[11g][10g] Group by via db link de 11g à 10g
    Membre émérite Avatar de bstevy
    Solutions Architect
    Mai 2009
    Activité : Solutions Architect
    Par défaut [11g][10g] Group by via db link de 11g à 10g
    Je bloque sur une requête pas très compliquée, mais je n'arrive pas à comprendre le problème exact.
    select	Main_Service_Number,
    		Time_Slot,
    		SUM(Direct_Entered_Call) as Tot_Direct_Entered_Call,
    		Call_Group
    from
        (	select	a.DNIS || ' (' || NVL(b.DINA, a.DNIS) || ')' as Main_Service_Number,
    				a.CATI as Time_Slot,
    				a.TCDQ as Direct_Entered_Call,
    				case
    					when a.ROPO IN (47000,47001,47009,47010,47011,47002,47014)
    						then '1st'
    					when a.ROPO IN (47015)
    						then 'AL'
    					when a.ROPO IN (47022,47025,47012)
    						then 'SUB'
    					when a.ROPO IN (40381,40384,40391,45115,45729,40382,40385,40392,45569,40383,40386,40393,45451,45612,45636,40388,40394,45111,45220,45219,40395)
    						then 'CM'
    					when a.ROPO IN (47016,47017,47018,45416,45415,44696,45216,45225,45266,45977)
    						then 'PA'
    					when a.ROPO IN (47003,47013,45457,45571,45458,45459,45460)
    						then 'DM'
    					when a.ROPO IN (47020,47021,45973,45974,45975,47024)
    						then 'PET'
    					else NULL
    				end as Call_Group
    		from CTMP.HDIGRE@CTMP_R a
    		INNER JOIN CTMP.DNISMA@CTMP_R b ON a.DNIS = b.DNIS
    		where a.CADA = date '2015-10-25'
    		and a.CATI Between '09' And '20'
    		and a.ROPO IN (47000,47001,47009,47010,47011,47002,47014,47015,47022,47025,47012,40381,40384,40391,45115,45729,40382,40385,40392,45569,40383,40386,40393,45451,45612,45636,40388,40394,45111,45220,45219,40395,47016,47017,47018,45416,45415,44696,45216,45225,45266,45977,47003,47013,45457,45571,45458,45459,45460,47020,47021,45973,45974,45975,47024)
    group by Main_Service_Number, Time_Slot, Call_Group
    Comme vous pouvez le voir, j'utilise un dblink. La base sur laquelle j'execute la requête est 11g et la base du db link est 10g
    Le problème est le suivant :
    ORA-00979: GROUP BYの式ではありません。(N'est pas une expression GROUP BY)
    ORA-02063: 先行のエラー・メッセージを参照してくださいline(CTMP_R)。(preceding line from CTMP_R)
    Si je mets le bloc case dans le group by directement, ca fonctionne.
    Donc je peux toujours passer par cette solution. Mais si vous pouviez m'expliquer pourquoi dans ce cas ci-dessus ca bloque, ca pourrait être interessant.
    Merci d'avance.
    Steven
    Avatar de escartefigue
    bourreau
    Mars 2010
    Activité : bourreau
    Faites + simple avec la syntaxe "group by 1, 2, 3..."
    McM
    McM est déconnecté
    Développeur Oracle
    Juillet 2003
    Activité : Développeur Oracle
    Tu peux préciser Escartefigue ce que tu entends par là ?
    Sinon, j'ai essayé une requête similaire entre une base 11g et 10g, je n'ai pas eu de problèmes. Donc je ne vois pas d'erreur flagrante.
    SELECT grp, tcli, SUM(nb)
    FROM (
    SELECT numdevis, client ||' ('|| typ ||')' tcli,
    		CASE WHEN  numdevis  IN ('D24', 'D26') THEN '1st'
        WHEN numdevis = 'D05' THEN '2nd'
        WHEN numdevis = 'D19' THEN '3rd'
        ELSE NULL
        END grp
    FROM LSTDEVIS@Base10 a JOIN LSTYP@Base10 b ON b.typ = a.typ
    WHERE numdevis IN ('D24', 'D05', 'D26', 'D19', 'D17')
    GROUP BY grp, tcli;
    GRP	TCLI	SUM(NB)
    	"EDT (D)"	30
    "2nd"	"EDT (D)"	36
    "3rd"	"EDT (D)"	35
    "1st"	"EDT (D)"	71
    Est-ce un problème de character set entre les bases ?
    Octobre 2007
    Il se peut que c'est un bug suite à la transformation de la requête. Essayez d'ajouter le hint NO_QUERY_TRANSFORMATION pour vérifier.
    Solutions Architect
    Mai 2009
    Merci pour vos réponses.
    @escartefigue: j'ai jamais vu la syntaxe "group by 1,2,3" fonctionner sous oracle (je l'utilisais sous teradata par contre). Je sais que ca fonctionne avec le order, mais avec le group by, ca m'a toujours renvoyé une erreur, et dans ce cas aussi.
    @McM: ce n'est pas véritablement un problème de group by en soit. Je peux faire tourner cette requete en supprimant la colonne Call_Group et ca fonctionne alors parfaitement. Donc j'ai un peu du mal à savoir d'ou ca peut venir. Je vois dans la tienne un case aussi, donc je me dis que ca doit pas etre ca le probleme. Peut etre le nombre d'element sur lequel on fait le group by ?
    @mnitu: Peux tu es plus précis stp ? comment j'utilise cela?
    Octobre 2007
    Citation Envoyé par bstevy Voir le message
    select  /*+ NO_QUERY_TRANSFORMATION */ Main_Service_Number,
        Time_Slot,
        Call_Group
    from
            case
                then '1st'
                then 'AL'
                then 'SUB'
                then 'CM'
                then 'PA'
                then 'DM'
                then 'PET'
              else NULL
            end as Call_Group
  1. Bouton via un link. KO sous IE
    Par FreshVic dans le forum Mise en page CSS
    Dernier message: 28/10/2008, 17h54
  2. [Site] group id dans un links item
    Par gonzoyumo dans le forum Maven
    Dernier message: 18/10/2007, 22h56
  3. Réplication via DATABASE LINK
    Par machtak dans le forum Administration
    Réponses: 13
    Dernier message: 17/09/2007, 18h12
  4. Réponses: 5
    Dernier message: 26/06/2007, 10h15
  5. [ 10g] import/export via datapump
    Par silverfab95 dans le forum Oracle
    Dernier message: 06/02/2006, 13h19
