Snake en python [Python 3.X]
    Membre habitué
    Novembre 2016
    Par défaut Snake en python
    Je dois effectuer un jeu snake pour les cours et j'aimerai un peu t'aide sans me donner les réponses clairement sinon cela n'a pas d’intérêt.
    Voici mon code :
    119
    120
    121
    122
    123
    124
    125
    126
    127
    128
    129
    130
    131
    132
    133
    134
    135
    136
    137
    138
    #! /usr/bin/env python3
    # -*- coding: utf8 -*-
    # imports ####################################################################
    import sys
    import curses
    import random
    # screen handling ############################################################
    def init_screen():
        screen = curses.initscr()
        screen.keypad(1)
        def excepthook(*args):
            cleanup(screen)
            return sys.__excepthook__(*args)
        sys.excepthook = excepthook
        curses.noecho()
        curses.halfdelay(2)
        curses.curs_set(0)
        return screen
    def display(screen, snake, food):
        screen.clear()
        screen.border()
        for l, c in snake:
            screen.addstr(l, c, "O")
        for food_l, food_c in food:
    	screen.addstr(food_l,food_c, "X")
        screen.refresh()
    def cleanup(screen):
        screen.keypad(0)
        curses.nocbreak()
        curses.echo()
        curses.endwin()
    def inside(screen, snake) :
        lmax, cmax = screen.getmaxyx()
    # Position de la tête
        l, c = snake[-1]
        snakes = snake
        del snakes[-1]
        if 0 < l < lmax-1 and 0 < c < cmax-1 :
            return False
        	if l,c in snake:
    		return True
    	else:
    		return False
        else:
            return True
    def create_food (food, snake, screen):
    	if food == snake[-1]:
    		food_lmax, food_cmax = screen.getmaxyx()
    		food_c = random.randint(1,food_cmax-1)
    		food_l = random.randint(1,food_lmax-1)
    		del food
    		food += [(food_l,food_c)]
    	return food
    # main program ###############################################################
    def main():
        screen = init_screen()
        food_l = 20
        food_c = 100
        food = []
        l = 50
        c = 8
        direc = "right"
        snake = [(50,2),(50,3),(50,4),(50,5),(50,6),(50,7),(50,8)]
        while True:
            k = screen.getch()
            if k == ord('q'):
                break
            elif k == curses.KEY_LEFT:
                if direc == "right":
                    direc = "up"
                elif direc == "up":
                    direc = "left"
                elif direc == "left":
                    direc = "down"
                elif direc == "down":
                    direc = "right"
            elif k == curses.KEY_RIGHT:
                    direc = "down"
                    direc = "left"
                    direc = "up"
                elif direc == "up":
                    direc = "right"
            if direc == "right" :
                c = c+1
            elif direc == "left" :
                c = c-1
            elif direc == "up" :
                l = l-1
            elif direc == "down" :
                l = l+1
    #Supprime le bout de la gueue pour le deplacmeent
            del snake[0]
            snake += [(l,c)]
            if inside(screen, snake):
                print "Game Over"
    	    break
            else:
    	    snake += [(l,c)]
        cleanup(screen)
    if __name__ == "__main__":
        sys.exit(main())
    Question 1 : J'ai une erreur à la ligne 54 qui est if l,c in snake: je ne vois pas ou il y a une erreur à ce niveau la
    Question 2 : Ma fonction create_food -> But voulu quand l'emplacement de la food est égal à la tête du serpent je veux supprimer la valeur dans food et lui en donner une nouvelle aléatoirement. (Pour le moment quand je passe sur la food elle ne disparait pas et je ne comprends pas pourquoi)
    Question 3 : A la fin je fais un
                print "Game Over"
    	    break
    en gros la fonction inside fait que si le serpent touche un mur ou lui même ça écrit Game Over mais sans le break plein de Game Over sont écriés à l'écran ( normal vu que j'appelle la fonction dans un while) et si je break comme la je ne vois pas le texte. En gros J'aimerait qu'il affiche game over au milieu de l'écran et que le jeu ce quitte quand j'appuie sur n'importe quelle touche.
    Voilà merci d'avance et j'insiste je veux juste des éclaircissements par les réponses
    Architecte technique retraité
    Juin 2008
    Citation Envoyé par Synerzie Voir le message
    L'erreur qui doit être "SyntaxError: invalid syntax" - mais il eût été sympa. de le préciser - dit seulement qu'il faut mettre les formes pour écrire "if l,c in snake:". i.e. ajouter des parenthèses (et à priori vous avez 2 possibilités).
