Question optimisation requête
    Août 2003
    Par défaut Question optimisation requête
    J'ai une requête ci-dessous qui consomme beaucoup des io logiques sur une base de données 10.2.0.4. :
    select * from ( select this_.dieudo_event_id as dieudo1_3_2_, this_.version as version3_2_,
    this_.batch_id as batch3_3_2_, this_.event_date as event4_3_2_,
    this_.event_type_id as event5_3_2_, this_.object_id as object6_3_2_, this_.object_type_id as object7_3_2_,
    dieudoe2_.event_type_id as event1_4_0_, dieudoe2_.name as name4_0_,
    dieudoo3_.object_type_id as object1_5_1_, dieudoo3_.name as name5_1_
    from
    dieudo_event this_, dieudo_event_type dieudoe2_, dieudo_object_type dieudoo3_
    where
     , and
    this_.object_type_id=dieudoo3_.object_type_id and this_.event_date>=:1 and
    this_.event_date<=:2 order by this_.dieudo_event_id asc )
    where rownum <= :3
    Voici ci-dessous le plan d'execution:
    PLAN_TABLE_OUTPUT
    Plan hash value: 91933269
    | Id | Operation | Name | Rows | Bytes
    | Cost (%CPU)| Time |
    PLAN_TABLE_OUTPUT
    | 0 | SELECT STATEMENT | | |
    | 425 (100)| |
    |* 1 | COUNT STOPKEY | | |
    | 2 | VIEW | | 10 | 17460
    | 425 (1)| 00:00:06 |
    |* 3 | FILTER | | |
    PLAN_TABLE_OUTPUT
    | 4 | NESTED LOOPS | | 10 | 880
    | 425 (1)| 00:00:06 |
    | 5 | NESTED LOOPS | | 10 | 700
    | 415 (1)| 00:00:05 |
    |* 6 | TABLE ACCESS BY INDEX ROWID| dieudo_EVENT | 7643 | 440
    K| 405 (1)| 00:00:05 |
    | 7 | INDEX FULL SCAN | SYS_C0044096 | 4000 |
    PLAN_TABLE_OUTPUT
    | 35 (0)| 00:00:01 |
    | 8 | TABLE ACCESS BY INDEX ROWID| dieudo_OBJECT_TYPE | 1 | 11
    | 1 (0)| 00:00:01 |
    |* 9 | INDEX UNIQUE SCAN | SYS_C0044100 | 1 |
    | 0 (0)| |
    | 10 | TABLE ACCESS BY INDEX ROWID | dieudo_EVENT_TYPE | 1 | 18
    | 1 (0)| 00:00:01 |
    PLAN_TABLE_OUTPUT
    |* 11 | INDEX UNIQUE SCAN | SYS_C0044098 | 1 |
    | 0 (0)| |
    Query Block Name / Object Alias (identified by operation id):
    1 - SEL$1
    PLAN_TABLE_OUTPUT
    2 - SEL$2 / from$_subquery$_001@SEL$1
    3 - SEL$2
    6 - SEL$2 / THIS_@SEL$2
    7 - SEL$2 / THIS_@SEL$2
    8 - SEL$2 / dieudoO3_@SEL$2
    9 - SEL$2 / dieudoO3_@SEL$2
    10 - SEL$2 / dieudoE2_@SEL$2
    11 - SEL$2 / dieudoE2_@SEL$2
    Outline Data
    PLAN_TABLE_OUTPUT
    BEGIN_OUTLINE_DATA
    IGNORE_OPTIM_EMBEDDED_HINTS
    OPTIMIZER_FEATURES_ENABLE('10.2.0.3')
    ALL_ROWS
    OUTLINE_LEAF(@"SEL$2")
    OUTLINE_LEAF(@"SEL$1")
    NO_ACCESS(@"SEL$1" "from$_subquery$_001"@"SEL$1")
    INDEX(@"SEL$2" "THIS_"@"SEL$2" ("dieudo_EVENT"."dieudo_EVENT_ID"))
    INDEX_RS_ASC(@"SEL$2" "dieudoO3_"@"SEL$2" ("dieudo_OBJECT_TYPE"."OBJ
    PLAN_TABLE_OUTPUT
