pb de multitexturing
    Futur Membre du Club
    Juin 2004
    Par défaut pb de multitexturing
    j'essaye de faire du multitexturing sur une skybox que j'avais texturé simplement.
    mais j'ai un probleme de mémoire a l'éxecution qui vient uniquement de l'affichage de la skybox mais je ne trouve pas précisément l'erreur
    voici le .h de ma classe skybox
    // Skybox.h: interface for the Skybox class.
    #if !defined(AFX_SKYBOX_H__C4FD8F0B_B99E_4395_9343_533A6C578571__INCLUDED_)
    #define AFX_SKYBOX_H__C4FD8F0B_B99E_4395_9343_533A6C578571__INCLUDED_
    #if _MSC_VER > 1000
    #pragma once
    #endif // _MSC_VER > 1000
    #include <windows.h>
    #include <gl\gl.h>
    #include <gl\glu.h>
    #include <gl\glaux.h>
    #include "Vector.h"
    #include "Texture.h"
    #include "tga.h"
    #include "glext.h"
    // External Function Pointers ///////////////////////////////////////////////////////////
    extern PFNGLMULTITEXCOORD2FARBPROC glMultiTexCoord2fARB;
    extern PFNGLACTIVETEXTUREARBPROC glActiveTextureARB ;
    extern PFNGLCLIENTACTIVETEXTUREARBPROC glClientActiveTextureARB;
    class Skybox
    public:
    	Skybox();
    	virtual ~Skybox();
    	void affiche();
    	void DefinitTexture(Texture *t1,Texture *t2,Texture *t3,
    						Texture *t4,Texture *t5,Texture *t6);
    private:
    		Texture *skybox_front;
    		Texture *skybox_back;
    		Texture *skybox_top;
    		Texture *skybox_bottom;
    		Texture *skybox_right;
    		Texture *skybox_left;
    		GLfloat box_ambient [4];
    		GLfloat box_diffuse [4];
    		GLfloat box_specular [4];
    		GLfloat box_shininess [1];
    #endif // !defined(AFX_SKYBOX_H__C4FD8F0B_B99E_4395_9343_533A6C578571__INCLUDED_)
    voici le .cpp de ma classe skybox
    // Skybox.cpp: implementation of the Skybox class.
    #include "Skybox.h"
    #include "glext.h"
    #include "glut.h"
    PFNGLMULTITEXCOORD2FARBPROC glMultiTexCoord2fARB = NULL;
    PFNGLACTIVETEXTUREARBPROC glActiveTextureARB = NULL;
    PFNGLCLIENTACTIVETEXTUREARBPROC glClientActiveTextureARB = NULL;
    // Construction/Destruction
    Skybox::Skybox()
    Skybox::~Skybox()
    void Skybox::DefinitTexture(Texture *t1,Texture *t2,Texture *t3,
    		skybox_front = t1;
    		skybox_back = t2;
    		skybox_top = t3;
    		skybox_bottom = t4;
    		skybox_right = t5;
    		skybox_left = t6;
    		box_ambient[0]=0.5f;  box_ambient[1]=0.5f;  box_ambient[2]=0.5f;  box_ambient[3]=1.0f;
    		box_diffuse[0]=0.8f;  box_diffuse[1]=0.8f;  box_diffuse[2]=0.8f;  box_diffuse[3]=1.0f;
    		box_specular[0]=0.0f; box_specular[1]=0.0f; box_specular[2]=0.0f; box_specular[3]=1.0f;
    		box_shininess[0]=1.0f;
    void Skybox::affiche()
    	glMaterialfv(GL_FRONT_AND_BACK, GL_AMBIENT, box_ambient);
    	glMaterialfv(GL_FRONT_AND_BACK, GL_DIFFUSE, box_diffuse);
    	glMaterialfv(GL_FRONT_AND_BACK, GL_SPECULAR, box_specular);
    	glMaterialfv(GL_FRONT_AND_BACK, GL_SHININESS, box_shininess);
    	/* Unité de texture 0 activée */
    	glActiveTextureARB(GL_TEXTURE0_ARB);
