[OpenGL]Compilation avec GLUT
    Membre éclairé Avatar de saad.hessane
    Avril 2008
    Par défaut [OpenGL]Compilation avec GLUT
    Bonjour tout le monde.
    Après avoir lu les cours de NeHe sur OpenGL avec l'API WIN32, j'ai commencé à lire le livre "OpenGL programming guide - the red book". Le livre utilise GLUT. Je n'arrive pas à compiler avec Visual Studio 2008 le code suivant :
    Code C++ : Sélectionner tout - Visualiser dans une fenêtre à part
     * Copyright (c) 1993-2003, Silicon Graphics, Inc.
     * All Rights Reserved
     * Permission to use, copy, modify, and distribute this software for any
     * purpose and without fee is hereby granted, provided that the above
     * copyright notice appear in all copies and that both the copyright
     * notice and this permission notice appear in supporting documentation,
     * and that the name of Silicon Graphics, Inc. not be used in
     * advertising or publicity pertaining to distribution of the software
     * without specific, written prior permission.
     * THE MATERIAL EMBODIED ON THIS SOFTWARE IS PROVIDED TO YOU "AS-IS" AND
     * WITHOUT WARRANTY OF ANY KIND, EXPRESS, IMPLIED OR OTHERWISE,
     * INCLUDING WITHOUT LIMITATION, ANY WARRANTY OF MERCHANTABILITY OR
     * FITNESS FOR A PARTICULAR PURPOSE.  IN NO EVENT SHALL SILICON
     * GRAPHICS, INC.  BE LIABLE TO YOU OR ANYONE ELSE FOR ANY DIRECT,
     * SPECIAL, INCIDENTAL, INDIRECT OR CONSEQUENTIAL DAMAGES OF ANY KIND,
     * OR ANY DAMAGES WHATSOEVER, INCLUDING WITHOUT LIMITATION, LOSS OF
     * PROFIT, LOSS OF USE, SAVINGS OR REVENUE, OR THE CLAIMS OF THIRD
     * PARTIES, WHETHER OR NOT SILICON GRAPHICS, INC.  HAS BEEN ADVISED OF
     * THE POSSIBILITY OF SUCH LOSS, HOWEVER CAUSED AND ON ANY THEORY OF
     * LIABILITY, ARISING OUT OF OR IN CONNECTION WITH THE POSSESSION, USE
     * OR PERFORMANCE OF THIS SOFTWARE.
     * US Government Users Restricted Rights
     * Use, duplication, or disclosure by the Government is subject to
     * restrictions set forth in FAR 52.227.19(c)(2) or subparagraph
     * (c)(1)(ii) of the Rights in Technical Data and Computer Software
     * clause at DFARS 252.227-7013 and/or in similar or successor clauses
     * in the FAR or the DOD or NASA FAR Supplement.  Unpublished - rights
     * reserved under the copyright laws of the United States.
     * Contractor/manufacturer is:
     *	Silicon Graphics, Inc.
     *	1500 Crittenden Lane
     *	Mountain View, CA  94043
     *	United State of America
     * OpenGL(R) is a registered trademark of Silicon Graphics, Inc.
     * hello.c
     * This is a simple, introductory OpenGL program.
    #include <GL/glut.h>
    #include <stdlib.h>
    void display(void)
    /* clear all pixels  */
       glClear (GL_COLOR_BUFFER_BIT);
    /* draw white polygon (rectangle) with corners at
     * (0.25, 0.25, 0.0) and (0.75, 0.75, 0.0)
       glColor3f (1.0, 1.0, 1.0);
       glBegin(GL_POLYGON);
          glVertex3f (0.25, 0.25, 0.0);
          glVertex3f (0.75, 0.25, 0.0);
          glVertex3f (0.75, 0.75, 0.0);
          glVertex3f (0.25, 0.75, 0.0);
       glEnd();
    /* don't wait!
     * start processing buffered OpenGL routines
       glFlush ();
    void init (void)
    /* select clearing color 	*/
       glClearColor (0.0, 0.0, 0.0, 0.0);
    /* initialize viewing values  */
       glMatrixMode(GL_PROJECTION);
       glLoadIdentity();
       glOrtho(0.0, 1.0, 0.0, 1.0, -1.0, 1.0);
     * Declare initial window size, position, and display mode
     * (single buffer and RGBA).  Open window with "hello"
     * in its title bar.  Call initialization routines.
     * Register callback function to display graphics.
     * Enter main loop and process events.
    int main(int argc, char** argv)
       glutInit(&argc, argv);
       glutInitDisplayMode (GLUT_SINGLE | GLUT_RGB);
       glutInitWindowSize (250, 250);
       glutInitWindowPosition (100, 100);
       glutCreateWindow ("hello");
       init ();
       glutDisplayFunc(display);
       glutMainLoop();
       return 0;   /* ANSI C requires main to return int. */
    L'erreur que j'ai à la compilation :
    1>c:\program files\microsoft visual studio 9.0\vc\include\stdlib.h(371) : error C2381: 'exit'*: redéfinition*; __declspec(noreturn) est différent
    Avril 2008
    C'est bon, j'ai trouvé tout seul. Il faut créer un projet Console, et il faut inclure stdlib.h avant glut.h.
  1. Impossible d'appliquer une texture avec Glut et Opengl
    Par akrogames dans le forum OpenGL
    Dernier message: 29/10/2010, 11h20
  2. Réponses: 3
    Dernier message: 19/05/2009, 16h32
  3. Bien compiler avec qt4, OpenGL et lib3ds
    Par Robert Dumarais dans le forum OpenGL
    Dernier message: 15/12/2008, 14h17
  4. Slider OpenGl (avec Glut)
    Par spnzero dans le forum OpenGL
    Dernier message: 22/11/2008, 12h12
  5. Gros pb de débutant sous opengl avec glut
    Par mozillo3625 dans le forum Dev-C++
    Dernier message: 06/12/2007, 15h21
