Problème avec un ListSelectionListener
    Avatar de Orian
    Août 2006
    Par défaut Problème avec un ListSelectionListener
    Lors de l'initialisation de ma classe (un JDialog contenant une JList), j'ai une Exception :
    Exception in thread "AWT-EventQueue-0" java.lang.NullPointerException
            at gui.dialog.NewFileWizard2.<init>(NewFileWizard2.java:246)
            at action.Dialog.showNewFileWizard(Dialog.java:40)
            at gui.dialog.NewFileWizard1$4.actionPerformed(NewFileWizard1.java:240)
            at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:1849)
            at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2169)
            at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:420)
            at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:258)
            at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(BasicButtonListener.java:234)
            at java.awt.Component.processMouseEvent(Component.java:5488)
            at javax.swing.JComponent.processMouseEvent(JComponent.java:3126)
            at java.awt.Component.processEvent(Component.java:5253)
            at java.awt.Container.processEvent(Container.java:1966)
            at java.awt.Component.dispatchEventImpl(Component.java:3955)
            at java.awt.Container.dispatchEventImpl(Container.java:2024)
            at java.awt.Component.dispatchEvent(Component.java:3803)
            at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4212)
            at java.awt.LightweightDispatcher.processMouseEvent(Container.java:3892)
            at java.awt.LightweightDispatcher.dispatchEvent(Container.java:3822)
            at java.awt.Container.dispatchEventImpl(Container.java:2010)
            at java.awt.Window.dispatchEventImpl(Window.java:1774)
            at java.awt.EventQueue.dispatchEvent(EventQueue.java:463)
            at java.awt.EventDispatchThread.pumpOneEventForHierarchy(EventDispatchThread.java:242)
            at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:163)
            at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:157)
            at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:149)
            at java.awt.EventDispatchThread.run(EventDispatchThread.java:110)
    J'ai découvert que cela veneai de mon ListSelectionListener dont voici le code.
    //Si on selectionne un objet dans la liste
            lstActivite.addListSelectionListener(new ListSelectionListener() {
                public void valueChanged(ListSelectionEvent e) {
                    // Recupere la valeur de l'objet et la convertit en chaine'
                    String value = String.valueOf(lstActivite.getSelectedValue());
                    // place la valeur dans le champs valeur
                    fldValeur.setText(value);
    J'utlise un DefaultListModel, et je pense que ça vient de là car quand j'utilise un AbstractListModel tout se passe sans problème.
    Hors, j'ai d'un DefaultListModel afin de pouvoir ajouter des éléments à ma JList.
    Merci de bien vouloir m'éclairer
    Avatar de afrikha
    Août 2005
    Citation Envoyé par Orian
    Personellement j'utilise un AbstractListModel auquel j'ajoute une méthode pour modifer les éléments qui a à peu près cette tête :
    public void setData(Donnees d) {
            this.data = d;
            //on avertit la liste que le modèle a changé
            this.fireContentsChanged(this,0,this.getSize()-1);
    Voilà, en esperant t'avoir aidé.
    Mes publications
    Lisez
    Les régles du forum
    Pensez au bouton
    Avatar de Orian
    Août 2006
    Bon je crois que ça m'aide...Mais peut tu m'expliquer le parce que je comprend pas...Et netbeans non plus...
    Avatar de afrikha
    Août 2005
    c'est juste un exemple ça...
    data represente les données de ton modèle, ça peut étre des string,des double,...
    Supposons que ta JList affiche une liste de nom, des string donc.
    Ton modèle a alors comme attribut une liste de string, par exemple un tableau qu'on nommera donnees.
    La méthode devient alors :
    public void setData(String[] d) {
            this.donnees = d;
    Mes publications
    Lisez
    Les régles du forum
    Pensez au bouton
    Avatar de Orian
    Août 2006
    Désolé je pose des bêtes question mais je rame...Je ne dois plus être habitué à la chaleur...
    Où je met ça et comment je l'appelle ? (sous entendu la méthode que tu me donne).
    Merci er désolé si je t'embête...
    Avatar de seiryujay
    Mars 2004
    Moi aussi j'aime bien poser des questions bêtes : ton exception pointe vers quelle ligne?
    Ce ne serait pas celle-là
    avec un
    qui serait null et une méthode qui crasherait?...
    Sinon pour te répondre, si tu utilises la méthode d'afrikha, tu dois créer une classe qui étend AbstractListModel et tu ajoutes la méthode dans cette classe.
    Après, tu l'appelles quand tu veux modifier les données de ta liste, en passant en paramètre toutes les données que doit contenir ta liste.
  1. Problème avec un ListSelectionListener (CastException!)
    Par bakaratoun dans le forum Composants
    Dernier message: 27/02/2009, 01h11
  2. VC++ Direct3D8, problème avec LPD3DXFONT et LPD3DTEXTURE8
    Dernier message: 03/08/2002, 12h10
    Dernier message: 14/07/2002, 19h48
    Réponses: 13
