1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183
| #include <iostream>
#include <cstdlib>
#include <GL/glew.h>
#include <SFML/Window.hpp>
sf::Window App;
// Un quadric
GLUquadric * sphere = NULL;
// Identifiants
GLuint framebuffer, texture1, depth, depthbuffer;
void InitOGL ()
glewInit ();
// Set color and depth clear value
glClearDepth(1.f);
glClearColor(0.f, 0.f, 0.3f, 1.f);
// Enable Z-buffer read and write
glEnable(GL_DEPTH_TEST);
glDepthMask(GL_TRUE);
// Setup a perspective projection
glMatrixMode(GL_PROJECTION);
glLoadIdentity();
glViewport (0, 0, 512, 512); // On règle le Viewport
glMatrixMode (GL_PROJECTION);
glLoadIdentity ();
gluPerspective (60.0, 512.0 / 512.0, 1.0, 20.0);
glMatrixMode (GL_MODELVIEW);
glLoadIdentity (); // On rétablit la matrice identité
// Création du quadric
sphere = gluNewQuadric ();
glGenFramebuffersEXT(1, &framebuffer);
glGenTextures(1, &texture1);
glBindTexture(GL_TEXTURE_2D, texture1);
glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_MIN_FILTER, GL_LINEAR);
glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_MAG_FILTER, GL_LINEAR);
glTexParameteri(GL_TEXTURE_2D, GL_DEPTH_TEXTURE_MODE, GL_INTENSITY);
glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_COMPARE_MODE, GL_NONE);
//glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_COMPARE_FUNC, GL_LEQUAL);
glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_WRAP_S, GL_CLAMP);
glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_WRAP_T, GL_CLAMP);
glTexImage2D(GL_TEXTURE_2D, 0, GL_DEPTH_COMPONENT, 512, 512, 0, GL_DEPTH_COMPONENT, GL_FLOAT, NULL);
glBindFramebufferEXT(GL_FRAMEBUFFER_EXT, framebuffer);
glFramebufferTexture2DEXT(GL_FRAMEBUFFER_EXT, GL_DEPTH_ATTACHMENT_EXT, GL_TEXTURE_2D, texture1, 0);
glDrawBuffer(GL_NONE);
glReadBuffer(GL_NONE);
glBindFramebufferEXT(GL_FRAMEBUFFER_EXT, 0);
void Destroy ()
gluDeleteQuadric (sphere);
glDeleteFramebuffersEXT (1, &framebuffer);
glDeleteRenderbuffersEXT (1, &depth);
glDeleteTextures (1, &texture1);
void RenderScene ()
// On dessine un sol
glBegin (GL_QUADS);
glNormal3f (0.0f, 1.0f, 0.0f);
glVertex3f (-5.0f, 0.0f, 5.0f);
glVertex3f (-5.0f, 0.0f, -5.0f);
glVertex3f (5.0f, 0.0f, -5.0f);
glVertex3f (5.0f, 0.0f, 5.0f);
glEnd ();
// Et une sphère
glTranslatef (0.0f, 5.0f, 0.0f);
gluSphere (sphere, 2.0f, 20, 20);
void DrawQuad ()
// On utilise une perception 2D
glPushMatrix ();
glLoadIdentity ();
gluOrtho2D (0.0, 512.0, 0.0, 512.0);
glPushMatrix ();
glLoadIdentity ();
glColor3f (1.0f, 1.0f, 1.0f);
glBegin (GL_QUADS);
glTexCoord2f (0.0f, 0.0f);
glVertex2f (0.0f, 0.0f);
glTexCoord2f (1.0f, 0.0f);
glVertex2f (512.0f, 0.0f);
glTexCoord2f (1.0f, 1.0f);
glVertex2f (512.0f, 512.0f);
glTexCoord2f (0.0f, 1.0f);
glVertex2f (0.0f, 512.0f);
glEnd ();
glPopMatrix ();
glPopMatrix ();
void Render ()
glLoadIdentity ();
gluLookAt (0.0f, 0.0f, 10.0f, 0.0f, 0.0f, 0.0f, 0.0f, 1.0f, 0.0f);
glRotatef (20.0f, 1.0f, 0.0f, 0.0f);
// On rend la scène dans le framebuffer
glBindFramebufferEXT (GL_FRAMEBUFFER_EXT, framebuffer);
glClear (GL_COLOR_BUFFER_BIT | GL_DEPTH_BUFFER_BIT);
RenderScene();
// Puis on dessine la texture
glEnable (GL_TEXTURE_2D);
glBindTexture (GL_TEXTURE_2D, texture1);
DrawQuad ();
glBindTexture (GL_TEXTURE_2D, 0);
glDisable (GL_TEXTURE_2D);
int main()
// Create the main window
App.Create(sf::VideoMode(512, 512, 32), "SFML OpenGL");
// Create a clock for measuring time elapsed
sf::Clock Clock;
InitOGL ();
// Start game loop
bool Running = true;
while (Running)
// Process events
sf::Event Event;
while (App.GetEvent(Event))
// Close window : exit
if (Event.Type == sf::Event::Closed)
Running = false;
// Escape key : exit
if ((Event.Type == sf::Event::KeyPressed) && (Event.Key.Code == sf::Key::Escape))
Running = false;
// Resize event : adjust viewport
if (Event.Type == sf::Event::Resized)
glViewport(0, 0, Event.Size.Width, Event.Size.Height);
// Set the active window before using OpenGL commands
// It's useless here because active window is always the same,
// but don't forget it if you use multiple windows or controls
App.SetCurrent();
Render ();
// Finally, display rendered frame on screen
App.Display();
Destroy ();
return EXIT_SUCCESS;
