Camera en opengl avec gluLookAt
    Avatar de Happy
    Juin 2005
    Par défaut Camera en opengl avec gluLookAt
    Je comprends pas bien commen faire et j'ai beau a essayer.ca marche pas comme je voulais.
    Voici le code:
    #include <SDL/SDL.h>
    #include <GL/gl.h>
    #include <GL/glu.h>
    int up,right;
    SDL_Event event;
    void draw_screen(void)
    while (1)
    glMatrixMode(GL_MODELVIEW);
    glLoadIdentity();
    if (event.type == SDL_KEYDOWN && event.key.keysym.sym == SDLK_UP)
     up = (up + 1);
    if (event.type == SDL_KEYDOWN && event.key.keysym.sym == SDLK_DOWN)
     up = (up - 1);
    if (event.type == SDL_KEYDOWN && event.key.keysym.sym == SDLK_LEFT)
     right = (right + 1);
    if (event.type == SDL_KEYDOWN && event.key.keysym.sym == SDLK_RIGHT)
     right = (right - 1);
    gluLookAt(right,up,1,0,0,0,0,1,0);
    glTranslatef(0.0f,0.0f,0.0f);
    glBegin(GL_QUADS);
     glColor3d(1,0,0);
     glVertex3i(1,1,1);
     glColor3d(-1,-9,0);
     glColor3d(1,-3,5);
     glVertex3i(1,-1,1);
     glColor3d(3,1,-1);
     glVertex3i(-1,-1,1);
     glColor3d(-1,-1,0);
     glVertex3i(-1,1,1);
     glColor3d(1,1,0);
     glVertex3i(1,1,-1);
     glColor3d(-1,-1,-1);
     glVertex3i(1,-1,-1);
     glColor3d(-1,-1,0);
     glVertex3i(-1,-1,-1);
     glColor3d(-1,-1,0);
     glVertex3i(-1,1,-1);
     glColor3d(1,0,-1);
     glVertex3i(1,1,1);
     glColor3d(2,-1,0);
     glVertex3i(1,-1,1);
     glColor3d(-1,-1,0);
     glVertex3i(1,1,-1);
     glColor3d(1,3,0);
     glVertex3i(-1,1,1);
     glColor3d(-1,4,-1);
     glColor3d(3,-1,0);
     glColor3d(1,0,0);
     glColor3d(-1,0,6);
     glColor3d(-1,2,-2);
     glVertex3i(-1,1,1);
     glColor3d(1,-5,0);
     glVertex3i(1,1,1);
     glColor3d(-1,-1,0);
     glVertex3i(1,1,-1);
     glColor3d(-1,-1,0);
     glColor3d(-3,2,0);
     glVertex3i(1,-1,1);
     glColor3d(-1,-2,3);
    glEnd();
    SDL_GL_SwapBuffers();
    SDL_PollEvent (&event);
    if (event.type == SDL_KEYDOWN && event.key.keysym.sym == SDLK_ESCAPE)
     SDL_Quit();
     return;
    void setup_opengl( int hauteur, int largeur )
       float ratio = (float) hauteur / (float) largeur;
       glClearColor(0, 0, 0, 0);
       glViewport(0, 0, hauteur, largeur);
       glMatrixMode(GL_PROJECTION);
       glLoadIdentity();
       gluPerspective(45, ratio, 0.5, 50);
       glEnable(GL_DEPTH_TEST);
    int main(int argc, char **argv)
       int hauteur = 800;
       int largeur = 600;
       int bits = 32;
       int flags = 0;
       SDL_Init(SDL_INIT_VIDEO);
       flags = SDL_OPENGL;
       SDL_SetVideoMode(hauteur,largeur,bits,flags);
       setup_opengl(hauteur,largeur);
       draw_screen();
       return 0;
    gluLookAt(0,0,0,0,0,0,0,0,0);
    je sais que les 1eres 3 zero c'est le point x,y,z ou se trouve la caméra, les 3 suivantes .. c'est le point x,y,z ou elle regarde.. et les dernieres 3dernieres je sais pas ce que ca fais.
    Mais le resultat n'est pas bon.Est ce que vous savez comment s'ii prendre? Merci d'avance
    Août 2004
    déjà, si tu ne nous dis pas ce que tu veux, c'est pas nous qui allons le devnier.. ça marche pas comme tu l'attend, ok, c'ets cool, mais c'est quoi que t'attend ?
    les trois dernières donne la "direction du haut", en gro c'est les coordonnées d'un vecteur qui serait colinaires au pied de la camera
    mais bon, si tu veux un conseil ne fais pas une camera avec un glulookat... calcul tes matrices à coup de quaternions et fais un beau glMulMatrix final... c'est plus mieux, ça te permettra de gérer facilemet n'importe quel type de camera (camera 3eme, première personne, jeu d'avion, ...) enfin moi j'ai comencé à réussir à faire une classe de camera cohérente à partir du moment où je me suis intéréssé aux quaternions... c'est donc mon conseil, fais signe si tu veux des docs sur ces outils d'algèbre qui ne sont pas des notions évidentes pour tout le monde, a commencé par moi (et je m'en suis sorti, alors..)
    voili
    ps : au lieu décrire a = (a + 1), qui est relativement lourd, pense à l'opérateur a += 1
    Avatar de Happy
    Juin 2005
    Merci pour ta rep , désolé j'ai oublier de preciser , je voulais bien gerer la camera, par exemple quand j'appuye sur la fleche gauche .. que ca tourne a gauche sur un axe..j'arrive pas..
