE:	exit(0);						break;
    							default :			camera->OnKeyboard(event.key);
    						break;
    				default:	break;
    	current_time = SDL_GetTicks();
            elapsed_time = current_time - last_time;
            last_time = current_time;
    	camera->animate(elapsed_time);
    	// Affichage de la scène
            affichage ();
    	stop_time = SDL_GetTicks();
            if ((stop_time - last_time) < time_per_frame)
                SDL_Delay(time_per_frame - (stop_time - last_time));
    void affichage (void)
    	static double th[4] = {0.0, 0.0, 0.0, 0.0};
    	static double t1 = 0.0, t2 = 0.0, t;
    	char num_str[128];
    	t1 = t2;
    	glClearColor(0,0,0,0);
    	glClear( GL_COLOR_BUFFER_BIT | GL_DEPTH_BUFFER_BIT );
    	// mise en place du Z-BUFFER
        glEnable (GL_DEPTH_TEST);
    	glPushMatrix();
    	glMatrixMode (GL_PROJECTION);
    		glLoadIdentity();
    		glOrtho(0, width, 0, height, -10.0, 10.0);
    		glRasterPos2f(5.0, 5.0);
    		t2 = mtime();
    		t = t2 - t1;
    		if(t > 0.0001) t = 1.0 / t;
    		glColor3f( 0.0, 0.0, 1.0 );
    		sprintf(num_str, "%0.2f FPS ", filter(t, th));
    		DrawStr(num_str);
    	glPopMatrix();
    	glPushMatrix();
    	camera->look();
    	dessineTerrain();
    	if (modeSelect)	dessinePoint();
    	glPopMatrix();
    	glFlush();
        SDL_GL_SwapBuffers();
    void redim (int x , int y)
    	if (y == 0 || x == 0) return;
    	//Set a new projection matrix
    	glMatrixMode(GL_PROJECTION);
    	glLoadIdentity();
    	glMatrixMode(GL_MODELVIEW);
    	glViewport(0,0,x,y);  //Use the whole window for rendering
    et les fonctions de picking
    void select (int x, int y)
        GLuint selectBuf[1024];
        GLint hits=0;
        GLint viewport[4];
        glGetIntegerv (GL_VIEWPORT, viewport);
        glSelectBuffer (1024, selectBuf);
        (void) glRenderMode (GL_SELECT);
        glInitNames();
        glPushName(0);
    	glPushMatrix ();                 // push projection
    	glLoadIdentity ();
    	gluPickMatrix((GLdouble) x, (GLdouble) (viewport[3] - y), 5.0, 5.0, viewport);
    	picking = true;
    	dessineTerrain();
    	picking = false;
        glPopMatrix ();        // pop projection
        glFlush();
        hits = glRenderMode (GL_RENDER);
        processHits (hits, selectBuf);
        glutPostRedisplay();
    Juillet 2005
    une fois de plus, on n'est jamais mieux servi que par soit meme:
        GLint hits=0;
        GLint viewport[4];
        glInitNames();
        glPushName(0);
    		glLoadIdentity ();
    		glPushMatrix();        /* push modelview */
    			glLoadIdentity();
    			camera->look();
    			picking = true;
    			dessineTerrain();
    			picking = false;
    		glPopMatrix (); // pop modelview
    	glFlush();
    Juillet 2005
    en fait, il me reste encore un souci. J'arrive bien à clicker sur mes sommets. Mais le numéro retourné part en vrille. Pour les premiers, c'est ok, et à partir de 255, il recommence à zéro!
    Pourtant dans la fonction où est appelé "glLoadName", le "i" s'incrémente correctement...
    Avez-vous déjà eu ce genre de souci?
    Juillet 2005
    bon je rajoute un élément au problème; Voila comment je regarde s'il y a un truc sous la souris:
    void processHits (GLint hits, GLuint buffer[])
    	for (int i = 0; i < hits; i++)
    		trouve = true;
    		pointCourant = (GLubyte)buffer[i * 4 + 3];
    		printf(	"Number: %d\n""Min Z: %d\n""Max Z: %d\n""Name on stack: %d\n",(GLubyte)buffer[i * 4],(GLubyte)buffer[i * 4 + 1],(GLubyte)buffer[i * 4 + 2],(GLubyte)buffer[i * 4 + 3]);
    	if (hits == 0)
    		printf("Rien du tout sous la souris\n");
    		trouve = false;
    Avatar de fearyourself
    Décembre 2005
    Quelques questions :
    - Pourquoi est-ce que je vois du code SDL et du code glut ? (Il y a un appel glutPostRedisplay)
    - C'est une mauvaise idée d'avoir des variables globales (variable trouve dans processHits par exemple).
    - Il faudrait voir un code complet pour vraiment répondre correctement à la question. Mais il me semble qu'il y a un maximum de noms que tu peux utiliser pour le picking. Du coup, tu ne peux pas t'amuser à avoir 10000 noms différents. A mon souvenir, glGetIntegerv(GL_NAME_STACK_DEPTH) te retourne la profondeur de la pile et donc le nombre maximum (ou la puissance de 2) que tu peux donner a glPushName. Donc il faut faire attention à comment tu fais ton code de rendu select.
    Jc
    Juillet 2005
    Citation Envoyé par fearyourself Voir le message
    une erreur dans le copier/coller!
    tres juste, mais on va deja essayer de faire un picking qui marche, on verra après pour le code hyper pro sans faute
    je vais regarder de ce coté alors, mais ca serait drolement chiant si c'était limité à 255 noms! Ca fait drôlement pas beaucoup!
  1. [MySQL] encore un probleme php mysql
    Par ph_anrys dans le forum PHP & Base de données
    Dernier message: 02/03/2006, 16h14
  2. Et oui encore un probleme d'icone dans une Jframe
    Par frett dans le forum Agents de placement/Fenêtres
    Dernier message: 17/02/2006, 15h12
  3. Encore un probleme
    Par lord jere dans le forum SQL Procédural
    Dernier message: 30/01/2006, 16h40
  4. Encors un problem avec IE
    Par Death83 dans le forum Balisage (X)HTML et validation W3C
    Dernier message: 24/10/2005, 16h55
  5. Réponses: 7
    Dernier message: 16/07/2004, 13h24
