probleme de compilation
    Septembre 2006
    Par défaut probleme de compilation
    quan j'esseye de compiler
    119
    120
    121
    #include <SDL/SDL.h>
    #include <GL/gl.h>
    #include <GL/glu.h>
    #include <cstdlib>
    void Dessiner();
    double angleZ = 0;
    double angleX = 0;
    int main(int argc, char *argv[])
        SDL_Event event;
        SDL_Init(SDL_INIT_VIDEO);
        atexit(SDL_Quit);
        SDL_WM_SetCaption("SDL GL Application", NULL);
        SDL_SetVideoMode(640, 480, 32, SDL_OPENGL);
        glMatrixMode( GL_PROJECTION );
        glLoadIdentity();
        gluPerspective(70,(double)640/480,1,1000);
        glEnable(GL_DEPTH_TEST);
        Dessiner();
        Uint32 last_time = SDL_GetTicks();
        Uint32 current_time,ellapsed_time;
        Uint32 start_time;
        for (;;)
            start_time = SDL_GetTicks();
            while (SDL_PollEvent(&event))
                switch(event.type)
                    case SDL_QUIT:
                    exit(0);
                    break;
            current_time = SDL_GetTicks();
            ellapsed_time = current_time - last_time;
            last_time = current_time;
            angleZ += 0.05 * ellapsed_time;
            angleX += 0.05 * ellapsed_time;
            Dessiner();
            ellapsed_time = SDL_GetTicks() - start_time;
            if (ellapsed_time < 10)
                SDL_Delay(10 - ellapsed_time);
        return 0;
    void Dessiner()
        glClear( GL_COLOR_BUFFER_BIT | GL_DEPTH_BUFFER_BIT );
        glMatrixMode( GL_MODELVIEW );
        glLoadIdentity( );
        gluLookAt(3,4,2,0,0,0,0,0,1);
        glRotated(angleZ,0,0,1);
        glRotated(angleX,1,0,0);
        glBegin(GL_QUADS);
        glColor3ub(255,0,0); //face rouge
        glVertex3d(1,1,1);
        glVertex3d(1,1,-1);
        glVertex3d(-1,1,-1);
        glVertex3d(-1,1,1);
        glColor3ub(0,255,0); //face verte
        glVertex3d(1,-1,1);
        glVertex3d(1,-1,-1);
        glVertex3d(1,1,-1);
        glVertex3d(1,1,1);
        glColor3ub(0,0,255); //face bleue
        glVertex3d(-1,-1,1);
        glVertex3d(-1,-1,-1);
        glVertex3d(1,-1,1);
        glColor3ub(255,255,0); //face jaune
        glVertex3d(-1,1,1);
        glColor3ub(0,255,255); //face cyan
        glVertex3d(1,1,-1);
        glColor3ub(255,0,255); //face magenta
        glVertex3d(1,-1,1);
        glVertex3d(1,1,1);
        glVertex3d(-1,1,1);
        glEnd();
        glFlush();
        SDL_GL_SwapBuffers();
    il me dise ceci comme error
    [Linker error] undefined reference to `gluPerspective@32'
    [Linker error] undefined reference to `gluLookAt@72'
    ld returned 1 exit status
    *** [2.exe] Error 1
    je suis debutant donc je ne comprend po tres bien l'error
    Avatar de fearyourself
    Décembre 2005
    Il faut ajouter à l'édition des liens la bibliothèque glu
    Cela dépend de ton compilateur, tu utilises quoi ?
    Jc
    Septembre 2006
    j'utilice dev-c++
    Décembre 2005
    Citation Envoyé par vanianuno
    j'utilice dev-c++
    Dans les options de compilation, trouve l'endroit qui parle d'édition de liens et ajoute -lglu
    (ou -lglu32, je ne sais jamais sous windows...)
    Cela devrait résoudre ton problème...
    Jc
    Septembre 2006
    merci pour la solution j'ai reussi a compiler mon code
  1. [API][Cup] problem niveau compilation
    Par KoLziG dans le forum Général Java
    Dernier message: 02/01/2005, 20h30
  2. [JSP & TAGLIB] Probleme de compilation
    Par GesMo dans le forum Servlets/JSP
    Dernier message: 17/05/2004, 16h03
  3. Probleme de Compilation de la STL
    Par stoluup dans le forum MFC
    Dernier message: 05/05/2004, 18h25
  4. [TP]Probleme de compilation sous TP7
    Par yffick dans le forum Turbo Pascal
    Dernier message: 18/12/2003, 21h32
  5. Problemes de compilation avec g++ sous linux
    Par Selimmel dans le forum Autres éditeurs
    Dernier message: 19/09/2003, 14h43
