Insert into + Case
    Membre Expert Avatar de QuestVba
    Enseignant
    Juillet 2012
    Activité : Enseignant
    Secteur : Service public
    Par défaut Insert into + Case
    Re- Forum,
    Je veux créer une table temporaire mais elle bloque à l'insertion à cause d'un CASE. Si je supprime la partie CASE, tout fonctionne parfaitement.
    Pouvez-vous me dire ce que je peux faire pour résoudre ce problème ?
    INSERT INTO TMP_PERIOD
    	VALUES
    	TO_NUMBER(TO_CHAR(ADD_MONTHS(TO_DATE(CURRENT_DATE), - 1),'yyyymm')),
    	TO_NUMBER(TO_CHAR(TO_DATE(CURRENT_DATE),'yyyymm')),
    	TO_NUMBER(TO_CHAR(ADD_MONTHS(TO_DATE(CURRENT_DATE),-12),'yyyy')),
    	TO_NUMBER(TO_CHAR(TO_DATE(CURRENT_DATE),'yyyy')),
    	TO_NUMBER(TO_CHAR(ADD_MONTHS(TO_DATE(CURRENT_DATE),-1),'mm')),
    	TO_NUMBER(TO_CHAR(TO_DATE(CURRENT_DATE),'mm')),
    	TO_NUMBER(TO_CHAR(ADD_MONTHS(TRUNC(CURRENT_DATE,'YYYY'),-12),'yyyymmdd')),
    	TO_NUMBER(TO_CHAR(TRUNC(CURRENT_DATE,'YYYY'), 'yyyymmdd')),
    	TO_NUMBER(TO_CHAR(LAST_DAY(ADD_MONTHS(TRUNC(CURRENT_DATE,'YYYY'),-1)), 'yyyymmdd')),
    	TO_NUMBER(TO_CHAR(LAST_DAY(ADD_MONTHS(TRUNC(CURRENT_DATE,'YYYY'),+11)), 'yyyymmdd')),
    	TO_NUMBER(TO_CHAR(TO_DATE(ADD_MONTHS(LAST_DAY(CURRENT_DATE),-2)+1),'yyyymmdd')),
    	TO_NUMBER(TO_CHAR(TO_DATE(ADD_MONTHS(LAST_DAY(CURRENT_DATE),-1)+1),'yyyymmdd')),
    	TO_NUMBER(TO_CHAR(TO_DATE(LAST_DAY(ADD_MONTHS(CURRENT_DATE, -1))),'yyyymmdd')),
    	TO_NUMBER(TO_CHAR(TO_DATE(LAST_DAY(ADD_MONTHS(CURRENT_DATE, 0))),'yyyymmdd')),
    	TO_NUMBER(to_char(trunc(CURRENT_DATE,'IW')-7,'yyyymmdd')),
    	TO_NUMBER(to_char(trunc(CURRENT_DATE,'IW'),'yyyymmdd')),
    	TO_NUMBER(to_char(trunc(CURRENT_DATE,'IW')-1,'yyyymmdd')),
    	TO_NUMBER(to_char(trunc(CURRENT_DATE,'IW')+6,'yyyymmdd')),
    	TO_NUMBER(TO_CHAR(ADD_MONTHS(TRUNC(CURRENT_DATE, 'Q'), -3), 'yyyymmdd')),
    	TO_NUMBER(TO_CHAR(TRUNC(CURRENT_DATE , 'Q'), 'yyyymmdd')),
    	TO_NUMBER(TO_CHAR(TRUNC(CURRENT_DATE , 'Q')-1, 'yyyymmdd')),
    	TO_NUMBER(TO_CHAR(ADD_MONTHS(TRUNC(CURRENT_DATE, 'Q'), +3)-1, 'yyyymmdd')),
    	(CASE
    		WHEN CEIL(TO_NUMBER(TO_CHAR(TO_DATE(CURRENT_DATE),'mm'))/6) = 1 THEN TO_NUMBER(TO_CHAR(ADD_MONTHS(TRUNC(CURRENT_DATE,'YYYY'),-6), 'yyyymmdd'))
    		WHEN CEIL(TO_NUMBER(TO_CHAR(TO_DATE(CURRENT_DATE),'mm'))/6) = 2 THEN TO_NUMBER(TO_CHAR(TRUNC(CURRENT_DATE,'YYYY'), 'yyyymmdd'))
    	END)
    Développeur Oracle
    Décembre 2019
    Activité : Développeur Oracle
    Quelle est l'erreur que tu obtiens?
    Enseignant
    Juillet 2012
    Je dois mettre ceci
    	(SELECT CASE
    	END from dual)
    Développeur Oracle
    Décembre 2019
    Ok, je pense que si tu enlevais les parenthèses autour du CASE ça aurait dû fonctionner
  1. [MySQL-5.0] Switch boolean avec CASE et INSERT INTO
    Par coincoin22 dans le forum MySQL
    Dernier message: 26/02/2015, 16h57
  2. INSERT INTO avec une case à cocher
    Par JULIA_13 dans le forum VBA Access
    Dernier message: 29/06/2012, 14h06
  3. Réponses: 5
    Dernier message: 19/10/2006, 14h28
  4. erreur SQL ...INSERT INTO
    Par naidinp dans le forum ASP
    Réponses: 20
    Dernier message: 18/09/2003, 11h38
  5. Insert Into + Date
    Par BoeufBrocoli dans le forum SQL
    Dernier message: 13/08/2003, 11h23