    	glEnable(GL_TEXTURE_2D);
    	/* Texture brick pour l'unité 0 */
    	skybox_front->utilise();
    	/* Unité de texture 1 activée */
    	glActiveTextureARB(GL_TEXTURE1_ARB);
    	/* Texture lightmap pour l'unité 1 */
    	skybox_back->utilise();
    	//glEnable (GL_TEXTURE_2D);
    	//skybox_front->utilise();
    	glNormal3f( 0.0f, 0.0f, -1.0f);
    	glBegin ( GL_QUADS );
    		//  Face de devant
    		//glTexCoord2f(1.0f, 1.0f);
    		glMultiTexCoord2fARB(GL_TEXTURE0_ARB, 1.0f, 1.0f);
    		glMultiTexCoord2fARB(GL_TEXTURE1_ARB, 1.0f, 1.0f);
    		glVertex3f(-150.0f, -150.0f,  150.0f);
    		//glTexCoord2f(0.0f, 1.0f);
    		glMultiTexCoord2fARB(GL_TEXTURE0_ARB, 0.0f, 1.0f);
    		glMultiTexCoord2fARB(GL_TEXTURE1_ARB, 0.0f, 1.0f);
    		glVertex3f( 150.0f, -150.0f,  150.0f);
    		//glTexCoord2f(0.0f, 0.0f);
    		glMultiTexCoord2fARB(GL_TEXTURE0_ARB, 0.0f, 0.0f);
    		glMultiTexCoord2fARB(GL_TEXTURE1_ARB, 0.0f, 0.0f);
    		glVertex3f( 150.0f,  150.0f,  150.0f);
    		//glTexCoord2f(1.0f, 0.0f);
    		glMultiTexCoord2fARB(GL_TEXTURE0_ARB, 1.0f, 0.0f);
    		glMultiTexCoord2fARB(GL_TEXTURE1_ARB, 1.0f, 0.0f);
    		glVertex3f(-150.0f,  150.0f,  150.0f);
    	glEnd();
    	// idem pour les autres faces ...
    j'utilise une classe texture qui permet d'initilaiser toutes mes textures.
    si vous avez besoin cette classe ou si vous avez des questions, n'hésiter pas
    merci d'avance
    Membre confirmé Avatar de Groove
    Décembre 2002
    Et tu donne une valeur à glMultiTexCoord2fARB a un moment ? Avec (wgl|glx)GetProcess ?
    Juin 2004
    est-ce que par donner une valeur tu entends :
    je n'ai jamais rencontré dans les tutoriaux que j'ai utilisé. as-tu un exemple ?
    merci
    Juillet 2002
    C'est plutôt wglGetProcAddress qu'il faut utiliser pour récupérer l'adresse de la fonction avant de pouvoir l'utiliser.
    Juin 2004
    merci pour votre aide, il me manquait effectivement trois lignes :
    glMultiTexCoord2fARB = (PFNGLMULTITEXCOORD2FARBPROC) wglGetProcAddress("glMultiTexCoord2fARBV");
    	glActiveTextureARB = (PFNGLACTIVETEXTUREARBPROC) wglGetProcAddress("glActiveTextureARB");
    	glClientActiveTextureARB = (PFNGLCLIENTACTIVETEXTUREARBPROC) wglGetProcAddress("glClientActiveTextureARB");
    malgré cela, j'ai toujours une erreur au moment ou je lance mon programme ...
    Juin 2004
    autant pour moi j'avais fait une méthode d'initialisation du multitexturing avec ces lignes et je ne l'appelais pas .... une erreur bête !!!
    donc voila ca marche merci beaucoup
  1. Multitexture
    Par Finch dans le forum OpenGL
    Dernier message: 28/05/2005, 15h29
  2. Multitexturing Vertex Array et Display List
    Par Wyatt dans le forum OpenGL
    Dernier message: 04/05/2005, 16h07
  3. Multitexturing?
    Dernier message: 16/02/2005, 15h16
  4. Multitexturing et éclairage
    Par Dranor dans le forum DirectX
    Dernier message: 21/02/2004, 13h41
  5. Multitexturing???
    Par sebh dans le forum OpenGL
    Dernier message: 07/12/2003, 19h23
