1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36
Option Explicit
Const HKEY_LOCAL_MACHINE = &H80000002
Const REG_MULTI_SZ = 7
Const BUFFER_SIZE = 255
Const READ_CONTROL = &H20000
Const KEY_QUERY_VALUE = &H1
Const KEY_SET_VALUE = &H2
Const KEY_CREATE_SUB_KEY = &H4
Const KEY_ENUMERATE_SUB_KEYS = &H8
Const KEY_NOTIFY = &H10
Const KEY_CREATE_LINK = &H20
Const KEY_READ = KEY_QUERY_VALUE + KEY_ENUMERATE_SUB_KEYS + KEY_NOTIFY + READ_CONTROL
Const KEY_WRITE = KEY_SET_VALUE + KEY_CREATE_SUB_KEY + READ_CONTROL
Const KEY_EXECUTE = KEY_READ
Const KEY_ALL_ACCESS = KEY_QUERY_VALUE + KEY_SET_VALUE + _
KEY_CREATE_SUB_KEY + KEY_ENUMERATE_SUB_KEYS + _
KEY_NOTIFY + KEY_CREATE_LINK + READ_CONTROL
Private Declare Function RegCloseKey Lib "advapi32" (ByVal hKey As Long) As Long
Private Declare Function RegOpenKeyEx Lib "advapi32" Alias "RegOpenKeyExA" (ByVal hKey As Long, ByVal lpSubKey As String, ByVal ulOptions As Long, ByVal samDesired As Long, ByRef phkResult As Long) As Long
Private Declare Function RegQueryValueEx Lib "advapi32" Alias "RegQueryValueExA" (ByVal hKey As Long, ByVal lpValueName As String, ByVal lpReserved As Long, ByRef lpType As Long, ByVal lpData As String, ByRef lpcbData As Long) As Long
Private Sub Command1_Click()
Dim Handle As Long
Dim DonneesValeur As String
Dim NBCaratères As Long
Dim Test As Long
If RegOpenKeyEx(HKEY_LOCAL_MACHINE, "HARDWARE\DESCRIPTION\system", 0, KEY_ALL_ACCESS, Handle) = 0 Then
DonneesValeur = Space(BUFFER_SIZE)
NBCaratères = BUFFER_SIZE
Test = RegQueryValueEx(Handle, "SystemBiosVersion", 0, REG_MULTI_SZ, DonneesValeur, NBCaratères)
MsgBox ("Votre version du Bios est: " & DonneesValeur)
RegCloseKey (Handle)
End If
End Sub |