    ECT_TYPE_ID"))
    INDEX_RS_ASC(@"SEL$2" "dieudoE2_"@"SEL$2" ("dieudo_EVENT_TYPE"."EVEN
    T_TYPE_ID"))
    LEADING(@"SEL$2" "THIS_"@"SEL$2" "dieudoO3_"@"SEL$2" "dieudoE2_"@"SE
    L$2")
    USE_NL(@"SEL$2" "dieudoO3_"@"SEL$2")
    USE_NL(@"SEL$2" "dieudoE2_"@"SEL$2")
    END_OUTLINE_DATA
    PLAN_TABLE_OUTPUT
    Predicate Information (identified by operation id):
    1 - filter(ROWNUM<=:3)
    3 - filter(:1<=:2)
    6 - filter(("THIS_"."EVENT_DATE">=:1 AND "THIS_"."EVENT_DATE"<=:2))
    9 - access("THIS_"."OBJECT_TYPE_ID"="dieudoO3_"."OBJECT_TYPE_ID")
    11 - access("THIS_"."EVENT_TYPE_ID"="dieudoE2_"."EVENT_TYPE_ID")
    PLAN_TABLE_OUTPUT
    Column Projection Information (identified by operation id):
    1 - "from$_subquery$_001"."dieudo1_3_2_"[VARCHAR2,128],
    "from$_subquery$_001"."VERSION3_2_"[NUMBER,22], "from$_subquery$_001"."BA
    TCH3_3_2_"[VARCHAR2,1020]
    , "from$_subquery$_001"."EVENT4_3_2_"[TIMESTAMP,11],
    "from$_subquery$_001"."EVENT5_3_2_"[NUMBER,22], "from$_subquery$_001"."OB
    JECT6_3_2_"[VARCHAR2,128]
    PLAN_TABLE_OUTPUT
    , "from$_subquery$_001"."OBJECT7_3_2_"[NUMBER,22],
    "from$_subquery$_001"."EVENT1_4_0_"[NUMBER,22], "from$_subquery$_001"."NA
    ME4_0_"[VARCHAR2,1020],
    "from$_subquery$_001"."OBJECT1_5_1_"[NUMBER,22], "from$_subquery$_001"."N
    AME5_1_"[VARCHAR2,1020]
    2 - "from$_subquery$_001"."dieudo1_3_2_"[VARCHAR2,128],
    PLAN_TABLE_OUTPUT
    PLAN_TABLE_OUTPUT
    3 - "THIS_"."dieudo_EVENT_ID"[VARCHAR2,128], "THIS_"."VERSION"[NUMBER,22],
    "THIS_"."BATCH_ID"[VARCHAR2,1020], "THIS_"."EVENT_DATE"[TIMESTAMP,11],
    "THIS_"."EVENT_TYPE_ID"[NUMBER,22], "THIS_"."OBJECT_ID"[VARCHAR2,128],
    "THIS_"."OBJECT_TYPE_ID"[NUMBER,22], "dieudoO3_"."OBJECT_TYPE_ID"[NUMB
    ER,22],
    "dieudoO3_"."NAME"[VARCHAR2,1020], "dieudoE2_"."EVENT_TYPE_ID"[NUMB
    ER,22],
    PLAN_TABLE_OUTPUT
    "dieudoE2_"."NAME"[VARCHAR2,1020]
    4 - "THIS_"."dieudo_EVENT_ID"[VARCHAR2,128], "THIS_"."VERSION"[NUMBER,22],
    ER,22],
    ER,22],
    PLAN_TABLE_OUTPUT
    5 - "THIS_"."dieudo_EVENT_ID"[VARCHAR2,128], "THIS_"."VERSION"[NUMBER,22],
    ER,22],
    PLAN_TABLE_OUTPUT
    6 - "THIS_"."dieudo_EVENT_ID"[VARCHAR2,128], "THIS_"."VERSION"[NUMBER,22],
    7 - "THIS_".ROWID[ROWID,10], "THIS_"."dieudo_EVENT_ID"[VARCHAR2,128]
    8 - "dieudoO3_"."OBJECT_TYPE_ID"[NUMBER,22], "dieudoO3_"."NAME"[VARCHAR
    2,1020]
    9 - "dieudoO3_".ROWID[ROWID,10], "dieudoO3_"."OBJECT_TYPE_ID"[NUMBER,22
    PLAN_TABLE_OUTPUT
    10 - "dieudoE2_"."EVENT_TYPE_ID"[NUMBER,22], "dieudoE2_"."NAME"[VARCHAR2
    ,1020]
    11 - "dieudoE2_".ROWID[ROWID,10], "dieudoE2_"."EVENT_TYPE_ID"[NUMBER,22]
    117 ligne(s) sélectionnée(s).
