Problème Servlet / Quartz
Servlets/JSP Java
    Mars 2006
    Par défaut Problème Servlet / Quartz
    Je dois développer un planificateur de tâches avec quartz en java sous une servlet pour qu'il puisse démarrer en même temps que le serv apache, mais il y a quelque chose qui ne va pas. Je vous montre la source.
    MyWebApp.java
    ublic class MyWebApp extends HttpServlet {
        public static final String QUARTZ_FACTORY_KEY = "org.quartz.impl.StdSchedulerFactory.KEY";
        private boolean performShutdown;
        private Scheduler scheduler;
    	Calendar cal = Calendar.getInstance();
        public MyWebApp()
            performShutdown = true;
            scheduler = null;
        public void init(ServletConfig cfg)
            throws ServletException
            super.init(cfg);
            System.out.println("Quartz Initializer Servlet loaded, initializing Scheduler...");
            try
                String configFile = cfg.getInitParameter("config-file");
                String shutdownPref = cfg.getInitParameter("shutdown-on-unload");
                if(shutdownPref != null)
                    performShutdown = Boolean.valueOf(shutdownPref).booleanValue();
                StdSchedulerFactory factory;
                if(configFile != null)
                    factory = new StdSchedulerFactory(configFile);
                } else
                    factory = new StdSchedulerFactory();
                scheduler = factory.getScheduler();
                String startOnLoad = cfg.getInitParameter("start-scheduler-on-load");
                if(startOnLoad == null || Boolean.valueOf(startOnLoad).booleanValue())
    			if(scheduler.isStarted()){
    			System.out.println("~~~~~~~~~~~~~~~~~~This is the Alarm message Scheduler Already started~~~~~~~~~~~~~~~~~~~``");	}
    			scheduler.start();
                    System.out.println("TriggerMail Started  for 3 and 3.15");
                } else
                    System.out.println("Scheduler has not been started. Use scheduler.start()");
                String factoryKey = cfg.getInitParameter("servlet-context-factory-key");
                if(factoryKey == null)
                    factoryKey = "org.quartz.impl.StdSchedulerFactory.KEY";
                System.out.println("Storing the Quartz Scheduler Factory in the servlet context at key: " + factoryKey);
                cfg.getServletContext().setAttribute(factoryKey, factory);
            catch(Exception e)
                System.out.println("Quartz Scheduler failed to initialize: " + e.toString());
                throw new ServletException(e);
    web.xml
    <servlet>
    <servlet-name>MyWebApp</servlet-name>
    <display-name>MyWebApp</display-name>
    <servlet-class>MyWebApp</servlet-class>
    <load-on-startup>2</load-on-startup>
    <init-param>
    <param-name>config-file</param-name>
    <param-value>quartz.properties</param-value>
    </init-param>
    <init-param>
    <param-name>shutdown-on-unload</param-name>
    <param-value>true</param-value>
    </init-param>
    <init-param>
    <param-name>start-scheduler-on-load</param-name>
    </init-param>
    </servlet>
    quartz.properties
    # Configure Main Scheduler Properties
    org.quartz.scheduler.instanceName = SchedulerDeTest
    org.quartz.scheduler.instanceId = scheduler1
    # Configure ThreadPool
    org.quartz.threadPool.class = org.quartz.simpl.SimpleThreadPool
    org.quartz.threadPool.threadCount = -1
    org.quartz.threadPool.threadPriority = 5
    Pour le message d'erreur
    Exception lors de l'allocation pour la servlet MyWebApp
    java.lang.NoClassDefFoundError: MyWebApp (wrong name: MyWebApp/MyWebApp)
            at java.lang.ClassLoader.defineClass1(Native Method)
            at java.lang.ClassLoader.defineClass(ClassLoader.java:620)
            at java.security.SecureClassLoader.defineClass(SecureClassLoader.java:124)
            at org.apache.catalina.loader.WebappClassLoader.findClassInternal(WebappClassLoader.java:1812)
            at org.apache.catalina.loader.WebappClassLoader.findClass(WebappClassLoader.java:866)
            at org.apache.catalina.loader.WebappClassLoader.loadClass(WebappClassLoader.java:1319)
            at org.apache.catalina.loader.WebappClassLoader.loadClass(WebappClassLoader.java:1198)
            at org.apache.catalina.core.StandardWrapper.loadServlet(StandardWrapper.java:1034)
            at org.apache.catalina.core.StandardWrapper.allocate(StandardWrapper.java:757)
            at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:130)
            at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:178)
            at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:126)
            at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:105)
            at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:107)
            at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:148)
            at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:869)
            at org.apache.coyote.http11.Http11BaseProtocol$Http11ConnectionHandler.processConnection(Http11BaseProtocol.java:664)
            at org.apache.tomcat.util.net.PoolTcpEndpoint.processSocket(PoolTcpEndpoint.java:527)
            at org.apache.tomcat.util.net.LeaderFollowerWorkerThread.runIt(LeaderFollowerWorkerThread.java:80)
            at org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.java:684)
            at java.lang.Thread.run(Thread.java:619)
    Si vous pouviez m'aider ^^, si le plus probable vient de tomcat5.0 où directement du fichier java où encore des fichiers annexe tels que quartz.properties (sur lequel j'ai un doute sur son fonctionnement) et web.xml.
