1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79
taille des tables
CREATE OR REPLACE FUNCTION
c_to_f (p_tname in varchar2) RETURN NUMBER IS
l_columnValue number default NULL;
BEGIN
execute immediate
'select count(*)
from ' || p_tname INTO l_columnValue;
return l_columnValue;
END;
SELECT * FROM (
SELECT
tablespace_name,
owner,
object_type, table_name,
rtrim(to_char(ROUND(bytes)/1024/1024, '99990.00000'), '.') AS Megabytes,
ROUND(Sum(bytes/1024/1024) OVER (PARTITION BY table_name)) AS Tables_in_MB,
c_to_f(table_name) AS COUNT_RECORDS
FROM (
-- We can start this with Table size
SELECT
tablespace_name,
owner,
'TABLE' AS object_type,
segment_name AS table_name, bytes
FROM dba_segments
WHERE segment_type IN ('TABLE', 'TABLE PARTITION', 'TABLE SUBPARTITION') --e are selecting the table,table partition and table
----subpartition
UNION ALL
--- We require to check for Indexes
SELECT
s.tablespace_name,
i.owner,
'Index' AS object_type,
i.table_name, s.bytes
FROM dba_indexes i, dba_segments s
WHERE s.segment_name = i.index_name
AND s.owner = i.owner
AND s.segment_type IN ('INDEX', 'INDEX PARTITION', 'INDEX SUBPARTITION')
-- Then for LOB
UNION ALL
SELECT
s.tablespace_name,
l.owner,
'LOB_COLUMN' AS object_type,
l.table_name, s.bytes
FROM dba_lobs l, dba_segments s
WHERE s.segment_name = l.segment_name
AND s.owner = l.owner
AND s.segment_type = 'LOBSEGMENT'
-- Get data of LOB INDEXES
UNION ALL
SELECT
s.tablespace_name,
l.owner,
'LOB_INDEX' AS object_type,
WHERE s.segment_name = l.index_name
AND s.segment_type = 'LOBINDEX'
WHERE owner in UPPER('&schema_name')
ORDER BY COUNT_RECORDS DESC,Tables_in_MB DESC, OBJECT_TYPE DESC