    Vu le plan d'execution, comment puis-je faire pour l'optimiser ? que ce qui pose problème ? y a t-il un autre moyen pour le reécrire ?
    Merci de votre analyse.
    Juillet 2007
    Vos noms tordus de tables, colonnes, et même d'alias rendent la lecture de la requête assez imbitable. Passons...
    La requête que vous avez postée ne dois pas pouvoir fonctionner telle quelle : il n'y a rien derrière le WHERE, et un AND est précédé d'une virgule.
    Sinon, la première chose qui interpelle est que la table "dieudo_event_type" n'est jointe à aucune autre, ce qui engendre automatiquement un produit cartésien, et donc à coup sûr déteriore les performances.
    Octobre 2007
    C'est difficile d'optimiser une requête incorrecte. Corrigez-la d'abord.
    WHERE
     , AND
    Août 2003
    Autant pour moi, voici la requête:
    select * from (
    from
    where this_.event_type_id=dieudoe2_.event_type_id and this_.object_type_id=dieudoo3_.object_type_id
    and this_.event_date>='02/10/09 02:17:17,655000' and this_.event_date<='02/10/09 02:17:21,328000'
    where rownum <= 3
    Août 2003
    La bonne d'origine avec les varibales liées:
    select * from (
    from
    and this_.event_date>=:1 and this_.event_date<=:2
    where rownum <= :3
    Avatar de Waldar
    Que voulez-vous optimiser ?
    Le plan d'exécution, si j'ai bien réussi à le lire, m'a l'air efficace.
    Sinon comme le faisait remarquer dgi77, un peu de mise en page et des alias plus court ne font pas de mal, mais les performances ne seront pas impactées :
    WITH SR AS
      SELECT ev.dieudo_event_id AS dieudo1_3_2_,
             ev.version         AS version3_2_,
             ev.batch_id        AS batch3_3_2_,
             ev.event_date      AS event4_3_2_,
             ev.event_type_id   AS event5_3_2_,
             ev.object_id       AS object6_3_2_,
             ev.object_type_id  AS object7_3_2_,
             et.event_type_id   AS event1_4_0_,
             et.name            AS name4_0_,
             ot.object_type_id  AS object1_5_1_,
             ot.name            AS name5_1_
        FROM dieudo_event ev
             INNER JOIN dieudo_event_type et
               ON et.event_type_id = ev.event_type_id
             INNER JOIN dieudo_object_type ot
               ON ot.object_type_id = ev.object_type_id
       WHERE ev.event_date between :1 AND :2
    ORDER BY ev.dieudo_event_id ASC
    SELECT *
      FROM SR
     WHERE rownum <= :3;
    Octobre 2007
    Est-ce que les cardinalités du plan d'exécution correspondent à la réalité ?
    C'est quoi l'index SYS_C0044096? Le full scan n'indique pas un optimum.
    Et une simple exécution de la requête avec auto trace devrait montrer les statistiques concernant le IO qui vous enquête.
  1. Linq - question optimisation requête
    Par boby62423 dans le forum Linq
    Dernier message: 07/04/2009, 18h19
  2. Besoin d'aide pour optimiser requête SQL
    Par Keuf95 dans le forum Langage SQL
    Dernier message: 06/09/2005, 16h02
  3. Optimiser requête utilisant NOT IN
    Par Neilos dans le forum Langage SQL
    Dernier message: 11/08/2005, 14h24
  4. optimisation requête
    Par alex2205 dans le forum Décisions SGBD
    Dernier message: 09/02/2005, 14h15
  5. optimisation requête SQL!!! help!!
    Par anathem62 dans le forum Requêtes
    Dernier message: 24/05/2004, 16h26
