JDBC: problème verrouillage pessimiste.
Servlets/JSP Java
    Membre éclairé Avatar de mumu27
    Mars 2009
    Par défaut JDBC: problème verrouillage pessimiste.
    J'essaye d'utiliser dans mon exemple, un verrouillage pessimiste.
    Voici les différents programmes utilisés:
    *JDBCManager.java:
    package Ch07;
    import java.sql.*;
    import java.util.*;
    public class JDBCManager {
    	private JDBCManager() {
    	public static Connection getConnection(String url) throws SQLException {
    		return getConnection(url, true);
    	public static Connection getConnection(String url, boolean autocommit) throws SQLException {
    		Connection connection = DriverManager.getConnection(url);
    		connection.setAutoCommit(autocommit);
    		return connection;
    		String url,
    		String user,
    		String password)
    		return getConnection(url, user, password, true);
    		String url,
    		String user,
    		String password,
    		boolean autocommit)
    		Connection connection = DriverManager.getConnection(url, user, password);
    		return connection;
    	public static Connection getConnection(String url, Properties props)
    		return getConnection(url, props, true);
    		String url,
    		Properties props,
    		boolean autocommit)
    		Connection connection = DriverManager.getConnection(url, props);
    	  	return connection;
    	public static void rollback(Connection conn) {
    		try {
    		  conn.rollback();
    		} catch (Exception e) {
    		  e.printStackTrace();
    	public static void close(Connection conn) {
    		if (conn != null) {
    		  try {
    		    conn.close();
    	public static void close(Statement stmt) {
    	 	 if (stmt != null) {
    	 	   try {
    		     stmt.close();
    	public static void close(ResultSet rset) {
    	  if (rset != null) {
    		try {
    		  rset.close();
    *PessimisticLockerA.java:
    package Ch07;
    import java.sql.*;
    public class PessimisticLockerA {
      static Connection conn;
      static Statement stmt;
      static Statement stmtA;
      static PreparedStatement pstmt;
      static ResultSet rsetA;
      static String sqlCreate = "create table RESERVE " +
        "(ROOMID varchar(5), RES_DATE date, RES_FLAG boolean, " +
        "RES_NAME varchar(30))";
      static String sqlInsert = "insert into RESERVE values " +
      static String sqlUpdate = "update RESERVE set RES_FLAG=?, " +
        "RES_NAME=? WHERE ROOMID=? AND RES_DATE=?";
      static String sqlSelect = "select ROOMID, RES_DATE, " +
        "RES_FLAG, RES_NAME from RESERVE WHERE RES_FLAG=false FOR UPDATE";
      static String roomName;
      static java.sql.Date roomDate;
    	try {
    	  String url = "jdbc:pointbase:server://localhost/pointbaseDB";
    	  String username = "PBPUBLIC";
    	  String password = "PBPUBLIC";
    	  conn = JDBCManager.getConnection(url, username, password, false);
    	  System.out.println("conn autocommit : " + conn.getAutoCommit());
    	  setup();
    	  userAQuery();
    	  System.out.println("Interruption de 15 second, " +
    	  					 "Lancer PessimisticLockerB");
    	  try {Thread.sleep(15000);} catch (Exception e) {}
    	    System.out.println("PessimisticLockerA est actif");
    	    userAUpdate();
      	  } finally {
    		JDBCManager.close(conn);
      static void setup() throws SQLException {
    	System.out.println("Creation de la table RESERVE");
    	try {
    	  stmt = conn.createStatement();
    	  stmt.addBatch(sqlCreate);
    	  stmt.executeBatch();
    	  System.out.println("Insertion d'une ligne de donnees");
    	  pstmt = conn.prepareStatement(sqlInsert);
    	  pstmt.setString(1, "PIKE");
    	  pstmt.setDate(2, new java.sql.Date(System.currentTimeMillis()));
    	  pstmt.setBoolean(3, false);
    	  pstmt.setNull(4, java.sql.Types.VARCHAR);
    	  pstmt.executeUpdate();
    	  conn.commit();
    	} finally {
    	  JDBCManager.close(pstmt);
    	  JDBCManager.close(stmt);
      static void userAQuery() throws SQLException {
    	System.out.println("L'utilisateur A demande une chambre");
    	stmtA = conn.createStatement();
    	rsetA = stmtA.executeQuery(sqlSelect);
    	if (rsetA.next()) {
    	  System.out.println("La requete retourne une ligne");
    	  roomName = rsetA.getString(1);
    	  roomDate = rsetA.getDate(2);
    	// Ni l'objet Statement ni l'objet ResultSet ne sont fermés ici
    	// Ils doivent rester ouverts userAUpdate()
      static void userAUpdate() throws SQLException {
    	try {
    	  if (roomName != null && roomDate != null) {
    		System.out.println("L'utilisateur A tente de réserver la chambre");
    		pstmt = conn.prepareStatement(sqlUpdate);
    		pstmt.setBoolean(1, true);
    		pstmt.setString(2, "Utilisateur A");
    		pstmt.setString(3, roomName);
    		pstmt.setDate(4, roomDate);
    		int result = pstmt.executeUpdate();
    		if (result == 0) {
    		  System.out.println("La réservation n'a PAS réussi !");
