Voila, je vous mets les requêtes :Construction des partitions
27 DROP TABLE WF_T_EXP_DATA CASCADE CONSTRAINTS ; CREATE TABLE WF_T_EXP_DATA ( IFC_CODE VARCHAR2 (16) NOT NULL, RCD_STATUS NUMBER (1) NOT NULL, EXP_DATE DATE NOT NULL, RCD_DATA VARCHAR2 (4000), RCD_EVT_STATUS NUMBER (1) ) PARTITION BY HASH (IFC_CODE) PARTITIONS 16 STORE IN ( MES_MMS_XS_DATA,MES_MMS_XS_DATA,MES_MMS_XS_DATA, MES_MMS_XS_DATA,MES_MMS_XS_DATA,MES_MMS_XS_DATA,MES_MMS_XS_DATA, MES_MMS_XS_DATA,MES_MMS_XS_DATA,MES_MMS_XS_DATA,MES_MMS_XS_DATA, MES_MMS_XS_DATA,MES_MMS_XS_DATA,MES_MMS_XS_DATA,MES_MMS_XS_DATA, MES_MMS_XS_DATA);
Et voila ce que j'ai comme erreur
38 ALTER TABLE MMS.WF_T_EXP_DATA ADD RCD_EVT_STATUS NUMBER(1); ALTER TABLE MMS.WF_T_EXP_DATA ADD PARTITION P_REJ_IMP_LN VALUES ('REJ_IMP_LN') TABLESPACE MES_MMS_XS_DATA; ALTER TABLE MMS.WF_T_EXP_DATA ADD PARTITION P_REJ_IMP_NA VALUES ('REJ_IMP_NA') TABLESPACE MES_MMS_XS_DATA; ALTER TABLE MMS.WF_T_EXP_DATA ADD PARTITION P_REJ_IMP_NB VALUES ('REJ_IMP_NB') TABLESPACE MES_MMS_XS_DATA; ALTER TABLE MMS.WF_T_EXP_DATA ADD PARTITION P_REJ_IMP_AM VALUES ('REJ_IMP_AM') TABLESPACE MES_MMS_XS_DATA; ALTER TABLE MMS.WF_T_EXP_DATA ADD PARTITION P_REJ_IMP_PTF VALUES ('REJ_IMP_PTF') TABLESPACE MES_MMS_XS_DATA; ALTER TABLE MMS.WF_T_EXP_DATA ADD PARTITION P_REJ_IMP_CO VALUES ('REJ_IMP_CO') TABLESPACE MES_MMS_XS_DATA; ALTER TABLE MMS.WF_T_EXP_DATA ADD PARTITION P_REJ_IMP_LR VALUES ('REJ_IMP_LR') TABLESPACE MES_MMS_XS_DATA; ALTER TABLE MMS.WF_T_EXP_DATA ADD PARTITION P_REJ_EXP_LN VALUES ('REJ_EXP_LN') TABLESPACE MES_MMS_XS_DATA; ALTER TABLE MMS.WF_T_EXP_DATA ADD PARTITION P_REJ_EXP_NA VALUES ('REJ_EXP_NA') TABLESPACE MES_MMS_XS_DATA; ALTER TABLE MMS.WF_T_EXP_DATA ADD PARTITION P_REJ_EXP_NB VALUES ('REJ_EXP_NB') TABLESPACE MES_MMS_XS_DATA; ALTER TABLE MMS.WF_T_EXP_DATA ADD PARTITION P_REJ_EXP_AM VALUES ('REJ_EXP_AM') TABLESPACE MES_MMS_XS_DATA; ALTER TABLE MMS.WF_T_EXP_DATA ADD PARTITION P_REJ_EXP_PTF VALUES ('REJ_EXP_PTF') TABLESPACE MES_MMS_XS_DATA;Je suis venu ici en effectuant les solutions proposées, mais ça change rien du tout.
Code : Sélectionner tout - Visualiser dans une fenêtre à part ORA-14400:inserted partition key does not map to any partition
Quelqu'un peut me dire ou se trouve mon erreur ?
PS : Oracle 9i comme SGBD.