    Mars 2006
    Il n'y a personne qui sait utiliser Quartz ? ça m'aiderai vraiment car la je galère pas mal et j'ai vraiment besoin de résoudre ce problème :\
    Directeur technique
    Janvier 2007
    Activité : Directeur technique
    Si tu disais à quoi correspond "MyServlet.java:29" ça pourrait aider aussi ...
    Mars 2006
    Merci chtiq de t'interessé à mon cas, je viens d'éditer mon post, pour ne pas flooder, j'ai changer quelque peu mon appli, mais toujours des problèmes...
    Directeur technique
    Janvier 2007
    Le problème n'est plus le même, là il ne trouve pas ta classe Servlet...
    Ta classe MyWebApp est dans quel package ??
    Mars 2006
    il est bien dans son package, la servlet fonctionne mais au niveau de quartz il y a un problème :\ mais je n'arrive pas à trouver pourquoi
    Avatar de OButterlin
    Novembre 2006
    Dans ton fichier web.xml, le paramètre servlet-class doit être : nom_package.NomServlet
    Dans la servlet, il faudrait également définir la méthode
    public void init(ServletConfig config)
    A+
    Mars 2006
    Merci de ton aide, mais la fonction init() est déjà définit... Et pour le web.xml je pense que tu as raison (un détail de réglé ^^),et toujours une erreur.
    Je vous montre l'erreur que je récupère quand je l'appel depuis le navigateur.
    javax.servlet.ServletException: "Servlet.init()" pour la servlet Webapp a généré une exception
    cause mère
    java.lang.NoClassDefFoundError: javax/transaction/UserTransaction
    	org.quartz.impl.StdSchedulerFactory.instantiate(StdSchedulerFactory.java:1104)
    	org.quartz.impl.StdSchedulerFactory.getScheduler(StdSchedulerFactory.java:1355)
    	WebApp.Webapp.init(Webapp.java:60)
    Et le problème vient de cette ligne je pense, que l'on utilise le fichier quartz .properties ou non :
    WebApp.java
    Ps : MyWebapp = Webapp ( j'ai juste refait mon projet pour verifer )
    Novembre 2006
    Ca ressemble à un jar (de Quartz) qui ne serait pas dans /WEB-INF/lib
    Peux-tu vérifier ?
    Mars 2006
    Ah, c'est juste ce que je viens de trouver avant de lire ton post :p, oui en fait c'est jta.jar qu'il manquait, mais la autre erreur ou j'ai pas eu le tps de travailler dessu
    javax.servlet.ServletException: Thread count must be > 0
    	WebApp.Webapp.init(Webapp.java:91)
    cause mère
    org.quartz.SchedulerConfigException: Thread count must be > 0
    	org.quartz.simpl.SimpleThreadPool.initialize(SimpleThreadPool.java:232)
    	org.quartz.impl.StdSchedulerFactory.instantiate(StdSchedulerFactory.java:1154)
    	WebApp.Webapp.init(Webapp.java:63)
    serait parce que je n'ai pas implementé de thread ? la class scheduler n'instancie pas un thread ? dans tous les cas je vais verifier je vous tiens au courant^^
    Novembre 2006
    En regardant la doc de Quartz j'ai vu qu'il y avait un fichier quartz.properties qui fait référence à un nombre de thread.
    Tu ne l'aurais pas oublié par hasard ?
    http://www.onjava.com/pub/a/onjava/2...tz.html?page=2
    Mars 2006
    Oui Merci beaucoup , c'etait bien ça , la je n'ai plus de problème je vais pouvoir me lancer dans les jobs et jobstore. A bientot
    Futur Membre du Club
    Avril 2010
    pouvez vous m'aider j'ai eu le meme probleme :org.quartz.SchedulerConfigException: Thread count must be > 0
    pourtant j'ai changer dans le fichier quartz.properties (org.quartz.threadPool.threadCount =10)
    merci d'avance.
  1. Problème API Quartz
    Par yaya0057 dans le forum API standards et tierces
    Dernier message: 06/10/2009, 23h38
  2. problème servlet enregistrement
    Par stofeben dans le forum Servlets/JSP
    Dernier message: 04/06/2007, 16h18
  3. problème servlet xml
    Par youp_db dans le forum Tomcat et TomEE
    Dernier message: 02/10/2006, 15h46
  4. problème servlet + JDBC sur tomcat
    Par pellec dans le forum Tomcat et TomEE
    Dernier message: 09/08/2006, 09h45
  5. [Débutant] Problème servlet simple
    Par davycrocket dans le forum Servlets/JSP
    Dernier message: 30/06/2004, 09h24
