probleme de vue
    Septembre 2004
    Par défaut probleme de vue
    j'ai créer une rue en opengl mais je n'en voit qu'une petite partie mais si j'avance, la rue apparait a la place du vide .
    que dois je faire pour voire ma rue en entier
    119
    120
    121
    122
    123
    124
    125
    126
    127
    128
    #include <windows.h>
    #include <gl/gl.h>
    #include <gl/glut.h>
    #define WIDTH 640
    #define HEIGHT 480
    int id_rue = 0;
    float viseex = 0,viseey = 0.0,viseez = -1.7142855 * 0.4;
    float emplacementx = 0,emplacementy = 0.4,emplacementz = 0;
    int a = 0;
    int murexterieurx[14] = {1.5,1.5,1.5,1.5,9.5,9.5,9.5,9.5,11,11,11,11,1.5,1.5};
    int murexterieury[14] = {0,2.45,0,2.45,0,2.45,0,2.45,0,2.45,0,2.45,0,2.45};
    int murexterieurz[14] = {-4,-4,8,8,8,8,0.5,0.5,0.5,0.5,-4,-4,-4,-4};
    void rue(){
    id_rue=glGenLists(1);
    glNewList(id_rue,GL_COMPILE);
    glBegin(GL_QUADS);
    	glColor3f(0.0,0.0,0.0);
    	glVertex3f(-1,0,-3);
    	glVertex3f(1,0,-3);
    	glVertex3f(1,0,3);
    	glVertex3f(-1,0,3);
    	glColor3f(0.5,0.5,0.5);
        glVertex3f(1,0,3);
        glVertex3f(1.1,0.05,3);
        glVertex3f(1.1,0.05,-3);
        glVertex3f(1,0,-3);
        glVertex3f(1.2,0.05,3);
        glVertex3f(1.2,0.05,-3);
        glVertex3f(1.2,0.0,-3);
        glVertex3f(1.2,0.0,3);
        glVertex3f(1,0,3);
        glVertex3f(1,0,-3);
        glVertex3f(-1,0,3);
        glVertex3f(-1.1,0.05,3);
        glVertex3f(-1.1,0.05,-3);
        glVertex3f(-1.2,0.05,3);
        glVertex3f(-1.2,0.05,-3);
        glVertex3f(-1.2,0.0,-3);
        glVertex3f(-1.2,0.0,3);
        glVertex3f(-1,0,3);
        glEnd();
        glEndList();
    void Clavier(unsigned char key, int x, int y)
    if(key == 'z'){
    emplacementz = emplacementz - 0.1;
    viseez = viseez - 0.1;
    if(key == 'q'){
    emplacementx = emplacementx - 0.1;
    viseex = viseex - 0.1;
    if(key == 's'){
    emplacementz = emplacementz + 0.1;
    viseez = viseez + 0.1;
    if(key == 'd'){
    emplacementx = emplacementx + 0.1;
    viseex = viseex + 0.1;
    if(key == 'p'){
    int ancienx = viseex;
    viseex = 0 - viseez;
    viseez = ancienx;
    glLoadIdentity();
    gluLookAt(emplacementx,emplacementy,emplacementz,viseex,viseey,viseez,0,1,0);
    glutPostRedisplay();
    void reshape(int w,int h){
    glViewport(0,0,w,h);
       glMatrixMode(GL_PROJECTION);
       glLoadIdentity();
       gluPerspective(45.0,(float) w/h,1.,10.);
    void init(){
    glClearColor(0.0,0.0,1.0,0.0);
    rue();
    void motion(int x, int y)
    void Display()
        glLoadIdentity();
        glCallList(id_rue);
        glBegin(GL_QUADS);
        glColor3f(1,0,0);
        glVertex3f(1,0,-3);
        glVertex3f(1,1,-3);
        glVertex3f(-1,1,-3);
        glEnd();
       	glFlush();
    	glutSwapBuffers();
    int main( int argc, char *argv[ ])
    	glutInit(&argc,argv);
        glutInitDisplayMode(GLUT_RGBA | GLUT_SINGLE | GLUT_DEPTH);
        glutInitWindowSize(WIDTH,HEIGHT);
    	glutInitWindowPosition(50,50);
    	glutCreateWindow("Fenetre OpenGL");
        init();
    	glutDisplayFunc(Display);
    	glutPassiveMotionFunc(motion);
        glutKeyboardFunc(Clavier);
    	glutReshapeFunc(reshape);
    	glutMainLoop(); // lance le gestionnaire glut
    	return 0;
    Septembre 2004
    Par défaut j'ai oublier de dire
    pour avancer,on appuie sur z,gauche : q droite : d reculer : s
    Avatar de bafman
    Novembre 2003
    met ton gluPerspective(45.0,(float) w/h,1.,10.);
    avec une valeur plus importante comme dernier paramettre, c'est la distance de vision.
    par contre fait attention car si une distance de vision trop petite coupe une partie de la scene, une distance de visuion trop grande risque de crée des probleme de z fighting, ce qui n'est pas mieux
    tiens un autre truc
    utilise plutot GLUT_DOUBLE que GLUT_SINGLE, toutes les cartes graphique a l'heure acctuelle supportent le double buffering et tu y gagnera vraiment en confort visuel quand l'affichage commencera a ralentire...
    par contre il ne faudra pas oublier de faire un glutSwapBuffer() a la fin de ton affichage.
    voila @+
    [EDIT] oups j'avait pas vu qu'il y avait deja le swapping des buffer
    Mes articles
    Septembre 2004
    Par défaut merci
    merci pour l'aide mais je met quoi comme valeur?
    Septembre 2004
    Par défaut j'ai changer
    j'ai changer ce que tu m'a dis mais je ne voit aucune difference
    Membre éclairé Avatar de venomelektro
    Avril 2004
    mets met ton gluPerspective(45.0,(float) w/h,0.1f,1000.0f);
    par exemple
    Septembre 2004
    Par défaut je ne voit aucune difference
    en changeant, on ne voit toujours pas plus loin.
    Avatar de bafman
    Novembre 2003
    enleve deja les
    glLoadIdentity();
    avant le
    ils sont inutiles vu que la fonction qui est appelé juste apres glutPostRedisplay est la fonction de display...
    sinon je ma demande si il ne faudrait pas mettre un
    glMatrixMode(GL_MODELVIEW);
    a la fin de ta fonction reshape...
    Mes articles
    Septembre 2004
    Par défaut genial
    c'est ce qui me fallait
  1. Problemes de vue ?
    Par ChameauFou dans le forum Requêtes
    Dernier message: 21/05/2008, 17h43
  2. [oracle9] probleme de vue
    Par jacques64 dans le forum SQL
    Dernier message: 17/09/2007, 17h09
  3. [Plone]Probleme de vue de mon new type de contenu
    Par schnito dans le forum Zope
    Dernier message: 09/03/2007, 09h09
  4. probleme de vue sur sous formulaire
    Par fabrice518 dans le forum Access
    Réponses: 12
    Dernier message: 05/09/2005, 10h35
  5. Probleme en vue
    Par vodevil dans le forum Langage
    Dernier message: 26/07/2005, 09h57
