Réseau/Web Python Discussion :
pb lancer programme python
Réseau/Web Python
    Mars 2009
    Par défaut pb lancer programme python
    j'ai realisé un developpement python :
    import socket
    ip = "192.168.1.50"
    port = 1028
    s = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
    s.connect((ip, port))
    msgs = [ "<read><object id='light1'/></read>\n\4",
     "<write><object id='light' value='on'/></write>\n\4" ]
    for msg in msgs:
     s.send(msg)
     data = s.recv(1024)
     print data
    s.close()
    je veux le lancer depuis une page html, j'ai réaliser ca :
    <html>
    <head>
    <title>Page Title</title>
    <link rel="STYLESHEET" type="text/css" href="Main.css">
    <script src="BasicFunctions.js" type="text/javascript"></script>
    <script src="Scrolling.js" type="text/javascript"></script>
    <script src="MoveFocus.js" type="text/javascript"></script>
    <script>
        function pageLoadFunctions()
            setBGColor("#666666");
            checkSVP();
            setCounter();
            setArray();
            startFocus();
        function doSelect()
        /* This function determines what your buttons do when they are selected
        (navigate, call a function, etc.). This function will get called whenever user
        clicks a focusable item, or selects it with "OK" button on remote. Make sure to
        include a case below for each focusable item on the page */
            var url = ""
            switch(oCurFocus.id)
                case "btnMenuPg": url="testpy.py"; break;
                case "btnFind": url = "BrowseMedia.htm"; break;
                case "btnPlay": url="PlayMedia.htm"; break;
                case "btnNewsMain": url="NewsMain.htm"; break;
                case "btnNewsArticle": url="NewsArticle.htm"; break;
                case "btnNewsSetup": url="NewsSetup.htm"; break;
                case "btnPurchase1": url="Purchase1.htm"; break;
                case "btnPurchase2": url="Purchase2.htm"; break;
                case "btnSchedRecord": url="ScheduleRecording.htm"; break;
                case "btnNavToPg": url="NavToPage.htm"; break;
                case "btnInstall": url="InstallApp.htm"; break;
                case "btnTest": url="Test.htm"; break;
            if (url != "") window.navigate(url);
    </script>
    </head>
    quand je clik sur le bouton j'ai une page html qui s'ouvre avec le code lisible dedans, mais moi je ne veux pas le lire, je veux que le code python s'execute.
    avez-vous une idée de comment réaliser ca?
    merci
    Nouveau membre du Club
    Mai 2006
    Pour que ton script python s'exécute, il faut qu'il y ait un interpréteur python.
    Le JavaScript s'exécute car il y a un interpréteur JavaScript dans ton navigateur, mais il n'y a pas celui du python (c'est comme ça).
    Si tu veux faire de la programmation web avec Python, tu peux tenter de faire des scripts CGI en python.
    Vois aussi ça:www.modpython.org/
    Mars 2009
    le mieux est que creer le meme fichier en .js.
    que dois-je mettre dans mon fichier .js pour avoir la meme chose????
    merci de ta reponse
    Avatar de yorukaze
    Janvier 2007
    comme précisé plus haut, il faut un interpreteur pour que python soit utilisé dans le web. As-tu mis en place mod-python sur ton serveur?
    Mars 2009
    J'ai installer mod python
    comment savoir si il est bien installer (je suis sous windows).
    et command lancer un .py depuis une page html maintenant?
    cordialement
    Mars 2009
    re
    j'ai installer mod python ca a l'air de marcher car mon wamp server est tout en blanc et je peux voir que le service mod python est actif.
    cependant quand je réalise te test de l'url http://www.modpython.org/live/curren...t-testing.html
    j'ai une page web qui affiche ca
    MOD_PYTHON ERROR
    ProcessId:      1052
    Interpreter:    'localhost'
    ServerName:     'localhost'
    DocumentRoot:   'C:/wamp/www/'
    URI:            '/testpy/mptest.py'
    Directory:      'C:/wamp/www/testpy/'
    Filename:       'C:/wamp/www/testpy/mptest.py'
    PathInfo:       ''
    Phase:          'PythonHandler'
    Handler:        'mptest'
      File "C:\Python23\Lib\site-packages\mod_python\importer.py", line 1537, in HandlerDispatch
        default=default_handler, arg=req, silent=hlist.silent)
      File "C:\Python23\Lib\site-packages\mod_python\importer.py", line 1202, in _process_target
        module = import_module(module_name, path=path)
      File "C:\Python23\Lib\site-packages\mod_python\importer.py", line 296, in import_module
        log, import_path)
      File "C:\Python23\Lib\site-packages\mod_python\importer.py", line 680, in import_module
        execfile(file, module.__dict__)
    IndentationError: expected an indented block (mptest.py, line 3)
    MODULE CACHE DETAILS
    Accessed:       Thu Mar 26 23:10:48 2009
    Generation:     0
    _mp_9d9ab00c728005e82726bbd9343c3d44 {
      FileName:     'C:\\wamp\\www\\testpy\\mptest.py'
      Instance:     1 [IMPORT]
      Generation:   0 [ERROR]
      Modified:     Thu Mar 26 23:00:46 2009
    comment resoudre la problème?????
    ps : le dossier testpy contient un fichier .htaccess avec dedans
    AddHandler mod_python .py
    PythonHandler mptest
    PythonDebug On
    et un fichier mptest.py avec dedans
    from mod_python import apache
    def handler(req):
    req.content_type = 'text/plain'
    req.write("Hello World!")
    return apache.OK
    Membre Expert Avatar de pacificator
    Août 2006
    Python est sympa, il te donne l'erreur:
    Mars 2009
    ok
    merci mais maintenant comment mofifier cette ligne 3 pour que ca marche???
    Mars 2009
    J'ai reussi a afficher hello word, comment?
    ben j'y comprend rien, il m'a valu juste rajouter un espace devant les reg et return :
    def handler(req):
     return apache.OK
    si quelqu'un peut m'expliquer la petite différence.
    Sinon maintenant comment lancer un fichier .py depuis un html (ma premier question)^^
    cordialement
    Mars 2009
    passer par du .hta est la solution sous windows
    Si tu sais pas la différence entre
    def handler(req):
     return apache.OK
    et
    def handler(req):
    return apache.OK
    C'est que tu ne connais pas le python.
    Sinon pour ta question, bah tu vas sur le site de mod_python, tu lis la doc pour configurer Apache, et normalement, ça marche
  1. Réponses: 10
    Dernier message: 25/12/2012, 20h31
  2. [Batch] Lancer programme python avec paramètre
    Par bastou93 dans le forum Scripts/Batch
    Dernier message: 07/07/2011, 08h58
  3. Réponses: 145
    Dernier message: 15/02/2009, 12h51
  4. [Lien]erreur dans mon programme python
    Par durnambule dans le forum Général Python
    Dernier message: 29/01/2004, 15h59
