prob de placage de texture en 2d
    Juin 2006
    Par défaut prob de placage de texture en 2d
    J'utilise sdl et opengl pour faire de la 2d. Pour les fonctions de 2d classiques, pas de problèmes (ligne, ellipses, rectangles, ...).
    Je cherche aussi a afficher des "sprites" (des surfaces SDL), mais il ne m'affiche qu'un quadrilatère blanc ....
    Le code :
    l'initialisation de l'écran
    		gluOrtho2D(0.0f, GLdouble(this->GetWidth()), GLdouble(this->GetHeight()), 0.0f);
    		// enable blending, should work like 2d sdl does
    		glEnable(GL_BLEND);
    		glBlendFunc(GL_SRC_ALPHA, GL_ONE_MINUS_SRC_ALPHA);
    		// enable anti-aliasing
    		glEnable(GL_POINT_SMOOTH);
    		glEnable(GL_LINE_SMOOTH);
    		glShadeModel(GL_SMOOTH);
    		glPolygonMode(GL_FRONT_AND_BACK, GL_FILL);
    l'affichage du "sprite"
    	if (surface->flags & SDL_OPENGL)
    		ManageTexture();
    		glTexImage2D(GL_TEXTURE_2D, 0, GL_RGBA, hTexture->w, hTexture->h, 0, GL_RGBA,
    			GL_UNSIGNED_BYTE, hTexture->pixels);
    		glBegin(GL_QUADS);
    		glTexCoord2f(0, 0);
    		glVertex2d(x, y);
    		glTexCoord2f(0, hTexWidth);
    		glVertex2d(x + hSurface->w, y);
    		glTexCoord2f(hTexHeight, hTexWidth);
    		glVertex2d(x + hSurface->w, y + hSurface->h);
    		glTexCoord2f(hTexHeight, 0);
    		glVertex2d(x, y + hSurface->h);
    		glEnd();
    		return;
    static int GetPowerSize(int value)
    	int result = 0, count = 0;
    	while (result < value)
    		result = int(pow (2, count));
    		count++;
    	return (result);
    void SDLgfx::ManageTexture()
    	/* hTexture is of 2 power of n size so if hSurface is equal or smaller
    	than hTexture then there is no need to redefine it, only clean it and blit
    	hSurface into hTexture
    	hTexture is of RGBA (32 bits) format */
    	/* define the size of hTexture */
    	int texHeight = GetPowerSize(hSurface->h);
    	int texWidth = GetPowerSize(hSurface->w);
    	/* define hTexture if it isn't */
    	if (!hTexture)
    		hTexture = SDL_CreateRGBSurface(SDL_SWSURFACE, texWidth, texHeight, 32, 0, 0, 0, 0);
    		hTextureStatus = TEX_TO_RELOAD;
    	/* do we need to resize hTexture ? */
    	if (((hSurface->w) > (hTexture->w)) || ((hSurface->h) > (hTexture->h)))
    		SDL_FreeSurface(hTexture);
    	if (hTextureStatus & TEX_TO_RELOAD)
    		SDL_FillRect(hTexture, NULL, 0);
    		SDL_BlitSurface(hSurface, NULL, hTexture, NULL);
    	/* ratio for the texture coords */
    	hTexWidth = GLdouble(hSurface->w) / hTexture->w;
    	hTexHeight = GLdouble(hSurface->h) / hTexture->h;
    Merci pour votre aide
    Avatar de fearyourself
    Décembre 2005
    Je conseille de regarder ici :
    http://jeux.developpez.com/faq/sdl/?...PENGL_textures
    1) Il faut générer un indice pour la texture
    2) Utiliser glBindTexture pour dire quel indice on utilise
    3) Créer la texture
    Pour le moment, tu vérifies les dimensions de la texture -> c'est bien
    Par contre tu charges la texture à chaque affichage -> pas bien
    Jc
    Membre expérimenté Avatar de Sixissor
    Février 2006
    Salut.
    Un petit problème:
    glTexImage2D(GL_TEXTURE_2D, 0, GL_RGBA, hTexture->w, hTexture->h, 0, GL_RGBA, GL_UNSIGNED_BYTE, hTexture->pixels);
    	glBegin(GL_QUADS);
    	    glTexCoord2f(0, 0);
    	    glVertex2d(x, y);
    	glEnd();
    Tu inverses les coordonnées de textures X et Y.
    Remplaces ton code d'affichage par ça:
    	glBegin(GL_QUADS);
    	    glTexCoord2f(0, 0);
    	    glVertex2d(x, y);
    	    glTexCoord2f(hTexWidth, 0);
    	    glTexCoord2f(hTexWidth, hTexHeight);
    	    glTexCoord2f(0, hTexHeight);
    	glEnd();
    Ca empeche pas de voir la texture mais ça la tourne.
    Ensuite y'a un truc qui me gêne beaucoup....
       return;
    Pourquoi un return ici ?
    Petite info:
    est inutile dans ton cas (sauf erreur de ma part). OpenGL assemble par défaut ses primitives, donc 1 ligne de code en moins
    Sinon fearyourself a dit pourquoi ça fonctionnait pas.
    PS: moyen la fonction ManageTexture(): y'a plus simple comme solution... Je te conseilles d'utiliser gluBuildMipmaps2D().
    Juin 2006
    Ok merci pour vos reponses pleines de sens
    Maintenant ça s'affiche
    void SDLgfx::Blit(SDL_Surface *surface, int x, int y)
    	if (!surface || !hSurface)
    		return;
    	// TODO if gl Window on other SDL_Surface
    	if (hSurface->flags & SDL_OPENGL)
    		return;
    	// gl Window
    		ManageTexture();
    		glBegin(GL_QUADS);
    		glTexCoord2f(0, 0);
    		glVertex2d(x, y);
    		glTexCoord2f(1, 0);
    		glTexCoord2f(1, 1);
    		glTexCoord2f(0, 1);
    		glEnd();
    	else
    		SDL_Rect dest;
    		dest.x = x;
    		dest.y = y;
    		if (SDL_BlitSurface(hSurface, NULL, surface, &dest)<0)
    			std::cout << "something goes wrong" << std::endl;
    	if (!hTextureIndex)
    		glGenTextures(1, &hTextureIndex);
    	glEnable(GL_TEXTURE_2D);
    	glBindTexture(GL_TEXTURE_2D, hTextureIndex);
    		gluBuild2DMipmaps(GL_TEXTURE_2D, 4, hSurface->h, hSurface->w, GL_RGBA,
    		GL_UNSIGNED_BYTE, hSurface->pixels);
    Pour info, ce pitit morceau de code c'est pour gambas http://gambas.sourceforge.net
  1. Objet en GL_TRIANGLES et placage de texture
    Par themoye dans le forum OpenGL
    Dernier message: 27/08/2009, 14h19
  2. [opengl] probleme d artefact au placage des textures
    Par ubenz dans le forum Moteurs 3D
    Dernier message: 07/11/2008, 12h23
  3. placage de textures
    Par xelif dans le forum Moteurs 3D
    Dernier message: 17/04/2008, 22h17
  4. Réponses: 5
    Dernier message: 18/12/2006, 17h02
  5. Placage de texture
    Par Teapot dans le forum OpenGL
    Réponses: 22
    Dernier message: 10/09/2006, 13h41