    Pour les autres questions, je les abandonne à la sagacité de mes collègues.
    - W
    Architectures post-modernes.
    Membre habitué
    Novembre 2016
    - W
    Ah merci, oui effectivement c'est juste un manque de parenthèse ! Mais pourquoi j'en est besoin la alors que plus haut j'en est pas besoin pourtant c'est presque la même ligne ?
    Juin 2008
    Le "presque", c'est des contextes différents qui permettent (ou pas) de lever des ambiguïtés.
    - W
    Membre habitué
    Novembre 2016
    Par défaut Collision snake
    Bon pendant ces quelques jours j'ai pu avancer ! La fonction create food fonctionne parfaitement avec mon nouveau code mais je n'arrive pas à créer une erreur pour la collision du snake. En gros j'aimerait lui dire que si le premier n-uplet touche n'importe quel autre n-uplet il break le programme mais je n'y arrive pas. J'arrive à sélectionner juste le premier n-uplet et sélectionner le reste du tableau mais je sais pas lui dire si le premier n-uplet "touche" le reste du tableau alors break le programme. En gros c'est le "touché" qui me pose problème.
    Voila mon exemple de condition
    #(50,8) représente la tête de mon serpent
    z = len(snake)
    if snake [-1] "touche" snake [0:z-1]
        break
    Voilà merci de me donner un petit coup de main ça serait super
    Juin 2008
    Avant d'imaginer comment traduire cette relation en Python, il faut peut être clarifier ce qu'elle veut dire. Et à défaut de savoir l'écrire avec des mots, prendre des exemples i.e. si:
    snake [0:z-1] contient [(50,2),(50,3),(50,4),(50,5),(50,6),(50,7)] quand dit-on que toucher(snake[0], snake[:-1]) est "vraie" ?
    - W
    Membre habitué
    Novembre 2016
    - W
    Je ne comprends pas ce que tu me dis la :/
    Juin 2008
    Reprenez votre exemple: "if snake [-1] "touche" snake [0:z-1]". Si vous n'explicitez pas quand la condition (s'il y a un "if", il y a une condition) est vraie, pas facile de savoir par quoi remplacer "touche".
    - W
    Membre habitué
    Novembre 2016
    En gros l'erreur à renvoyer c'est que quand le tête du serpent touche son corps il faut renvoyer une erreur mais je ne vois pas comment je peux lui dire
    Juin 2008
    Ben le plus simple c'est de prendre un papier et un crayon et de réfléchir à comment raconter çà en français... Comme je n'habite pas dans votre tête, il n'y a que vous qui sachiez ce que vous voulez.
    - W
    Membre habitué
    Novembre 2016
    - W
    Bah en français ça donne "si la tête du serpent toujours son corps alors je coupe le programme"
    Juin 2008
    Et vous appelez çà du français? où est le verbe?
    admettons que ce soit l'idée, çà veut dire quoi côté positions de la tête et du reste? (En fait, c'est çà qu'il faut dessiner avec papier/crayon).
    - W
    Membre habitué
    Novembre 2016
    - W
    Que la tête est égal au corps mais quand je fais un :
    z = len(snake)
    #snake [-1] correspond à l'emplacement de la tête
    if snake[-1] == snake[0:z-1]:
        break
    Mon code ne fonctionne pas. Quand je touche le corps du serpent avec la tête rien ne ce passe
    Membre habitué
    Novembre 2016
    Bon bah j'ai réussi la collision
  1. Jeu du snake en python
    Par pythonovice dans le forum Général Python
    Dernier message: 24/04/2015, 10h46
  2. Snake avec Python 3.0 et Tkinter
    Par tonykart13 dans le forum Tkinter
    Réponses: 18
    Dernier message: 10/06/2012, 21h55
  3. [Open-Source][Python]Snake like
    Par the_dorian dans le forum Mon programme
    Dernier message: 21/03/2008, 11h22
  4. [TP][Projet] Réaliser un Snake-Like
    Par Giovanny Temgoua dans le forum Turbo Pascal
    Réponses: 69
    Dernier message: 17/01/2005, 18h04
  5. CORBA & PYTHON
    Par stan91stan dans le forum CORBA
    Dernier message: 10/06/2004, 12h32
