optimisation de requête SQL
    Membre du Club
    Octobre 2007
    Par défaut optimisation de requête SQL
    Je recherche un moyen d'optimiser cette requête qui demande plusieurs minutes pour s'exécuter.
    L'objectif est de récupérer l'occurence la plus récente dans une période donnée (ici, janvier 2007).
    d'avance merci.
     select  CUF_C_UF, mat_c_agent
    from taff b
    where
    AFF_D_DEBUT <= to_date('01/01/2007','DD/MM/YYYY')
    and AFF_D_FIN>=LAST_DAY(to_date('01/01/2007','DD/MM/YYYY'))
    and EHR_C_EH='21066'
    and AFF_D_DEBUT=
        select max(c.AFF_D_DEBUT)
        from taff c
        where c.MAT_C_AGENT=b.MAT_C_AGENT
        and c.AFF_D_DEBUT<=to_date('01/01/2007','DD/MM/YYYY')
    CREATE TABLE TAFF (
      EHR_C_EH      CHAR (5)      NOT NULL,
      MAT_C_AGENT   VARCHAR2 (14)  NOT NULL,
      AFF_D_DEBUT   DATE          NOT NULL,
      AFF_C_NATURE  CHAR (3)      NOT NULL,
      EHR_C_EHUF    CHAR (5)      NOT NULL,
      CUF_C_UF      VARCHAR2 (17)  NOT NULL,
      AFF_D_APPAR   DATE          NOT NULL,
      AFF_D_DISPAR  DATE          NOT NULL,
      AFF_D_FIN     DATE          NOT NULL,
      AFF_N_POINTS  NUMBER (6),
      AFF_N_NUMER   NUMBER (6),
      AFF_N_DENOM   NUMBER (6),
      CONSTRAINT PK_TAFF
      PRIMARY KEY ( EHR_C_EH, MAT_C_AGENT, AFF_D_DEBUT, AFF_C_NATURE, EHR_C_EHUF, CUF_C_UF, AFF_D_APPAR )
        USING INDEX
         TABLESPACE AGEINDEX PCTFREE 10
         STORAGE ( INITIAL 90232K NEXT 4632K PCTINCREASE 0 ))
       TABLESPACE AGEDATA NOLOGGING
       PCTFREE 10
       PCTUSED 40
       INITRANS 1
       MAXTRANS 255
      STORAGE (
       INITIAL 78499840
       NEXT 1331200
       MINEXTENTS 1
       MAXEXTENTS 99
       FREELISTS 1 FREELIST GROUPS 1 )
       NOCACHE;
    ALTER TABLE PH7.TAFF ADD  CONSTRAINT FK_TAFF_AFF_CUF_TCUF
     FOREIGN KEY (EHR_C_EH, CUF_C_UF)
      REFERENCES PH7.TCUF (EHR_C_EH, CUF_C_UF) ;
    ALTER TABLE PH7.TAFF ADD  CONSTRAINT FK_TAFF_AFF_MAT_TMAT
     FOREIGN KEY (EHR_C_EHUF, MAT_C_AGENT)
      REFERENCES PH7.TMAT (EHR_C_EH, MAT_C_AGENT) ;
    CREATE INDEX AFF_CUF_FK ON
      TAFF(EHR_C_EH, CUF_C_UF)
      TABLESPACE AGEINDEX PCTFREE 10  STORAGE(INITIAL 31744000 NEXT 4706304 PCTINCREASE 10 )
    CREATE INDEX AFF_MAT_FK ON
      TAFF(EHR_C_EHUF, MAT_C_AGENT)
      TABLESPACE AGEINDEX PCTFREE 10  STORAGE(INITIAL 34816000 NEXT 4943872 PCTINCREASE 10 )
    Octobre 2007
    Peut tu ajouter le plan d'exécution de la requête, éventuellement faire un tkprof ?
    Décembre 2007
    Citation Envoyé par millien Voir le message
    d'avance merci.
    from taff b
    where
    and AFF_D_DEBUT=
        from taff c
    Il y a beaucoup d'information qui manque notamment la version, le plan d'exécution, la volumetrie et si les statistiques sont collectées Certains index sont probablement à créer. Mais mon nez me dit que la requête ci-après va se comporter mieux. Elle marche à partir d'Oracle 9i et elle peut être réécrite différemment pour les versions précédentes
    with t as
      select mat_c_agent, max(AFF_D_DEBUT) max_aff_d_debut
      from taff
      where AFF_D_DEBUT<=to_date('01/01/2007','DD/MM/YYYY')
      group by mat_c_agent
    from taff t1, t
    where
      t1.AFF_D_DEBUT <= to_date('01/01/2007','DD/MM/YYYY')
      and t1.AFF_D_FIN>=LAST_DAY(to_date('01/01/2007','DD/MM/YYYY'))
      and t1.EHR_C_EH='21066'
      and t1.AFF_D_DEBUT= t.max_aff_d_debut
      and t1.mat_c_agent = t.mat_c_agent
    Membre émérite Avatar de Yorglaa
    Janvier 2004
    bonjour,
    je sais que ça joue peu sur les perf, mais au lieu de faire
    AND t1.AFF_D_FIN>=LAST_DAY(to_date('01/01/2007','DD/MM/YYYY'))
    il serais plus simple de faire
    AND t1.AFF_D_FIN>=to_date('31/01/2007','DD/MM/YYYY')
    un last_day sur une valeur "en dur" c'est pas très bon...puisque la valeur calculée du last_day est connue d'avance.
    De plus le fait d'avoir une clause sur une fonction peut empêcher l'optimiseur d'utiliser un index...
    Membre du Club
    Octobre 2007
    Par défaut merci Michel SALAIS
    Je suis passée par une table temporaire parce que je suis en version 8 d'oracle.
    Ca marche bien merci beaucoup
  1. Initiation à l'optimisation de requêtes SQL sous ORACLE
    Par Vincent Rogier dans le forum Contribuez
    Réponses: 12
    Dernier message: 30/09/2011, 15h09
  2. [phpBB] Optimiser les requêtes SQL
    Par Jimalexp dans le forum EDI, CMS, Outils, Scripts et API
    Dernier message: 22/09/2008, 08h33
  3. [phpBB] Optimiser les requêtes SQL
    Par Jimalexp dans le forum Langage SQL
    Dernier message: 22/09/2008, 02h42
  4. Optimisation de requêtes SQL - utilisation de IN SELECT
    Par cfeltz dans le forum Langage SQL
    Dernier message: 20/12/2006, 10h28
  5. Optimiser une requête SQL d'un moteur de recherche
    Par kibodio dans le forum Langage SQL
    Dernier message: 06/03/2005, 21h55