    Il faut utiliser l'axe des 3 dernieres 0 du gluLookAt si j'ai bien compri?
    Sinon quaternions ca a l'aire un peu plus compliqué ,je vais voir .. encore merci.
    Août 2004
    il faut réfléchir deux secondes... qu'est ce qu'il se passe lorque tu appuies sur la gauche la... tu une coordonnée de ton vecteur position qui s'incrémente, autrement dit, tu subi une espèce de translation suivant une composante, et en même temps une rotation puisque ton vecteur "direction de la camera" est fixe (il pointe sur l'ortigine)
    en fait, si tu veux faire effectuer un rotation tout en restant immobile (rotation suivant un des axe du repère lié à la camera), tu dois changer le vecteurde la direction !
    bon c'est pas très clair tout ça...
    glulookat prend trois vecteurs, position, direction, orientation (va t on les appeler ici)
    position designe la position de la camera au sein de la scène en 3d, direction designe le point fixé par la camera, et orientation designe en gros si on a la tête en haut en bas ou dans un position intermédiare
    ne nous occupons pas celui là...
    nous avons donc position et direction, orientation reste constant et a pour valeur (0, 1, 0) si on considère que le cameraman est sobre
    la difficulté de gérer une telle camera en mouvement est de calculer la bonne valeur du vecteur direction... en effet lorsque tu tournes autour de toi, position est contant, ok ? tu ne bouges car tu es au centre de la rotation... donc ce n'est pas sur ce vecteur que l'on va agir...
    ton glulookat à cette geule :
    gluLookAt(pos[0], pos[1], pos[2], dir[0], dir[1], dir[2], 0.0, 1.0, 0.0);
    avec à t = 0 :
    pos[0] = pos[1] = pos[2] = 0.0;
    dir[0] = pos[0];
    dir[1] = pos[1];
    dir[2] = pos[2] + 20; // tu regardes devant toi sur z (convention)
    maintenant si tu avances (up) :
    pos[0] += dir[0] * speed;
    pos[1] += dir[1] * speed;
    pos[2] += dir[2] * speed;
    (-= si tu recules (down))
    et quand tu tournes... ben il faut que ton vecteur direction garde une norme constante... donc tu ajoutes une composante sur x que tu retranche sur z... sur y on va dire que ça bouge pas (le gars peut pas lever les yeux au ciel... sinon c'est trop chiant )
    bon alors si on va à gauche, on calcul :
    depl = speed;
    sinon (droite),
    depl = -speed;
    puis
    dir[0] += depl;
    dir[2] -= depl;
    voili... bon alors y'a rien de garanti, c'est plus pour expliquer, hein ? le code source je l'ai tapé à l'arache mais je pens que mon truc est cohérent...
    bon après comme je t'ai dit, tout ça, c'est avant de se pencher sur es quaternions ça t'ouvre des portes fabuleuses ce truc !
    tiens, je viens d'avoir uen autre idée, tu initialises un angle theta = 0, et tu dis que :
    dir[0] = sin(theta) * dist; // dist est une constante (20 dans l'exemple précédent)
    dir[1] = 0.0;
    dir[2] = cos(theta) * dist;
    après, lorsque tu appuies sur droite et gauche, tu fais sincrémenter ou se décrémenter la valeur de theta en fonction de la constante speed, et tu recalcules tes coordonées en cosinus et sinus à chaque fois... ça devrait marcher !
  1. Changement angle camera avec glulookat()
    Par Despak dans le forum OpenGL
    Dernier message: 28/02/2007, 11h16
  2. Redefiniton de la camera avec gluLookAt();
    Par AliceD dans le forum OpenGL
    Dernier message: 03/08/2006, 19h44
  3. GTK et OPENGL avec gtkglarea
    Par Vincent|Dev dans le forum OpenGL
    Dernier message: 09/02/2005, 14h33
  4. erreurs opengl avec devcpp
    Par Vermin dans le forum OpenGL
    Dernier message: 13/04/2004, 15h50
  5. comment utiliser de l'OpenGL avec du Java ?
    Par DjiZ dans le forum OpenGL
    Dernier message: 14/01/2004, 16h21
