Opération arithmétique : optimisation
    Mai 2011
    Par défaut Opération arithmétique : optimisation
    j'ai la table suivante
    CREATE TABLE TEST_CALCUL (  ANNEE NUMBER(4,0) ,MOIS NUMBER(2,0),ID_EMPLOYE VARCHAR2(08) , CODE VARCHAR2(10), SOUS_CODE VARCHAR2(10),VALEUR1 NUMBER(10,2) , VALEUR2 NUMBER(10,2) , VALEUR3 NUMBER(10,2),PRIMARY KEY (ANNEE,MOIS,ID_EMPLOYE,CODE,SOUS_CODE))
    Insert into TEST_CALCUL (ANNEE,MOIS,ID_EMPLOYE,CODE,SOUS_CODE,VALEUR1,VALEUR2,VALEUR3) values ('2012','10','EMP01','CODE1','Q','1','2','3');
    Insert into TEST_CALCUL (ANNEE,MOIS,ID_EMPLOYE,CODE,SOUS_CODE,VALEUR1,VALEUR2,VALEUR3) values ('2012','10','EMP01','CODE2','W','4','5','6');
    Insert into TEST_CALCUL (ANNEE,MOIS,ID_EMPLOYE,CODE,SOUS_CODE,VALEUR1,VALEUR2,VALEUR3) values ('2012','10','EMP01','CODE3','D','7','8','9');
    Insert into TEST_CALCUL (ANNEE,MOIS,ID_EMPLOYE,CODE,SOUS_CODE,VALEUR1,VALEUR2,VALEUR3) values ('2012','10','EMP02','CODE1','D','10','11','12');
    Insert into TEST_CALCUL (ANNEE,MOIS,ID_EMPLOYE,CODE,SOUS_CODE,VALEUR1,VALEUR2,VALEUR3) values ('2012','10','EMP02','CODE3','F','13','14','15');
    Insert into TEST_CALCUL (ANNEE,MOIS,ID_EMPLOYE,CODE,SOUS_CODE,VALEUR1,VALEUR2,VALEUR3) values ('2012','10','EMP02','CODE3','D','16','17','18');
    Insert into TEST_CALCUL (ANNEE,MOIS,ID_EMPLOYE,CODE,SOUS_CODE,VALEUR1,VALEUR2,VALEUR3) values ('2012','10','EMP02','CODE3','X','19','20','21');
    Insert into TEST_CALCUL (ANNEE,MOIS,ID_EMPLOYE,CODE,SOUS_CODE,VALEUR1,VALEUR2,VALEUR3) values ('2012','10','EMP02','CODE4','X','22','23','24');
    Insert into TEST_CALCUL (ANNEE,MOIS,ID_EMPLOYE,CODE,SOUS_CODE,VALEUR1,VALEUR2,VALEUR3) values ('2012','10','EMP02','CODE5','X','25','26','27');
    Insert into TEST_CALCUL (ANNEE,MOIS,ID_EMPLOYE,CODE,SOUS_CODE,VALEUR1,VALEUR2,VALEUR3) values ('2012','10','EMP01','CODE4','X','28','29','30');
    Insert into TEST_CALCUL (ANNEE,MOIS,ID_EMPLOYE,CODE,SOUS_CODE,VALEUR1,VALEUR2,VALEUR3) values ('2012','10','EMP01','CODE5','X','31','32','33');
    ANNEE MOIS ID_EMPLOYE CODE       SOUS_CODE     VALEUR1    VALEUR2    VALEUR3
     2012   10 EMP01      CODE1      Q                   1          2          3
     2012   10 EMP01      CODE2      W                   4          5          6
     2012   10 EMP01      CODE3      D                   7          8          9
     2012   10 EMP02      CODE1      D                  10         11         12
     2012   10 EMP02      CODE3      F                  13         14         15
     2012   10 EMP02      CODE3      D                  16         17         18
     2012   10 EMP02      CODE3      X                  19         20         21
     2012   10 EMP02      CODE4      X                  22         23         24
     2012   10 EMP02      CODE5      X                  25         26         27
     2012   10 EMP01      CODE4      X                  28         29         30
     2012   10 EMP01      CODE5      X                  31         32         33
    et le but est d'obtenir le résultat suivant
    ANNEE MOIS ID_EMPLOYE 'STOCK1' 'STOCK2'
     2012   10 EMP01             5        4
     2012   10 EMP02            64        4
    sachant que
    STOCK1=(VALEUR1 DE CODE1)-(VALEUR2 DE CODE2)+(VALEUR3 DE CODE3)
    STOCK2=-(VALEUR2 DE CODE4)+(VALEUR3 DE CODE5)
    Avez-vous une méthode plus performante que celle-ci?
