TExture sphere
    Février 2005
    Par défaut TExture sphere
    Bonjour, j'ai crée une sphere, je voudrai lui appliquer une texture, je faistourner la sphere, mais la texture ne tourne pas, grrr, je ne sais pourkoi:
    #include <GL/glu.h>
    #include <GL/glut.h>
    #include <stdlib.h>
    #include <stdio.h>
    #include "sgi.h"
    #include <math.h>
    #define MGL_JPEG 1
    #define MGL_RGB 2
    float myangle = 0.0;
    GLint id_tex1;
    GLint id_tex2;
    GLuint init_texture(char *nom,int format)
      GLubyte *image;  // pour stocker les pixels de l'image texture
      GLuint tex_id;
      GLint longueur,largeur,depthi;
    	switch (format) {
    		case MGL_JPEG:image=read_jpg(nom,&longueur,&largeur,&depthi);break;
    		case MGL_RGB:image=read_sgi(nom,&longueur,&largeur,&depthi);break;
    		default:exit(1);
    	printf("lecture image : %d x %d x %d\n",longueur,largeur,depthi);
    	glGenTextures(1,&tex_id); // alloue 1 identifiant à tex_id.
    	glBindTexture(GL_TEXTURE_2D,tex_id); // la texture courante 2D correspond à
    	glPixelStorei(GL_UNPACK_ALIGNMENT,1);
    	glTexImage2D(GL_TEXTURE_2D,0,GL_RGB,longueur,largeur,0,GL_RGB,GL_UNSIGNED_BYTE,image);
    	glTexParameterf(GL_TEXTURE_2D,GL_TEXTURE_WRAP_S,GL_REPEAT);
    	glTexParameterf(GL_TEXTURE_2D,GL_TEXTURE_WRAP_T,GL_REPEAT);
    	glTexParameterf(GL_TEXTURE_2D,GL_TEXTURE_MAG_FILTER,GL_NEAREST);
    	glTexParameterf(GL_TEXTURE_2D,GL_TEXTURE_MIN_FILTER,GL_NEAREST);
    	glTexEnvf(GL_TEXTURE_ENV,GL_TEXTURE_ENV_MODE,GL_REPLACE);
    	return tex_id;
    void texture_coord(GLint idtex)
    	glBindTexture(GL_TEXTURE_2D,idtex);
    	glEnable(GL_TEXTURE_2D);
    void texture_sphere(GLint idtex)
      glTexGeni(GL_S, GL_TEXTURE_GEN_MODE,GL_SPHERE_MAP);
      glEnable(GL_TEXTURE_GEN_S);
      glTexGeni(GL_T, GL_TEXTURE_GEN_MODE,GL_SPHERE_MAP);
      glEnable(GL_TEXTURE_GEN_T);
    void desactiver_texture() {
      glDisable(GL_TEXTURE_GEN_S);
      glDisable(GL_TEXTURE_GEN_T);
      glDisable(GL_TEXTURE_2D);
    void myIdle() {
    	myangle+=0.05;
    	glutPostRedisplay();
    static void myReshape(int width, int height) {
    	glViewport(0,0,(GLint) width, (GLint) height);
    	glMatrixMode(GL_PROJECTION);
    	glLoadIdentity();
    	gluPerspective(60.0, (GLfloat) width/(GLfloat)height, 1.0,50.0);
    	glMatrixMode(GL_MODELVIEW);
    void tracerSoleil() {
    	glColor3f(1,1,0);
    	glTranslatef(0.5,0.5,0);
    	glRotatef(myangle,0,1,0);
    	glutSolidSphere(3.0,50,50);
    static void myDisplay() {
    	glClearColor(0,0,0,0);
    	glPushMatrix();
    		glTranslatef(2,3,-20);
    		tracerSoleil();
    	glPopMatrix();
    	glutSwapBuffers();
    void myInit() {
    	glEnable(GL_DEPTH_TEST);
    	glEnable(GL_LIGHTING);
    	glEnable(GL_LIGHT0);
    	initLumiere(GL_LIGHT0);
    	glEnable(GL_COLOR_MATERIAL);
    	glColorMaterial(GL_FRONT_AND_BACK,GL_DIFFUSE);
    	id_tex1=init_texture("texture-sphere.jpg",MGL_JPEG);
    	id_tex2=init_texture("msmichel.jpg",MGL_JPEG);
    	glutInit(&argc,argv);
    	glutInitWindowSize(800,800);
    	glutInitDisplayMode(GLUT_RGB | GLUT_DEPTH | GLUT_DOUBLE);
    	glutCreateWindow("premier prog");
    	glutReshapeFunc(myReshape);
    	glutDisplayFunc(myDisplay);
    	glutIdleFunc(myIdle);
    	myInit();
    	glutMainLoop();
    	return 0;
    Février 2005
    En fait il semblerait que ce soit une limitation de glut, car le Red Book dit que glut*Sphere ne génère pas de coordonnées de textures (essayes avec glut*Teapot qui est la seule à générer ces coordonnées pour vérifier). Je ne sais pas s'il est possible de fournir les coordonnées de texture manuellement, mais sinon il ne te reste plus qu'à créer la sphère toi-même.
  1. Pb texture sur une sphere
    Par olivier21c dans le forum OpenGL
    Dernier message: 25/02/2011, 10h54
  2. Texture Sphere OpenGL
    Par bouillet dans le forum OpenGL
    Dernier message: 07/12/2008, 03h14
  3. Texture de sphere..
    Par DrTank dans le forum OpenGL
    Dernier message: 08/05/2007, 21h51
  4. texture d'une sphere?
    Par swibina dans le forum GLUT
    Dernier message: 31/03/2007, 20h50
  5. Sphere et texture
    Par JuLiOoOoO dans le forum DirectX
    Dernier message: 16/02/2005, 17h20
