1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139
| #include <GL/glut.h>
#include <stdio.h>
#include <jpeglib.h>
#include <jerror.h>
#include <stdlib.h>
unsigned char image[800*600*3];
unsigned char texture[800][600][3];
unsigned char rouge[800][600][3],vert[800][600][3],bleu[800][600][3];
void affichage();
void displayEye();
void loadJpegImage(char *fichier);
int main(int argc,char **argv)
loadJpegImage("paysage.jpg");
/* initialisation de glut et creation
de la fenetre */
glutInit(&argc,argv);
glutInitDisplayMode(GLUT_RGB);
glutInitWindowPosition(250,100);
glutInitWindowSize(800,600);
glutCreateWindow("Lunette 3D");
/* Initialisation d'OpenGL */
glClearColor(0.0,0.0,0.0,0.0);
glShadeModel(GL_FLAT);
glColor3f(1.0,1.0,1.0);
glPointSize(1.0);
/* enregistrement des fonctions de rappel */
glutDisplayFunc(affichage);
/* Entree dans la boucle principale glut */
glutMainLoop();
return 0;
void affichage()
/* effacement de l'image avec la couleur de fond */
glClear(GL_COLOR_BUFFER_BIT | GL_ACCUM_BUFFER_BIT);
glTexParameteri(GL_TEXTURE_2D,GL_TEXTURE_MAG_FILTER,GL_NEAREST);
glTexParameteri(GL_TEXTURE_2D,GL_TEXTURE_MIN_FILTER,GL_NEAREST);
glTexImage2D(GL_TEXTURE_2D,0,GL_RGB,800,600,0,GL_RGB,GL_UNSIGNED_BYTE,rouge);
glEnable(GL_TEXTURE_2D);
//glColorMask(1,0,0,1);
displayEye();
glTranslatef(0.02,0,0);
glTexImage2D(GL_TEXTURE_2D,0,GL_RGB,800,600,0,GL_RGB,GL_UNSIGNED_BYTE,bleu);
glColorMask(0,1,1,1);
displayEye();
/* on force l'affichage du resultat */
glFlush();
void displayEye(void){
/* Dessin du polygone */
glBegin(GL_POLYGON);
//glColor3f(1.0,0.0,0.0);
glTexCoord2i(0,1);glVertex2f(-1,-1);
//glColor3f(0.0,1.0,0.0);
glTexCoord2i(1,1);glVertex2f(1,-1);
//glColor3f(0.0,0.0,1.0);
glTexCoord2i(1,0);glVertex2f(1,1);
//glColor3f(1.0,1.0,1.0);
glTexCoord2i(0,0);glVertex2f(-1,1);
glEnd();
struct jpeg_decompress_struct cinfo;
struct jpeg_error_mgr jerr;
FILE *file;
unsigned char *ligne;
int i,j;
cinfo.err = jpeg_std_error(&jerr);
jpeg_create_decompress(&cinfo);
if ((file=fopen(fichier,"rb"))==NULL)
fprintf(stderr,"Erreur : impossible d'ouvrir le fichier texture.jpg\n");
exit(1);
jpeg_stdio_src(&cinfo, file);
jpeg_read_header(&cinfo, TRUE);
if ((cinfo.image_width!=800)||(cinfo.image_height!=600)) {
fprintf(stdout,"Erreur : l'image doit etre de taille 800x600\n");
exit(1);
if (cinfo.jpeg_color_space==JCS_GRAYSCALE) {
fprintf(stdout,"Erreur : l'image doit etre de type RGB\n");
exit(1);
jpeg_start_decompress(&cinfo);
ligne=image;
while (cinfo.output_scanline<cinfo.output_height)
ligne=image+3*800*cinfo.output_scanline;
jpeg_read_scanlines(&cinfo,&ligne,1);
jpeg_finish_decompress(&cinfo);
jpeg_destroy_decompress(&cinfo);
for (i=0;i<800;i++){
for (j=0;j<600;j++) {
//image RVB
texture[i][j][0]=image[i*600*3+j*3];
texture[i][j][1]=image[i*600*3+j*3+1];
texture[i][j][2]=image[i*600*3+j*3+2];
//image rouge
rouge[i][j][0]=image[i*600*3+j*3];
//image verte
vert[i][j][1]=image[i*600*3+j*3+1];
//image bleu
bleu[i][j][2]= image[i*600*3+j*3+2];
