J'ai une erreur sur ce script avec le message
File "D:\Utilisateurs\Genius\Documents\Programmation\database_parser_IL2_Great_Battles.py", line 521, in <module>
SET bombs_kg = payload_bombs(Planes.aircraft_name, Planes.payload_id);''')
sqlite3.OperationalError: no such function: payload_bombs
    cur.execute('''UPDATE Planes
pourtant j'importe bien toutes mes fonctions au préalable:
from aircraft_payloads import *
Voici un extrait de mes fonctions dans le fichier aircraft_payloads:
def payload_name (aircraft_name, payload_id):
    """Extraction of the payload name"""
    try:
        b = aircraft_payload[aircraft_name]
    except:
        print("unknow plane")
    else:
        try:
            c = (b[payload_id])
        except:
            print("unknow payload")
        else:
            print (c[1])
            return (c[1])
def payload_bombs (aircraft_name, payload_id):
    """Extraction of the bombs Weight"""
    try:
    except:
    else:
        try:
            c = (b[payload_id])
        except:
        else:
            print (c[2])
            return (c[2])
def payload_rockets (aircraft_name, payload_id):
    """Extraction of the rockets Weight"""
    try:
    except:
    else:
        try:
            c = (b[payload_id])
        except:
        else:
            print (c[3])
            return (c[3])
Auriez-vous un conseil ?