    		  System.out.println("L'utilisateur devra essayer avec " +
    		  					 "une autre chambre ou une autre date");
    		} else {
    		  System.out.println("Validation pour l'utilisateur A");
    		  conn.commit();
    	} catch (SQLException e) {
    	  e.printStackTrace(DriverManager.getLogWriter());
    	  System.out.println(e.getErrorCode());
    	  System.out.println(e.getMessage());
    	} finally {
    	  JDBCManager.close(rsetA);
    	  JDBCManager.close(stmtA);
    *PessimisticLockerB.java:
    package Ch07;
    import java.sql.*;
    public class PessimisticLockerB {
      static Statement stmtB;
      static ResultSet rsetB;
          + "RES_NAME=? WHERE ROOMID=? AND RES_DATE=?";
          + "RES_FLAG, RES_NAME from RESERVE WHERE RES_FLAG=false FOR UPDATE";
    	try {
    	  userBQueryAndUpdate();
    	} finally {
      static void userBQueryAndUpdate() throws SQLException {
    	System.out.println("L'utilisateur B tente de réserver la chambre");
    	try {
    	  stmtB = conn.createStatement();
    	  rsetB = stmtB.executeQuery(sqlSelect);
    	  if (rsetB.next()) {
    		System.out.println("L'utilisateur B réserve une chambre");
    		pstmt.setString(2, "User B");
    		pstmt.setString(3, rsetB.getString(1));
    		pstmt.setDate(4, rsetB.getDate(2));
    		System.out.println("Validation pour l'utilisateur B");
    		conn.commit();
      	  } else {
    		System.out.println("Pas de chambre disponible pour l'utilisateur B");
    	} finally {
    	  JDBCManager.close(rsetB);
    	  JDBCManager.close(stmtB);
    Pour faire fonctionner le programme, j'ouvre deux fenêtres et je configure le classpath dans chacune d'elle comme ceci:
    set classpath=.;C:\Sun\AppServer\pointbase\lib\pbclient.jar
    Ensuite je tape cette commande dans une fenêtre:
    java -Djdbc.drivers=com.pointbase.jdbc.jdbcUniversalDriver Ch07.PessimisticLockerA
    Puis celle-ci dans l'autre:
    java -Djdbc.drivers=com.pointbase.jdbc.jdbcUniversalDriver Ch07.PessimisticLockerB
    J'exécute la première commande, j'ai ceci qui s'affiche:
    conn autocommit : false
    Interruption de 15 second, lancer PessimisticLockerB
    Je lance PessimisticLockerB, voici le message d'erreur:
    java.sql.SQLException: No suitable driver
    at java.sql.DriverManager.getConnection(DriverManager.java:532)
    at Ch07.JDBCManager.getConnection(JDBCManager.java:34)
    at Ch07.PessimisticLockerB.main(PessimisticLockerB.java:27)
    Là j'avoue que je ne comprends pas très bien, le programme semblait correct, puisque le JDBCManager avait été essayé sur un précédent programme qui marchait très bien.
    Enfin sur la première fenêtre, j'ai ces messages ci:
    L'utilisateur devra essayer avec une autre chambre ou une autre date
    Si quelqu'un peut m'éclairer, je suis preneur.
    Merci d'avance, mumu27!
    Mars 2009
    Bonjour en fait, j'ai dû faire une mauvaise manip, je n'ai plus le message d'erreur:
    En revanche, j'ai toujours un problème, en effet après l'exécution de la classe PessimisticLockerA, j'ai bien ce que je veux:
    Après je lance PessimisticLockerB et j'ai:
    Le traitement de la classe PessimisticLockerB s'interrompt. Jusqu'ici tout va bien. Mais après l'exécution de la classe Pessimisticl=LockerB reprend, voici le message:
    L'utilisateur B a réserve une chambre
    Puis l'exécution de la classe PessimisticLockerA reprend:
    L'utilisateur A tente de reserver la chambre
    La reservation n'a PAS réussi !
    Hors lorsque le traitement de PessimisticLockerB s'interrompt, j'aurais souhaité lors de la reprise que cela soit PessimsticLockerA qui reprend, ainsi j'aurais eu:
    Ensuite seulement la classe de la requête PessimisticLockerB se serait exécuté:
    Pouvez-vous me dire pourquoi, c'est la classe PessimisticLockerB qui apparemment redémarre en premier et pas PessimisticLockerA, afin que je puisse faire la correction de ce programme.
    Mars 2009
    J'ai oublié de préciser, j'utilise Tomcat 5.5, car je pense que cela peut être important.
    mumu27!
    Mars 2009
    Erratum, je n'utilise pas Tomcat 5.5, mais le serveur J2EE de sun.
    Excusez-moi pour l'erreur.
    Mumu27!
    Mars 2009
    finalement, j'ai testé les programmes sous un autre ordi qui est sous XP et les exemples fonctionnent parfaitement bien. Je ne sais, si le problème vient du fait que mon ordi est sous Windows 7 ou si le problème vient de l'antivirus que j'ai installé avec Windows 7, en l'occurrence, Norton. Si vous avez une idée d'où provient le disfonctionnement?
    mumu27!
  1. Réponses: 4
    Dernier message: 07/02/2005, 17h12
  2. Réponses: 3
    Dernier message: 08/12/2004, 22h11
  3. Réponses: 5
    Dernier message: 19/08/2004, 12h11
  4. [JTextField][JDBC] Problème d'affichage
    Par deathwing dans le forum JDBC
    Dernier message: 12/05/2004, 15h50
  5. [JDBC] Problème avec les accents
    Par seawolfm dans le forum Administration
    Dernier message: 29/01/2004, 15h56
