Bonjour à vous,
Etant relativement débutant dans les bases de données, il faut que j' optimise des requetes existantes pour arriver à un résultat correct...
la requete en cause:
Donc pour les infos utiles:
32 SELECT DISTINCT OULINE.OBCONO AS XXCONO, OULINE.OBWHLO AS XXWHLO, OULINE.OBITNO AS XXITNO, OUATTR.AHAALF AS XXPACT, OULINE.OBCUNO AS XXCUNO, OCUSMA.OKCUNM AS XXCUNM, LEATTR.AHAALF AS XXECVE, ISNULL((SELECT SUM((ISNULL(INLINE.OBRNQT, 0) + ISNULL(INLINE.OBALQT, 0) + ISNULL(INLINE.OBPLQT, 0))) FROM OOLINE INLINE WHERE INLINE.OBCUNO = OULINE.OBCUNO AND INLINE.OBWHLO = OULINE.OBWHLO AND INLINE.OBCONO = OULINE.OBCONO AND INLINE.OBATNR IN (SELECT INATTR.AHATNR FROM MOATTR INATTR, MOATTR RIATTR WHERE INATTR.AHATID = 'CDT' AND INATTR.AHAALF = OUATTR.AHAALF AND INATTR.AHATNR = RIATTR.AHATNR AND RIATTR.AHATID = 'IND' AND RIATTR.AHAALF = LEATTR.AHAALF) AND INLINE.OBITNO = OULINE.OBITNO AND INLINE.OBDSDT < (CONVERT(int, CONVERT(varchar(30), GETDATE(), 112)))), 0) AS Q12 FROM dbo.OOLINE OULINE INNER JOIN dbo.MOATTR OUATTR ON OULINE.OBATNR = OUATTR.AHATNR INNER JOIN dbo.MOATTR LEATTR ON OUATTR.AHATNR = LEATTR.AHATNR AND OUATTR.AHCONO = LEATTR.AHCONO INNER JOIN dbo.OCUSMA OCUSMA ON OULINE.OBCUNO = OCUSMA.OKCUNO AND OULINE.OBCONO = OCUSMA.OKCONO WHERE (LEATTR.AHATID = 'IND') AND (OUATTR.AHATID = 'CDT') AND (OULINE.OBDSDT <= CONVERT(int, CONVERT(varchar(30), GETDATE(), 112)) + 35) AND (SUBSTRING(OULINE.OBORST, 1, 1) < '6') AND (SUBSTRING(OULINE.OBORST, 1, 1) >= '2')
Tables
_ooline : environ 400 000 enregistrements
_moattr : environ 9 000 000 enregistrements
Nombre d'enregistrements retournés : 6900
Pour la table OOLINE:
Pour les index :
42 CREATE TABLE [OOLINE] ( [OBCONO] [smallint] NOT NULL , [OBDIVI] [char] (3) COLLATE SQL_Latin1_General_CP1_CI_AS NOT NULL , [OBORNO] [char] (10) COLLATE SQL_Latin1_General_CP1_CI_AS NOT NULL , [OBPONR] [smallint] NOT NULL , [OBPOSX] [tinyint] NOT NULL , [OBORST] [char] (2) COLLATE SQL_Latin1_General_CP1_CI_AS NOT NULL , [OBFACI] [char] (3) COLLATE SQL_Latin1_General_CP1_CI_AS NOT NULL , [OBWHLO] [char] (3) COLLATE SQL_Latin1_General_CP1_CI_AS NOT NULL , [OBITNO] [char] (15) COLLATE SQL_Latin1_General_CP1_CI_AS NOT NULL , [OBORQT] [decimal](15, 6) NOT NULL , [OBRNQT] [decimal](15, 6) NOT NULL , [OBALQT] [decimal](15, 6) NOT NULL , [OBPLQT] [decimal](15, 6) NOT NULL , [OBDLQT] [decimal](15, 6) NOT NULL , [OBIVQT] [decimal](15, 6) NOT NULL , [OBNEPR] [decimal](17, 6) NOT NULL , [OBDWDT] [int] NOT NULL , [OBCODT] [int] NOT NULL , [OBDWDZ] [int] NOT NULL , [OBCODZ] [int] NOT NULL , [OBUCOS] [decimal](17, 6) NOT NULL , [OBUCCD] [tinyint] NOT NULL , [OBDLSP] [char] (12) COLLATE SQL_Latin1_General_CP1_CI_AS NOT NULL , [OBCUNO] [char] (10) COLLATE SQL_Latin1_General_CP1_CI_AS NOT NULL , [OBCUOR] [char] (20) COLLATE SQL_Latin1_General_CP1_CI_AS NOT NULL , [OBINPR] [decimal](17, 6) NOT NULL , [OBDSDT] [int] NOT NULL , [OBDSHM] [smallint] NOT NULL , [OBPLDT] [int] NOT NULL , [OBFDED] [int] NOT NULL , [OBLDED] [int] NOT NULL , [OBATNR] [decimal](17, 0) NOT NULL , [OBRGDT] [int] NOT NULL [/quote] Pour la table MOATTR : [quote]CREATE TABLE [MOATTR] ( [AHCONO] [smallint] NOT NULL , [AHATNR] [decimal](17, 0) NOT NULL , [AHATID] [char] (15) COLLATE SQL_Latin1_General_CP1_CI_AS NOT NULL , [AHAALF] [char] (15) COLLATE SQL_Latin1_General_CP1_CI_AS NOT NULL ) ON [PRIMARY] GO
_ahcono et ahaalf sur MOATTR
_obcono, obdivi, obwhlo, obalqt, obplqt sur OOLINE
Auriez vous des trucs qui vous choqueraient au niveau des performances ?
Sinon, si le post n' est pas conforme ou qu' il y a des choses qui ne vont pas, n' hésiter pas
