1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59
Dim FES As String * 16
Dim FES_TIME As String * 4
Dim Datum As Date
Dim t As Integer
Dim szHelp As String
Dim szHelp2 As String
Dim f As Integer
Dim v As Variant
Dim l As Long
f = FreeFile
Open App.Path + "\Jugl.db" For Binary Access Read As #f
Do While Not EOF(f)
Get #f, , FES
If EOF(f) Then Exit Do
Get #f, , FES_TIME
szHelp = ""
For t = 1 To 4
szHelp = szHelp + Right("00" + Hex(Asc(Mid(FES_TIME, t, 1))), 2)
Next
l = "&H" & szHelp
Datum = DateAdd("s", l, CDate("01.01.1970"))
szHelp = ""
Dim c As Integer
For t = 1 To 16
c = Asc(Mid(FES, t, 1))
szHelp = szHelp + Right("00" + Hex(c), 2)
Next
List1.AddItem Format(Datum, "hh:mm:ss dd.mm.yyyy") + " -> " + szHelp
Loop
Close #f
et
Private Sub Command3_Click()
Dim szFilename As String
Dim t As Integer
Dim f As Integer
Dim Data() As String
szFilename = App.Path + "\v_fes.txt"
List1.Clear
szHelp = Space(FileLen(szFilename))
f = FreeFile
Open szFilename For Binary Access Read As #f
Get #f, , szHelp
Close #f
Data = Split(szHelp, vbCrLf)
For t = 0 To UBound(Data)
If Trim(Data(t)) <> "" Then
List1.AddItem Trim(Data(t))
End If
Next t |
