Voici ma requête actuelle
si on regarde bien, dans chaque bloc, une partie est commune
111 IF (p_date = '') THEN BEGIN OPEN cur FOR SELECT * FROM t_alerts a, t_alert_base base, t_alert_call CALL WHERE a.pk_alert = base.pk_alert AND CALL.pk_option = base.pk_option AND (p_obj IS NULL OR CALL.option_object = p_obj) AND (p_prd IS NULL OR CALL.product = p_prd) AND (p_ref IS NULL OR base.option_ref = p_ref) AND (p_file IS NULL OR a.pk_file = p_file) AND (p_book IS NULL OR CALL.book IN (SELECT pk_book FROM t_book WHERE lbl = p_book)) AND ( p_cty IS NULL OR CALL.counterparty IN (SELECT pk_counterparty FROM t_counterparty WHERE lbl = p_cty) ); END; ELSIF (p_date = '=') THEN BEGIN OPEN cur FOR SELECT * FROM t_alerts a, t_alert_base base, t_alert_call CALL WHERE a.pk_alert = base.pk_alert AND CALL.pk_option = base.pk_option AND (p_obj IS NULL OR CALL.option_object = p_obj) AND (p_prd IS NULL OR CALL.product = p_prd) AND (p_ref IS NULL OR base.option_ref = p_ref) AND (p_file IS NULL OR a.pk_file = p_file) AND (p_book IS NULL OR CALL.book IN (SELECT pk_book FROM t_book WHERE lbl = p_book)) AND ( p_cty IS NULL OR CALL.counterparty IN (SELECT pk_counterparty FROM t_counterparty WHERE lbl = p_cty) ) AND CALL.alert_date = p_date1; END; ELSIF (p_date = '<') THEN BEGIN OPEN cur FOR SELECT * FROM t_alerts a, t_alert_base base, t_alert_call CALL WHERE a.pk_alert = base.pk_alert AND CALL.pk_option = base.pk_option AND (p_obj IS NULL OR CALL.option_object = p_obj) AND (p_prd IS NULL OR CALL.product = p_prd) AND (p_ref IS NULL OR base.option_ref = p_ref) AND (p_file IS NULL OR a.pk_file = p_file) AND (p_book IS NULL OR CALL.book IN (SELECT pk_book FROM t_book WHERE lbl = p_book)) AND ( p_cty IS NULL OR CALL.counterparty IN (SELECT pk_counterparty FROM t_counterparty WHERE lbl = p_cty) ) AND CALL.alert_date < p_date1; END; ELSIF (p_date = '>') THEN BEGIN OPEN cur FOR SELECT * FROM t_alerts a, t_alert_base base, t_alert_call CALL WHERE a.pk_alert = base.pk_alert AND CALL.pk_option = base.pk_option AND (p_obj IS NULL OR CALL.option_object = p_obj) AND (p_prd IS NULL OR CALL.product = p_prd) AND (p_ref IS NULL OR base.option_ref = p_ref) AND (p_file IS NULL OR a.pk_file = p_file) AND (p_book IS NULL OR CALL.book IN (SELECT pk_book FROM t_book WHERE lbl = p_book)) AND ( p_cty IS NULL OR CALL.counterparty IN (SELECT pk_counterparty FROM t_counterparty WHERE lbl = p_cty) ) AND CALL.alert_date > p_date1; END; ELSIF (p_date = 'Between') THEN BEGIN OPEN cur FOR SELECT * FROM t_alerts a, t_alert_base base, t_alert_call CALL WHERE a.pk_alert = base.pk_alert AND CALL.pk_option = base.pk_option AND (p_obj IS NULL OR CALL.option_object = p_obj) AND (p_prd IS NULL OR CALL.product = p_prd) AND (p_ref IS NULL OR base.option_ref = p_ref) AND (p_file IS NULL OR a.pk_file = p_file) AND (p_book IS NULL OR CALL.book IN (SELECT pk_book FROM t_book WHERE lbl = p_book)) AND ( p_cty IS NULL OR CALL.counterparty IN (SELECT pk_counterparty FROM t_counterparty WHERE lbl = p_cty) ) AND CALL.alert_date > p_date1 AND CALL.alert_date < p_date2; END; END IF;
j'aimerai trouver un moyen "factoriser" tout cela. par exemple en mettant cette partie commune dans une table temporaire puis ensuite faire une select sur cette table selon les autres filtres (if, etc).
17 OPEN cur FOR SELECT * FROM t_alerts a, t_alert_base base, t_alert_call CALL WHERE a.pk_alert = base.pk_alert AND CALL.pk_option = base.pk_option AND (p_obj IS NULL OR CALL.option_object = p_obj) AND (p_prd IS NULL OR CALL.product = p_prd) AND (p_ref IS NULL OR base.option_ref = p_ref) AND (p_file IS NULL OR a.pk_file = p_file) AND (p_book IS NULL OR CALL.book IN (SELECT pk_book FROM t_book WHERE lbl = p_book)) AND ( p_cty IS NULL OR CALL.counterparty IN (SELECT pk_counterparty FROM t_counterparty WHERE lbl = p_cty) )
l'avantage: meilleure visibilité, et surtout un seul bloc de code à maintenir.
peut-être surtout que cela m'aidera à trouver l'origine de l'erreur "ORA-24338: statement handle not executed". je suppose que ca vient des cursor imbriqués dans un bloc IF mais je vois pas comment faire dedans.
merci d'avance à celui(ceux) qui pourra(ont) m'éclairer.
