| 12
 | SQL> create table g_wrkTable (type_champ varchar2(30), champ2 varchar2(30));
Table created.
SQL>
SQL> insert into g_wrkTable (type_champ, champ2) values ('CODEPOSTAL',lpad('x',15,'x'));
1 row created.
SQL> insert into g_wrkTable (type_champ, champ2) values ('CODEPOSTAL',lpad('x',5,'x'));
1 row created.
SQL> commit;
Commit complete.
SQL>
SQL> create or replace function validateData
  2  return sys.odcivarchar2list
  3  pipelined is
  4    l_message varchar2(500);
  5  begin
  6    for c in (select type_champ, champ2 from g_wrkTable) loop
  7      if (c.type_champ = 'CODEPOSTAL' and length(c.champ2) > 12) then
  8        l_message := ' (type_champ = '||c.type_champ||' , champ2 = '||c.champ2||') Le champ : champ2 doit avoir une longueur max de 5 ';
  9        pipe row(l_message);
 10      end if;
 11    end loop;
 12  end;
 13  /
Function created.
SQL> show err
No errors.
SQL> select * from table(validateData)
  2  /
COLUMN_VALUE
 (type_champ = CODEPOSTAL , champ2 = xxxxxxxxxxxxxxx) Le champ : champ2 doit avoir une longueur max de 5
SQL> |