    WITH TABLE1 AS (
    SELECT ANNEE ,MOIS  ,ID_EMPLOYE ,CODE,SUM(VALEUR1) AS VALEUR1,SUM(VALEUR2) AS VALEUR2,SUM(VALEUR3) AS VALEUR3
    FROM TEST_CALCUL
    WHERE
    ANNEE = 2012 AND MOIS = 10
    AND CODE IN ('CODE1','CODE2','CODE3','CODE4','CODE5')
    GROUP BY ANNEE ,MOIS  ,ID_EMPLOYE ,CODE
    ,TABLE2 AS (
    SELECT ANNEE ,MOIS ,ID_EMPLOYE  ,'STOCK1' AS CODE, VALEUR1 AS VALEUR FROM TABLE1 WHERE  CODE = 'CODE1'
    UNION
    SELECT ANNEE ,MOIS ,ID_EMPLOYE  ,'STOCK1' AS CODE, VALEUR2*-1 AS VALEUR FROM TABLE1 WHERE  CODE = 'CODE2'
    UNION
    SELECT ANNEE ,MOIS ,ID_EMPLOYE  ,'STOCK1' AS CODE, VALEUR3 AS VALEUR FROM TABLE1 WHERE  CODE = 'CODE3'
    UNION
    SELECT ANNEE ,MOIS ,ID_EMPLOYE  ,'STOCK2' AS CODE, VALEUR2*-1 AS VALEUR FROM TABLE1 WHERE  CODE = 'CODE4'
    UNION
    SELECT ANNEE ,MOIS ,ID_EMPLOYE  ,'STOCK2' AS CODE, VALEUR3 AS VALEUR FROM TABLE1 WHERE  CODE = 'CODE5'
    SELECT * FROM TABLE2 PIVOT (SUM(VALEUR) FOR CODE IN ('STOCK1','STOCK2'));
    McM
    McM est déconnecté
    Développeur Oracle
    Juillet 2003
    Activité : Développeur Oracle
    Avec un decode et une fonction de groupe
    SELECT annee, mois, id_employe,
    		SUM(DECODE(code, 'CODE1', valeur1, 0))
    	- SUM(DECODE(code, 'CODE2', valeur3, 0))
    	+ SUM(DECODE(code, 'CODE3', valeur3, 0)) stock1,
      	SUM(DECODE(code, 'CODE5', valeur3, 0))
    	- SUM(DECODE(code, 'CODE4', valeur2, 0)) stock2
    FROM test_calcul
    GROUP BY annee, mois, id_employe
    ANNEE	MOIS	ID_EMPLOYE	STOCK1	STOCK2
    2012	10	EMP01		4	4
    2012	10	EMP02		64	4
    Et tu as une erreur dans ton résultat : C'est 4 le premier résultat : 1 - 5 + 8
    Avatar de Waldar
    Citation Envoyé par McM Voir le message
    C'est une erreur dans le decode : valeur3 au lieu de valeur2 dans la ligne 3.
    Mai 2011
    Merci et comme dirait l'autre "parfaitement parfait"
  1. Opération arithmétique dans un select
    Par Christophe Charron dans le forum Requêtes
    Dernier message: 21/03/2007, 11h19
  2. Réponses: 5
    Dernier message: 17/06/2006, 12h33
  3. Opération arithmétique de String à Float
    Par Shiryu57 dans le forum Langage
    Dernier message: 13/03/2006, 10h22
  4. Réponses: 6
    Dernier message: 28/07/2005, 21h14
  5. [VAL] Opérations arithmétiques
    Par WriteLN dans le forum Langage SQL
    Dernier message: 12/05/2005, 09h59
