Salut, j'ai cree la page jsp suivante:
Code xml : Sélectionner tout - Visualiser dans une fenêtre à part
42 <%@ page language="java" contentType="text/html; charset=ISO-8859-1" pageEncoding="ISO-8859-1"%> <jsp:useBean id="mybean" scope="page" class="pak.Prog" /> <jsp:setProperty name="mybean" property="*" /> <HTML> <HEAD> <TITLE>service simulator</TITLE> <META HTTP-EQUIV="Content-Type" CONTENT="text/html; charset=iso-8859-1"> <style type="text/css"> <!-- .Style1 {font-family: Arial, Helvetica, sans-serif} --> </style> </HEAD> <BODY BGCOLOR=#FFFFFF LEFTMARGIN=0 TOPMARGIN=0 MARGINWIDTH=0 MARGINHEIGHT=0> <FORM METHOD=POST ACTION="pagejsp.jsp"> <table width="490" height="549" border="0" align="center" background="../images/interface2.gif" > <tr> <td width="484" height="543"> <div align="center"> <p><textarea name="textarea" cols="40" rows="10"></textarea></p> <p> </p> </div> <table width="432" border="0"> <tr> <td width="302"><div align="center"> <input type="submit" name="Submit" value="SEND"> </div></td> <td width="120"><input type="submit" name="Submit2" value="ERASE"></td> </tr> </table> </td> </tr> </table> <!-- ImageReady Slices (Untitled-1.html) --> </FORM> </BODY> </HTML>
et aussi la classe suivante utilisée comme bean:
65 package pak; import java.io.*; import java.util.Iterator; import java.util.StringTokenizer; import java.util.List; import org.jdom.*; import org.jdom.input.*; public class Prog { String text,kw,msg; static org.jdom.Document doc; static Element services; String message; public Prog(){} public void setTextarea (String chaine) { text=chaine; System.out.println(text); } public String getTextarea() { StringTokenizer tok = new StringTokenizer(text, " "); int nv = tok.countTokens(); msg = ""; //key word// kw = tok.nextToken().toString(); // /**reste du message// for (int i = 1; i < nv; i++) { msg += (tok.nextToken().toString() + " "); } // **fin reste du message**// // ***lecture du fichier xml SAXBuilder sxb = new SAXBuilder(); try { doc = sxb .build(new File( "C:/Aymen/eclipseworkspace/projet web/src/pak/services.xml")); } catch (Exception e) { } services = doc.getRootElement(); List service = services.getChildren("service"); Iterator k = service.iterator(); while (k.hasNext()) { Element courant = (Element) k.next(); if (courant.getChild("nom").getText().equals(kw)) { message=(courant.getChild("text").getText()); } } System.out.println(message); return(message); } }
Mais j'ai rencontré un probleme en utilisant getProperty et donc la methode getTextarea; j'ai pas pu afficher le resultat de retour dans le textarea; svp est ce que vous pouvez me dire comment dois je proceder?et une autre question: est ce que je peux utiliser getProperty et setProperty pour le meme doc jsp??
merci d'avance pour votre aide
